How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Has thanked: 1161 times
Been thanked: 278 times
Detailed instructions for installing custom watch faces on Amazfit GTR, GTS, T-Rex, Verge Lite, Amazfit Bip smartwatches, and Cor and Mi Band 4 smart bracelets.
Note! At the moment, the instruction is relevant only for Zepp (Amazfit)
For a successful installation, you need to connect your gadget to a smartphone on Android or IOS with the Amazfit (Zepp) app installed. You also need to have installed file manager and pre-download the watch face that you would like to set on your watch.
Installation for Android
  1. First, you need to install one of the stock watch faces available in Zepp (Amazfit)/Mifit (if you have already installed one, you may skip this step).
  2. Open the folder with the downloaded watch face in the file manager with the path:
    • Zepp (Amazfit) /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
    • Mi Fit /Android/data/com.xiaomi.hm.health/files/watch_skin_local/
  3. Go to any of these folders and find the .bin file. Copy the .bin file name.
    • Name example for bin: 4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin
    • Name example for zip: UQkNrGEQmaPvYbLmGseWkOkUCHDDkOBf.zip
  4. Go to the custom watch face and rename it using the name of the standard watch face.
  5. Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
  6. Open the Zepp (Amazfit)/Mifit app and install the stock watch face, which file you replaced.
Android apps
AmazFaces app
Gadgetbridge (Android)
Notify & Fitness for Amazfit (Android)
Amazfit Replacer (Android)
Installation for iOS
You may also use our application or other, such as AmazTools (iOS), to install watch faces
This manual is current at the time of writing.
If you notice any inaccuracies or mistakes, please, let us know.
Frank_MB
Post by Frank_MB »
Thank you for getting back to me. I am in developer mode and now more questions.
1. Does every watch face have a QR Code?
2. Where do I get the QR Code from your web site?
3. Do I have to ask the watchface designer make a QR Code?
4. How do you use the Zepp App to scan a QR code or can any QR Code app can be used?
Thank you again for all your help.
Frank_MB wrote: 14 Jan 2024, 10:28
1. Not every watch face comes with a QR code. QR codes are available for watch faces where direct installation through the Zepp app is supported.
2. You can find the QR code on the download page of a watch face on our website. If the watch face supports installation via QR code, you will see a 'QR Code' button near the download option.
3. You do not need to ask the watch face designer to create a QR code. The QR codes are generated automatically for supported watch faces on our site.
4. To scan a QR code, use the Zepp app in developer mode. While other QR code scanning apps can recognize the code, they won't facilitate the installation of the watch face on your device. Below each QR code on our site, you will find instructions on how to use the Zepp app for scanning and installing the watch face.
radrick01
Post by radrick01 »
I have android 12, how do I install it?
Chaboy
Post by Chaboy »
Hi, i have an iphone and the app version is 4.6.383.
my problem is, when I tried to download it and click on view ads, the ad does not show and thus preventing me to install the watchface.
can anyone help me? i have a GTR 47mm
Chaboy wrote: 08 Dec 2024, 12:12
viewtopic.php?t=1709
nklkhanna
Post by nklkhanna »
Hello guys, I'm new here. I recently bought Amazfit BIP 6 and was able to scan and install custom watch faces from this side 2 times. But now I'm unable to.
I took screenshot of the desired watchface and scanned it in developer mode, but I'm getting this error "Parse mini program package failed"
I tried going back to stock watchface and doing it again but still the same error.
I'm using samsung S22 running android 15 and zepp app version is 9.9.6.
Can you someone help and guide me? What m I doing wrong ?
Thanks 🙏
Been thanked: 2121 times
nklkhanna wrote: 27 Jul 2025, 05:24
Thanks 🙏
Here are some suggestions:
1. You should also mention which watch face you installed and had problems with.
2. It is recommended to post in the "Amazfit Bip series" forum
viewforum.php?f=6
According to the topic related to your problem.
3. Generating QR code for installation Once you generate it, the QR code will only be valid for a certain period of time and cannot be stored for long-term use. Therefore, if you have generated it for a long time, please refresh and re-generate it.
