Reglas del Foro
Avatar de Usuario
Been thanked: 1044 times
Contactar:
Mensaje por SashaCX75 »
Imagen
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Última edición por SashaCX75 el 01 Jun 2022, 07:20, editado 25 veces en total.
Horatius80
Mensaje por Horatius80 »
Adjuntos
Amazfit_RainbowCircle.zip
Compressed bin file:
(149.7 KiB) Descargado 1519 veces
Avatar de Usuario
Has thanked: 437 times
Been thanked: 2141 times
Contactar:
Mensaje por asoo »
Imagen
Imagen
(607.67 KiB) Descargado 2186 veces
Última edición por asoo el 15 Ene 2020, 07:16, editado 1 vez en total.
Avatar de Usuario
Lordalpine
Been thanked: 35 times
Contactar:
Mensaje por Lordalpine »
asoo escribió: 07 Ene 2020, 02:54
Avatar de Usuario
Contactar:
Mensaje por asoo »
Lordalpine escribió: 08 Ene 2020, 10:11
( Thank SashaCX75 )
Ekohero
Contactar:
Mensaje por Ekohero »
have the problem with
Imagen
I cant extract the bin.
Matth78
Contactar:
Mensaje por Matth78 »
Does compile work? I failed to do it with Windows without python. I don't understand what is wrong since it seems so simple! 😓
Edit :
For those who may have the same problem, mine was coming from no transparency on some image.
After adding transparency I have been able to pack. (But produced bin does not work on my watch T_T)
Última edición por Matth78 el 13 Ene 2020, 20:09, editado 1 vez en total.
Ekohero
Contactar:
no compile:
bin to -> open file directory does not work
so I cant edit this watchfaces
I wanted to see how the circles for calories and temperatur are done
Avatar de Usuario
Contactar:
Mensaje por asoo »
GTR_WatchFace editor for Windows by SashaCX75
Version 5.2 full
Imagen
The program is available for download now.
http://4pda.ru/forum/index.php?showtopi ... ry92847810
Обновил Графический редактор циферблатов
Добавлена поддержка набора иконок (иконки и набор координаты к ним) для прогресса шагов и батареи.
Добавлена возможность обрезки предпросмотра по форме экрана.
Исправлены ошибки в английской версии.
Google translate
Updated Graphical Dial Editor
Thank SashaCX75
kampanita
Has thanked: 8 times
Been thanked: 7 times
Contactar:
Mensaje por kampanita »
asoo escribió: 13 Ene 2020, 18:22
Version 5.2 full
Imagen
Google translate
Thank SashaCX75
I can not download from 4pda.ru , not registered at that site....I tried to but don't understand russian and google translate didn't help also.
Could you upload 5.2 version to somewhere else ( mega / drive ... ) ?
Avatar de Usuario
Contactar:
Mensaje por asoo »
kampanita escribió: 14 Ene 2020, 08:17
I'm not sure if 4pda allows copying this file for distribution outside of the 4pda in public.
To conclude, I sent my link that I uploaded for you in PM.
Please SEE your Private message
Horatius80
[mention]asoo[/mention] please, if it is possibble, share the link with me also ... many many thx
Avatar de Usuario
Contactar:
Mensaje por asoo »
Horatius80 escribió: 14 Ene 2020, 10:44
@asoo please, if it is possibble, share the link with me also ... many many thx
Next time, who wants my link?
Please PM to me
Do not post request
Thank
Última edición por asoo el 23 Ene 2020, 00:34, editado 1 vez en total.
Avatar de Usuario
Contactar:
If you want to improve the translation or add a translation into other languages, write in PM.
Kastelic
Contactar:
Mensaje por Kastelic »
many many thx
Starlince
Contactar:
Mensaje por Starlince »
hola a todos, perdón por mi petición, pero es que me he bajado el programa watchfaces tools en inglés pero no se como funciona, se que es mucho pedir, pero alguien me podría decir, indicar o remitir a unas instrucciones para un novato?? Muchas gracias de antemano y perdón por las molestias.
Ekohero
Contactar:
may i get a link pls?
ionut02
Contactar:
Mensaje por ionut02 »
Hi, can I please have the link for the new version. 4PDA uses Russian captcha for creating an account, practically impossible to register with google translate.
ss30
Contactar:
Mensaje por ss30 »
Hi can someone pm me the dl link for 5.2 please.
Avatar de Usuario
maikeandre
Contactar:
Mensaje por maikeandre »
Guys, here you have a tutorial to bypass the captcha from 4DPA.
https://doorsgeek.blogspot.com/2015/08/ ... orial.html
Tugas
Has thanked: 7 times
Contactar:
Mensaje por Tugas »
ionut02
Contactar:
maikeandre escribió: 24 Ene 2020, 00:17
Thanks maikeandre, that tutorial worked great.
Fuzzy
Contactar:
Mensaje por Fuzzy »
can be used for verge lite?
Matierk
Contactar:
Mensaje por Matierk »
Is there a GTR editor for mac
Avatar de Usuario
Contactar:
Fuzzy escribió: 28 Ene 2020, 21:45
The editor is not designed for the verge lite screen size. The preview image may not be correct (especially for analog clock). But theoretically, he should collect dials for verge lite. To do this, on the first tab, replace "--gtr 47 --file" with "--vergelite --file".
Avatar de Usuario
Contactar:
Matierk escribió: 29 Ene 2020, 02:06
No
Responder
Volver a “Watchfaces tools”
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 4 invitados
