Messaggio da SashaCX75 »
1mylord
The arrow pointer cannot move smoothly. It depends on the firmware.
don1yoor
Messaggio da don1yoor »
Hello guys. How to rotate numbers for GTS 3 ?
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Messaggio da demiurg1 »
demiurg1
I have such a question. Does anyone know how after the next ZEPP update, you can upload the file with the dial to your smartwatch. So far I used an Android app called "GTR 3" and there, after selecting the "Install own WatchFace" option, I was able to install my watch face using the indicated watch face in Zepp. Unfortunately, this app doesn't work with Zepp 6.9.7. Can anyone advise on this topic besides uninstalling the new version of Zepp and installing the old one?
FeRu
Has thanked: 14 times
Been thanked: 8 times
Messaggio da FeRu »
demiurg1 ha scritto: 28 giu 2022, 10:03
Hey. This is known problem because new ZEPP version changed watchface store and instalation proces. This should be fixed soon in newer version of GTR3 app (I used the same for testing my work). You have 2 options right now: Unistall Zepp and install older version or use Amazfitfacess app to install watchfaces. You can upload private watchface and install by app. It works fine.
demiurg1
I chose the second method. I have used the Amazfitfacess app or it is actually "AmazFaces" and it failed. I can only download the ZIP file. I haven't found "Amazfitfacess" anywhere. I also found the "Amazfit WatchFaces" program, but there is the same problem as with the "GTR 3" application. Both programs need the old version of Zepp.
demiurg1
In the "AmazFaces" app I can see the correct "Amazfit GTR" watch model and I have chosen the watch face for the GTR 3. "Connect" appears. I click on it, then "Continue" and nothing happens. The watch face does not install. The watch is visible in Zepp and is syncing correctly.
Has thanked: 1162 times
Been thanked: 278 times
Messaggio da GIK-Team »
demiurg1 ha scritto: 29 giu 2022, 10:00
Leave all comments about the application here: viewforum.php?f=23
Developer reads them and makes all the corrections.
FeRu
Messaggio da FeRu »
In Amazfitfaces app your watch is shown with MAC adress? If not you can add MAC manually in app options and then you will be able to install faces. BT MAC adress is shown in ZEPP app.
Ultima modifica di FeRu il 30 giu 2022, 09:19, modificato 1 volta in totale.
demiurg1
Thanks a lot. I entered the address manually and it helped right away.
FeRu
Messaggio da FeRu »
demiurg1 ha scritto: 30 giu 2022, 09:12
Great ;)
DvdDs
Messaggio da DvdDs »
Is it possible to create watchfaces for the bip3 with this tool? thank you.
don1yoor
please update this tool pleeease
Evilmind_04
Been thanked: 14 times
Messaggio da Evilmind_04 »
don1yoor ha scritto: 25 lug 2022, 17:59
Sasha is working hard on the program so have a little patience please.
Big update will come soon.
Remember life ain't easy in Ukraine 🇺🇦, no further explanation needed.
ajulraj
Messaggio da ajulraj »
Is it possible to add mi band 7 support to this tool?
kwakykwaky1
Has thanked: 8 times
Messaggio da kwakykwaky1 »
Hi, friend ,
mainly health .
The program will wait :-) .
Your friend from CZ
Guydu91
Has thanked: 58 times
Messaggio da Guydu91 »
kwakykwaky1 ha scritto: 31 lug 2022, 16:24
Hi, friend ,
mainly health .
Your friend from CZ
+1 from France.
ThomasAn.
Messaggio da ThomasAn. »
SashaCX75 ha scritto: 26 gen 2022, 16:01
ThomasAn. ha scritto: 26 gen 2022, 03:09
Thanks for the tip. Is there a tutorial on how to code this manually ?
Here are a few examples of 24hr dial watches
https://www.watchuseek.com/threads/noon ... es.5244589
I'd be particularly interested in replicating this dial:
demiurg1
If you are not in a rush, please wait a bit. In my free time, I will try to design this watch face. If a watch face is made, you will find it under the name "VR PRIORIS EXPLORER".
However, it will not be a 24-hour dial, because Amazfit does not have this option in analog, only as a digital clock.
Are you reflecting on a 12-hour analog clock? Is the time to be additionally given in the digital version?
This would be a watch face for the GTR 3.
demiurg1
This watch face is now available for the GTR 3 here:
https://amazfitwatchfaces.com/gtr/view/26229
ThomasAn.
demiurg1 ha scritto: 01 ago 2022, 07:26
Thank you for that, but I was specifically looking for the 24 hour analog dial, that was the whole point ... how to make the hour marker move at half speed so that 12 oclock is always 12 noon pointing up towards the sky. Otherwise the horizon graphics make no sense (6am needs to be on the left to indicate sunrise and 6pm on the right to indicate sunset, etc)
Regular 12hr dials are no problem, I can do them too.
Again thank for taking the time on that dial though, sorry if I wasn't clear earlier and got you into all this work for nothing.
demiurg1
It's my hobby. I did it with pleasure for exercise. In analog 24-hour time, I will not help. I don't even know if it's possible. Regards
ThomasAn. ha scritto: 31 lug 2022, 23:03
Of all the watches found on the link, I was interested in Botta Duo and SVALBARD NOIR AA22. If you provide graphic resources for creating a dial, I can try to make these.
demiurg1
If I find some time, I will try to deliver BOTTA elements in black and 24 hours.
Anoniem
Messaggio da Anoniem »
how to make a smooth second hand?, i tried to unpack a watchface with a smooth second hand but it wont work.
Torna a “Watchfaces tools”
Visitano il forum: Baidu [Spider] e 1 ospite
