Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Ekohero
Post by Ekohero »
Saschas tool doesnt work for me :( I try to unpack than the file gets copied into the watchface folder and gets opened. but no exracted files are found there. need help :( thank you
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
I see in the PY code (Our tool to create our GTR watchfaces) there is worked on child parent base, i also see that the function dayprogress hasnt got its own element yet. I have a problem that i try to get this function dayprogress behind other elements, ideal would be behind the background.
Also in the background there we have a option to set the X and Y for this element but it doesnt work. When image is smaller then 454 x 454 on the gtr its shown in the left upper corner, if we could fix this i can fix my date problem. (rotating date behind clock).
Please help!
[mention]Ekohero[/mention]
Make sure that the program folder is located in the root of the disk.
To unpack, use the "Unpack compressed bin" button.
Some dials are not unpacked, but the probability of this is very low.
[mention]Maikeldevil[/mention]
The order of rendering elements cannot be changed at the moment (I am afraid that this will not change in the future). But I think you were very good at getting around this limitation. In my opinion, your dial looks quite finished.
Maikeldevil
SashaCX75 wrote: 24 Mar 2020, 15:54
@Ekohero
@Maikeldevil
True but becease of the 2 times usage of the 0000 layer it makes the watch run way slower and slow repond on touch :-( If we could ignore the background function we should be able to run these things way smoother. Now its causes to much lag.
spidey_potter
Post by spidey_potter »
Silly Question,
but can this be used to create watch faces from scratch? i seem to be running into issues of not being able to start a project at all?
Maikeldevil
spidey_potter wrote: 27 Mar 2020, 11:01
Silly Question,
Yes you can.. but not without images XD add your images and assign a element. Start with the background:-p
marcosalzillo
Post by marcosalzillo »
Hi SashaCX75
There are instruction ?
i can't decompress any file and i don't know what is the MAIN.exe file and i don't know where i can find json file and what i have to do after...
i downloaded a bin file to do an exercise (GTR.bin)
but i can't decompress it. After clicked "unpack compresse bin " i found the same bin il the "watch_face" folder...
what i have to do?
thank you
[mention]spidey_potter[/mention]
Yes you can.
Prepare all the necessary pictures.
On the "Choose" tab, press the image-selection button and load all the pictures into the program.
On the "Editing" tab, edit the settings and save the json file.
[mention]marcosalzillo[/mention]
The path to the program should not contain spaces. It is advisable to put the program in the root of the disk.
marcosalzillo
SashaCX75 wrote: 28 Mar 2020, 11:40
@marcosalzillo
thank you but it doesn't work... i have the same issue... when i want unpack the bin file, i found the same file in the Watch_face folder...
Lordalpine
Been thanked: 35 times
Post by Lordalpine »
marcosalzillo wrote: 28 Mar 2020, 13:29
@marcosalzillo
There's a space on your Username Session did you change where the program is ?
No Space means at least an underscore to simulate space "_"
Put the program on c:\ [ If you want you can create a folder if you don't want to have it directly on c:\ like Gtr_Tool Gtrtool GTR_dev so the destination will be C:\GTR c:\Gtr_Tool c:\ GTR_dev ]
Once it's unpack or unpack compressed bin file, the Bin is replicated on Watchface folder, and an additional folder is created with all the file inside.... For example if you bin file : GTR_test. bin , a folder named GTR_Test will be created with all the files inside.
Look inside that new folder created, if it's empty, it's a compressed bin.
If you choose to Unpack compressed bin and the new folder created is still empty [ just a log file inside ] There's something wrong on how you set up your Work space.
On the 2nd picture I see another Hard drive or partition "Programmi e An" why don't you put it there ?
Been thanked: 2122 times
Lordalpine wrote: 28 Mar 2020, 23:44
If none of what is written here helps, try a different watch face. Some dials are not unpacked, but there are very few.
Version 7.0
aliense
Post by aliense »
Why when i set to on month (as numbers) and monthname (as name), my watch didn't show month in numbers?
