Johnson070
Been thanked: 13 times
Post by Johnson070 »
Author
Johnson070
lvpokka
Tool description
  • All widgets support
  • Easy creation of watchfaces
  • Unpacking .bin
  • Support Mi Band 5
  • Support Mi Band 6
How to
2. Open MiBandWatchFaces.exe
4. Save file File => Save
Changelog
1.0.1.8 (2021-06-09)
- Fixed Circle Scale bug
- Fixed oneline date
- Fixed bug number size 0
1.0.1.2 (2021-04-22)
- Bug fixes
- (FIXED) Month/Date add
1.0.1.0 (2021-03-14)
Bug fixes
Add convert GIF to PNG frames
1.0.0.7 (2021-03-14)
  • Bug fixes
1.0.0.6 (2021-03-13)
  • Bug fixes
1.0.0.5 (2021-03-12)
  • Bug fix steps progress form
  • Fix circle scale form
  • Start work for languages
1.0.0.4 (2021-03-10)
1.0.0.3 (2021-03-10)
  • Bug fix status simple form
1.0.0.2 (2021-03-10)
1.0.0.1 (2021-03-09)
  • First release!
Screenshots
Support
https://paypal.me/j0hnson070
Download:
Click Assets
joaokit
Post by joaokit »
I'm having trouble turning the json file into bin, can someone help me?
Johnson070
Peoplehater wrote: 20 May 2021, 16:40
pepe pepon wrote: 15 May 2021, 12:50
I am getting a "Trojan:Win32/Zpevdo.B" warning from Windows Security
Same here :roll:
Problem because I include wininet,dll
Johnson070
1) bug with save bin file fix in 1.0.1.5
2) i don't understand why antivirus warning
lcyfer
Post by lcyfer »
Backdoor:Win32/Bladabindi!ml
lcyfer
Post by lcyfer »
Program:Win32/Wacapew.C!ml
Johnson070
Same here :roll:
Fixed in 1.0.1.6, because obfuscator
https://www.virustotal.com/gui/file/ce6 ... /detection
eve4bizz
Post by eve4bizz »
joaokit wrote: 21 May 2021, 00:22
Also can't export it as bin.
Is there anything I'm missing? Or is it a bug?
CASIONFAN2021
Post by CASIONFAN2021 »
i cant find the option to unpack bin file.. can someone help me. the program is missing this option, if i drag the bin file over to the .exe it does nothing at all.. it doesnt make a folder
CASIONFAN2021
Can anyone help please. Forum seems to bit a bit deaded. Private messages unanswered.
ntelas
Post by ntelas »
CASIONFAN2021 wrote: 12 Jun 2021, 19:01
Select file -> open, then on the window that appeared in the bottom right corner click "json watchface" and then select "packed bin file". Then open the file you want to unpack, and it should create a folder with the unpacked watchface!
karthik31
Post by karthik31 »
hello, after getting error while packing .json I saw log file it said 615kb max but my wf was 663kb, after searching this thread for solution I used Palette mode and It created a bin. I synced it to Band 5 but the Problem is Weather and Animation Icons( Blinking ":" icon between hours and minutes ex. 20:12) is also not working.
Weather elements I used
  • Temp Icon
    Temp
    Air pollution
    Humidity
    Wind
    UV Index
I synced that bin file to MI BAND 5 and I dont see any weather elements and animation elements working.
please help me: I am a newbie and tried to create this WF took me 4 whole days. It has all the elements I love.
KART_FINAL01_packed_packed.bin
(246.28 KiB) Downloaded 318 times
lcyfer
Post by lcyfer »
The bin file could not be created.
I could not create it with "save", "save as", or "save bin".
But when I did one thing, I was able to create a bin file.
I went to "Background", then "Generate previews", then "Save", and after the 0104.png file was created, the bin file was created and I could save it.
When the bin file could not be created, the 0104.png file was not there either.
