Been thanked: 1044 times
Messaggio da SashaCX75 »
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Maikeldevil
Been thanked: 44 times
Messaggio da Maikeldevil »
spidey_potter ha scritto: 27 mar 2020, 11:01
Silly Question,
but can this be used to create watch faces from scratch? i seem to be running into issues of not being able to start a project at all?
Yes you can.. but not without images XD add your images and assign a element. Start with the background:-p
marcosalzillo
Messaggio da marcosalzillo »
Hi SashaCX75
There are instruction ?
i can't decompress any file and i don't know what is the MAIN.exe file and i don't know where i can find json file and what i have to do after...
i downloaded a bin file to do an exercise (GTR.bin)
but i can't decompress it. After clicked "unpack compresse bin " i found the same bin il the "watch_face" folder...
what i have to do?
thank you
Allegati
[mention]spidey_potter[/mention]
Yes you can.
Prepare all the necessary pictures.
On the "Choose" tab, press the image-selection button and load all the pictures into the program.
On the "Editing" tab, edit the settings and save the json file.
[mention]marcosalzillo[/mention]
The path to the program should not contain spaces. It is advisable to put the program in the root of the disk.
marcosalzillo
SashaCX75 ha scritto: 28 mar 2020, 11:40
@marcosalzillo
thank you but it doesn't work... i have the same issue... when i want unpack the bin file, i found the same file in the Watch_face folder...
Lordalpine
Been thanked: 35 times
Messaggio da Lordalpine »
marcosalzillo ha scritto: 28 mar 2020, 13:29
@marcosalzillo
There's a space on your Username Session did you change where the program is ?
No Space means at least an underscore to simulate space "_"
Put the program on c:\ [ If you want you can create a folder if you don't want to have it directly on c:\ like Gtr_Tool Gtrtool GTR_dev so the destination will be C:\GTR c:\Gtr_Tool c:\ GTR_dev ]
Once it's unpack or unpack compressed bin file, the Bin is replicated on Watchface folder, and an additional folder is created with all the file inside.... For example if you bin file : GTR_test. bin , a folder named GTR_Test will be created with all the files inside.
Look inside that new folder created, if it's empty, it's a compressed bin.
If you choose to Unpack compressed bin and the new folder created is still empty [ just a log file inside ] There's something wrong on how you set up your Work space.
On the 2nd picture I see another Hard drive or partition "Programmi e An" why don't you put it there ?
Has thanked: 437 times
Been thanked: 2141 times
Messaggio da asoo »
Ultima modifica di asoo il 29 mar 2020, 08:50, modificato 1 volta in totale.
Lordalpine ha scritto: 28 mar 2020, 23:44
If none of what is written here helps, try a different watch face. Some dials are not unpacked, but there are very few.
Version 7.0
aliense
Messaggio da aliense »
Why when i set to on month (as numbers) and monthname (as name), my watch didn't show month in numbers?
On preview is allright, but on watch nope :(
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 357,
"TopLeftY": 162,
"BottomRightX": 0,
"BottomRightY": 0,
"Alignment": "TopLeft",
"Spacing": 2,
"ImageIndex": 12,
"ImagesCount": 10
"MonthName": {
"X": 141,
"Y": 149,
"ImageIndex": 43,
"ImagesCount": 12
"Day": {
"TopLeftX": 285,
"TopLeftY": 162,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 2,
"ImageIndex": 12,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 129,
"Y": 176,
"ImageIndex": 55,
"ImagesCount": 7
Allegati
Bez nazwy-3.jpg (581.58 KiB) Visto 46950 volte
Synek
Messaggio da Synek »
Hello. I would like to change only the background of the face. How to do it quickly and easily? I don't know how to use the program.
cmelcher78
Messaggio da cmelcher78 »
Hi. I can not extract bin files with weather Info within. Do you have an idea what I do wrong? Used different tools.
Maikeldevil
Synek ha scritto: 30 mar 2020, 20:13
Dude, dont be so damn lazy, just read the whole topic and try it yourself.. It easy as hell with this tool..
vape
Messaggio da vape »
Newbie here. I tried to find info but I failed, so please help. I downloaded the app (which is fantastic), managed to unpack and edit the necessary files the packed/compressed back. I can see there are 2 new bin files, one with ***packed.bin and one with ***packed_zip.bin ending. Which one should I upload to the watch now? I'm little bit confused, please help me out with this. Thank you in advance, you're doing great job!
[mention]cmelcher78[/mention]
Weather dials should normally be unpacked in the program starting with version 6. If any dial is not unpacked, it means that you are doing something wrong. If one specific dial is not unpacked, send it I will look.