On preview is allright, but on watch nope :(
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 357,
"TopLeftY": 162,
"BottomRightX": 0,
"BottomRightY": 0,
"Alignment": "TopLeft",
"Spacing": 2,
"ImageIndex": 12,
"ImagesCount": 10
"MonthName": {
"X": 141,
"Y": 149,
"ImageIndex": 43,
"ImagesCount": 12
"Day": {
"TopLeftX": 285,
"TopLeftY": 162,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 2,
"ImageIndex": 12,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 129,
"Y": 176,
"ImageIndex": 55,
"ImagesCount": 7
Bez nazwy-3.jpg (581.58 KiB) Viewed 46770 times
Synek
Post by Synek »
Hello. I would like to change only the background of the face. How to do it quickly and easily? I don't know how to use the program.
cmelcher78
Post by cmelcher78 »
Hi. I can not extract bin files with weather Info within. Do you have an idea what I do wrong? Used different tools.
Maikeldevil
Synek wrote: 30 Mar 2020, 20:13
Dude, dont be so damn lazy, just read the whole topic and try it yourself.. It easy as hell with this tool..
vape
Post by vape »
Newbie here. I tried to find info but I failed, so please help. I downloaded the app (which is fantastic), managed to unpack and edit the necessary files the packed/compressed back. I can see there are 2 new bin files, one with ***packed.bin and one with ***packed_zip.bin ending. Which one should I upload to the watch now? I'm little bit confused, please help me out with this. Thank you in advance, you're doing great job!
[mention]cmelcher78[/mention]
Weather dials should normally be unpacked in the program starting with version 6. If any dial is not unpacked, it means that you are doing something wrong. If one specific dial is not unpacked, send it I will look.
[mention]vape[/mention]
Any.
*** packed_zip.bin is compressed and installs a little faster.
Lordalpine
vape wrote: 31 Mar 2020, 14:52
Hello, Thank you in advance, you're doing great job!
Let's say a 1Mo File Bin [Normal Bin File ] will install slower than a 200Ko File_zip.Bin [ Compressed Bin File ]
Size difference, Bluetooth data rate transfer.... but finally same face. Just transfer you bin file and after transfer the zip.bin.
You will see a Huge gain of time. [ BT 5.0 // Note 10 // Android 10 ] with the 200Ko Face VS 1Mo Face.
vape
Post by vape »
Thanks for your quick answer,
I don't know what went wrong but the package_zip.bin file ended up with firmware error when I tried to upload it via Mi Bandage andoid app, The other bin file could be uploaded but doesn't appear on the watch, there are only those 2 preinstalled watchfaces.
bushmaster
Post by bushmaster »
SashaCX75 wrote: 29 Mar 2020, 08:15
does the animation work for all watch (GTR,GTS,T-REX and Verge Lite)?
i tried for t-rex, it does show on the preview, but nothing on the watch after i applyed it..
this is my animation setting
"Unknown11": {
"Unknown11_2": {
"Unknown11d2p1": {
"X": 75,
"Y": 115,
"ImageIndex": 49,
"ImagesCount": 10
"Unknown11d2p2": 130,
"Unknown11d2p3": 0,
"Unknown11d2p4": 1170,
"Unknown11d2p5": 350
Maikeldevil
TOOL
1. For the people who are finding it hard to create font png's here is a tool you can use this tool:
AMAZFITFONTGENERATOR
2. For people who wants to convert images from a 47mm GTR to a 42mm GTR use this tool:
GTR47 to 42 IMAGE GENERATOR
Download here:
GTR IMAGE TOOLS
bushmaster wrote: 01 Apr 2020, 09:32
GTR, GTS - animation works
T-REX - no information
Verge Lite - supposedly animation support appeared on the latest beta version of the firmware, there is no animation on stable firmware.
I have the opportunity to test only on GTR and the editor is primarily designed for this watch. On the other watch, some functions may not work.
bushmaster
SashaCX75 wrote: 01 Apr 2020, 14:34
Thank you for the reply, i will keep stay tuned for the next update, hope it will be more information for t-rex...
The software is very good, again thank you very much..