Try deleting the image created and saved by "Background" and see if you can create and save a bin file.
errslima
Post by errslima »
Thanks for your tool, it's amazing!
I've designed the watch face that i want to use, but i can't figure out how to set the heart rate icons.
I can choose "Heart rate progress" and then there are 4 tabs, "scale", "line scale", "linear", and "add images".
What do these mean? What kind of images does it expect? Where should i upload the heart icon and where the images for the numbers?
nxdlxfb.,xfmfd
Post by nxdlxfb.,xfmfd »
Mi.Band.WatchFace.Editor\MiBandWatchFaces.exe
Gefunden: Trojan.GenericKD.46452556 (B)
ilneminis
Post by ilneminis »
Hello, thanks for the editor! I have Mi Band 6 and trying to translate some watchfaces but I, too, can not export the wf as .bin...
CASIONFAN2021
ive not managed to use this program at all as it should. i downloaded a bin file from here, that i know works on my Band 5 - i unpacked and just to check the program worked, i repacked it as a bin file and the bin file is not being created. ive tried running the program in administrator mode and that makes no difference, the first time i try and create a bin file the antivirus software goes nuts so i accept the program as safe and redo the procedure but it refuses to create the bin file, even though it says it has been created.
this program is not working.. please help
lcyfer
Post by lcyfer »
AhnLab-V3 Malware/Win.AGEN.C4476096
Alibaba Trojan:Win32/Generic.dcc53516
ALYac Gen:Variant.Bulz.508197
Arcabit Trojan.Bulz.D7C125
Avast Win32:Malware-gen
AVG Win32:Malware-gen
BitDefender Gen:Variant.Bulz.508197
Emsisoft Gen:Variant.Bulz.508197 (B)
FireEye Gen:Variant.Bulz.508197
GData Gen:Variant.Bulz.508197
MAX Malware (ai Score=86)
McAfee RDN/Generic.com
McAfee-GW-Edition RDN/Generic.dx
Sangfor Engine Zero Trojan.Win32.Generic.dx
TrendMicro-HouseCall TROJ_GEN.R002H06E121
This app is riddled with viruses.
We recommend that you stop using it immediately.
PsychoMatt
Post by PsychoMatt »
Hi
pls help me. i cant save bin file
raejin
Post by raejin »
Hi !! o/
I made a watch face but i can't create a .bin as the file is too big? I have 721kb of images total but log says file too big and will not be acepted? I've tried reducing my image size as much as I can but it isn't helping ;A;
I opened another user's watch face (from bin to json) with the program and tried to save as bin to see if i get the same error and I did
Fatal|[ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:2768kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:2768kb.
at IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.SjD0RiGg7(String )
raejin
Post by raejin »
update: I've managed to create a .bin by using 'pallette mode' and it writes okay. The only problem is now I can't install it to my Mi Band :? Using the Notify app I get update failed, im guessing the bin is faulty somehow
I'm really at a loss as to what to do now. Dropping a link here with the files if anyone could create a .bin and/or tell me how I'd be grateful ~
https://drive.google.com/drive/folders/ ... sp=sharing
lcyfer
Post by lcyfer »
Why do the authors of this app continue to leave the virus being detected?
Normally, if a virus is detected in an application that you have created, you will make every effort to avoid it.
But even with the latest version, viruses are still being detected.
Even if the virus detection is a false positive, there are many ways to avoid it.
I hope it will be improved as soon as possible.
juras13
Post by juras13 »
Language Česká Republika CZ?
my xyz
Post by my xyz »
Hello, AFTER unpacking bin, I only adjusted and modified the date. After the package was installed, the wristband did not show the date (week, month and day). If you change the date, even a single change, the date will not be displayed on the finger ring. What am I supposed to do now?
my xyz
Post by my xyz »
I tried to modify the date configuration in the json file, save it and install it on the bracelet, the date can be displayed normally. However, the date is modified through the editor, but it is not displayed after the installation is saved.
KrakeCZ
Post by KrakeCZ »
Weather not working after save as bin