4. Since bip6 uses zeppOS to operate, if you want to see how to install it, please see the topic: "Create a QR Code and Sync to device that use zeppOS by using the Zepp app"
viewtopic.php?t=3873
nklkhanna
Post by nklkhanna »
asoo wrote: 27 Jul 2025, 09:28
Thanks 🙏
viewforum.php?f=6
Thanks for the reply and guidance, I'll try with fresh QR code and get back on the forum links you mentioned. 🙏🙂
icemanstrike
Post by icemanstrike »
Hello, I'm new here and wanted to know if I can download the files and use the assets file to watchface maker? I have the active 2 square.
icemanstrike wrote: 10 Nov 2025, 15:24
you can use "Watch face editor for Amazfit watch on ZeppOS"
viewtopic.php?t=2743
for unpack and bring image in assets to do that you want.
Next time, please post in an area that matches your question and device, for a more organized search.
Area for "Active device"
viewforum.php?f=176
icemanstrike
asoo wrote: 10 Nov 2025, 15:54
viewforum.php?f=176
Thanks for the link! I have an Active 2 and was trying to find square designs for it, but all I can see are circle designs in active device. I checked that GTS 3 and GTS 4 watch faces are compatible with the Active 2, which is why I downloaded the files for GTS. However, I’m not sure how to use the assets file.
icemanstrike wrote: 10 Nov 2025, 23:29
viewforum.php?f=176
Please post in the correct forum.
I told you earlier. It seems you don't care about what I said.
The image files in the assets folder are encrypted and cannot be used.
You must unpack with "Watch face editor for Amazfit watch on ZeppOS". When you unpack them, the files in the assets folder will be decrypted.
The program used to edit them is in the post I replied to you earlier.
Next time, if you post in the wrong forum, I won't reply.
Your question is not related to the main topic so your question
It will confuse this thread, because your question not related to this topic.
Fearless-Week
Post by Fearless-Week »
Got myself a Bip 6 and I was trying for hours to setup a custom skin. I did everything suggested and didnt worked, I just got this error : "Parse mini program package failed", every single time I scan a QR. The same error that nklkhanna already has.
If this matters, Im using Zepp v9.15.2. I was trying to find an older version but it was impossible to find, even I have tried to install an xAPK, didnt worked.
Fearless-Week wrote: 07 Jan 2026, 13:45
I think what you posted probably isn't relevant to this topic.
I suggest you check out this thread:
It might be helpful to you to some extent.
I also use Zepp V9.15.2 and was able to install the watchface on my Bip 6 via QR code without any problems.
I expect that if you follow the steps correctly, it should install successfully.
Fearless-Week
thanks asoo for your replying and Im sorry to bother you but... I did exactly what that link you posted since yesterday.
I think twice before making any post on any forum, if I cant find a way to do it by myself, I ask.
This is what I got
Fearless-Week wrote: 07 Jan 2026, 14:36
This is what I got
The problem you attached the image for can only be guessed to be caused by several things:
1. If you created the QR code yourself, it's possible that:
You created the zpk file incorrectly.
2. The server where you hosted the file is experiencing problems or does not support direct downloads.
If you used a QR code on this website, the problem may be due to:
1. The QR code has expired.
QR codes created on this website have a limited lifespan; you cannot save them for permanent use.
If it expires, you need to create a new one by refresh that page.
That's all I can answer for now. I will not answer this question further in this thread as it will confuse the main topic.
As I said before, your question should not be in this topic.
I have already provided a link to the correct topic. Please ask your question in that topic.
P.S. The entire problem analysis is based on the assumption that you need to understand the process of correctly creating a zpk file and understand how to host files on a server.
And in case you host files on this website, you must understand that the resulting QR code is not permanent.
Fearless-Week
No, that wasnt the problem at all, it wasnt an expired QR and it wasnt a zpk that I never created. Even more, I dont have any idea how to upload a zpk file to this device.
As I suspected its because of the version. So, this is what I did (to everyone who has the same problem as me): "Parse mini program package failed"
I downgraded to Zepp v9.8.2.
How did I did that?. I downloaded the apkm, de-compiled and then recompiled again. Uninstalled the previous version v9.15.2 and then I now can upload every skin from this device without any problems using any QR.
Fearless-Week wrote: 07 Jan 2026, 20:18
Congratulations on resolving the issue.
However, I'm still surprised because I'm also using Zepp Version 9.15.2 and was able to install it via QR code on Bip6 and Balance without any problems.
JAGGER
Has thanked: 11 times
Post by JAGGER »
Since the update to the new Zepp app v9.15.2, it no longer works for me either. I scan directly from the browser on the website. The scanner displays the error message: "parse mini program package failed". If I use the Amazface app, watch the ad, save the QR code, and then scan it directly on my phone, it works with the same watch face. Greetings from Germany
