py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Post by afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
Been thanked: 2122 times
lobianco wrote: 16 Jun 2024, 19:43
lobianco wrote: 15 Jun 2024, 22:13
asoo wrote: 15 Jun 2024, 14:31
This is a tool used to pack and unpack and edit watch faces that use ZeppOS as the operating system, which GTRmini is one of them.
PS. The format of the watch face using zeppOS will be .zip.
Hi asoo,
I used the wonderful Watch Face Editor program (ZeppOS), as you indicated, from SashaCX75, I made a watchface for the GTRmini, it generated a .zip file, how do I install this watchface on the watch?
[/quote]
You can UPLOAD your watch face to the web with your ID and install it through the AmazFaces app.
viewforum.php?f=23
OR please see instructions from the link below for other way.
lobianco
Post by lobianco »
Hi, asoo
I did everything, turned it into zpk, created QR Code, and nothing worked, several and several attempts, finally, I took the zip created with the @SashaCX75 program, put it on the smartphone, with the file manager, told it to open with the app Amazfaces, it installed without problems.
Thank you very much for your information, good will, I learned a lot.