[mention]vape[/mention]
Any.
*** packed_zip.bin is compressed and installs a little faster.
Lordalpine
vape ha scritto: 31 mar 2020, 14:52
Hello, Thank you in advance, you're doing great job!
Let's say a 1Mo File Bin [Normal Bin File ] will install slower than a 200Ko File_zip.Bin [ Compressed Bin File ]
Size difference, Bluetooth data rate transfer.... but finally same face. Just transfer you bin file and after transfer the zip.bin.
You will see a Huge gain of time. [ BT 5.0 // Note 10 // Android 10 ] with the 200Ko Face VS 1Mo Face.
vape
Messaggio da vape »
Thanks for your quick answer,
I don't know what went wrong but the package_zip.bin file ended up with firmware error when I tried to upload it via Mi Bandage andoid app, The other bin file could be uploaded but doesn't appear on the watch, there are only those 2 preinstalled watchfaces.
bushmaster
Messaggio da bushmaster »
SashaCX75 ha scritto: 29 mar 2020, 08:15
does the animation work for all watch (GTR,GTS,T-REX and Verge Lite)?
i tried for t-rex, it does show on the preview, but nothing on the watch after i applyed it..
this is my animation setting
"Unknown11": {
"Unknown11_2": {
"Unknown11d2p1": {
"X": 75,
"Y": 115,
"ImageIndex": 49,
"ImagesCount": 10
"Unknown11d2p2": 130,
"Unknown11d2p3": 0,
"Unknown11d2p4": 1170,
"Unknown11d2p5": 350
Maikeldevil
TOOL
1. For the people who are finding it hard to create font png's here is a tool you can use this tool:
AMAZFITFONTGENERATOR
2. For people who wants to convert images from a 47mm GTR to a 42mm GTR use this tool:
GTR47 to 42 IMAGE GENERATOR
Download here:
GTR IMAGE TOOLS
bushmaster ha scritto: 01 apr 2020, 09:32
GTR, GTS - animation works
T-REX - no information
Verge Lite - supposedly animation support appeared on the latest beta version of the firmware, there is no animation on stable firmware.
I have the opportunity to test only on GTR and the editor is primarily designed for this watch. On the other watch, some functions may not work.
bushmaster
SashaCX75 ha scritto: 01 apr 2020, 14:34
Thank you for the reply, i will keep stay tuned for the next update, hope it will be more information for t-rex...
The software is very good, again thank you very much..
shirumitsu
Messaggio da shirumitsu »
I'm having a problem, when I will compress for .bin always be giving more than 1.95mb, I have already changed the fonts, I already took the time, dates, everything, even without editing anything when I will compress the .bin give the warning
please help
Maikeldevil
shirumitsu ha scritto: 02 apr 2020, 01:04
please help
Could you share the file so we can see?
RainerR
Messaggio da RainerR »
Hello Sasha CX75,
I have a very interesting problem with my GTR47 and a watch face.
The 1. photo shows a WF created with your Watch Face Editor (V6) and as it should be. The WF is packed and compressed, and synchronized with the watch - everything is okay up to here. The WF is loaded and it is correctly visible. The preview image is also okay (photo 3)
Info: the file not compressed 1.5 MB, compressed 480 kB.
But .... later the WF is not displayed correctly - as shown on my watch in photo 2.
But that doesn't always stay that way. I will be shown later (15 min - 30 min or more) the WF is correct and then later again is not correctly displayed.
I only have the problem with this WF. I've changed different images, rearranged them, but always the same problem.
What could be the mistake? Do you have any idea?
Thanks for this great WatchFace Editor and thank for you reply.
... and that was it - thanks Sasha for your help.
Rainer
Allegati
Photo 3
Photo 3
Photo 2
Photo 2
Photo 1
Photo 1
Ultima modifica di RainerR il 02 apr 2020, 20:28, modificato 3 volte in totale.
Greetings from Bavaria
Rainer
[mention]RainerR[/mention]
Usually this happens when the number of the image with the background is indicated in the weather section for the place of the error symbol
andrebstv
Messaggio da andrebstv »
I`ve a weird issue. I can edit the watchface using the software, but when I try to upload it to the watch it goes ok, but it end up reverting to a stock watchface. Can anyone help me find the error ?
Here is the link to it:
https://amazfitwatchfaces.com/gtr/view/4737
And here is the one I based on:
https://amazfitwatchfaces.com/gtr/view/2165
Torna a “Watchfaces tools”
Visitano il forum: Nessuno e 14 ospiti
