• 管理员
版面规则
头像
Johnson070
来自: Москва
Has thanked: 5 time
Been thanked: 13 time
联系:
帖子 Johnson070 »
Author
Johnson070
lvpokka
Tool description
  • All widgets support
  • Easy creation of watchfaces
  • Unpacking .bin
  • Support Mi Band 5
  • Support Mi Band 6
How to
2. Open MiBandWatchFaces.exe
4. Save file File => Save
Changelog
1.0.1.8 (2021-06-09)
- Fixed Circle Scale bug
- Fixed oneline date
- Fixed bug number size 0
1.0.1.2 (2021-04-22)
- Bug fixes
- (FIXED) Month/Date add
1.0.1.0 (2021-03-14)
Bug fixes
Add convert GIF to PNG frames
1.0.0.7 (2021-03-14)
  • Bug fixes
1.0.0.6 (2021-03-13)
  • Bug fixes
1.0.0.5 (2021-03-12)
  • Bug fix steps progress form
  • Fix circle scale form
  • Start work for languages
1.0.0.4 (2021-03-10)
1.0.0.3 (2021-03-10)
  • Bug fix status simple form
1.0.0.2 (2021-03-10)
1.0.0.1 (2021-03-09)
  • First release!
Screenshots
Support
https://paypal.me/j0hnson070
Download:
Click Assets
上次由 Johnson070 在 21 5月 2021, 17:35,总共编辑 6 次。
danyvas7
来自: Lima
联系:
帖子 danyvas7 »
Hi, i have a problem with the bin file, i save the project as bin, but the bin file is not created.
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
danyvas7 写了: 26 3月 2021, 22:08
Bin file creates in directory where created json and images
ElTioSTARK
来自: Tampico , Tamaulipas, México.
联系:
帖子 ElTioSTARK »
代码: 全选
System.NullReferenceException: Object reference not set to an instance of an object.
   at bgxp\]s^Mpx1SGtpFD/8D5~\.s$.‫‫‌‍‪​‏‮‍‎‬‎‫‫‍‌‪‬‮‫‍‎​‫‏‮(Object , EventArgs )
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
MiBand5WatchFaces
    Assembly Version: 1.0.1.0
    Win32 Version: 1.0.1.0
    CodeBase: file:///D:/Desktop/111/1qweqwe/MiBand5WatchFaces.exe
OZrdkKvfdujmPMMrgtotamxovFsE
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
mscorlib.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_es_b77a5c561934e089/mscorlib.resources.dll
eXBbWZhTwvdxOjhfnaqwKuToRNx
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
MiBand5WatchFaces.resources
Newtonsoft.Json
    Assembly Version: 12.0.0.0
    Win32 Version: 12.0.3.23909
    CodeBase: file:///D:/Desktop/111/1qweqwe/Newtonsoft.Json.DLL
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
    Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
enabled.
For example:
<configuration>
</configuration>
kazlaz
来自: China
Has thanked: 2 time
帖子 kazlaz »
It's awesome!the "panda" watchface is unzipped successfully,Thank you so much!
kazlaz
来自: China
Has thanked: 2 time
帖子 kazlaz »
Looking forward to the watch face editor of Mi Band 6
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
I start working version for mi band 6
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
ElTioSTARK 写了: 07 4月 2021, 20:38
mscorlib
MiBand5WatchFaces
System
System.Drawing
mscorlib.resources
System.Core
System.Xml
Newtonsoft.Json
System.Numerics
System.Data
enabled.
For example:
<configuration>
</configuration>
I fix in next update, thanks very much. I find bug
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
头像
Wagner669
来自: Athens
Has thanked: 2 time
联系:
帖子 Wagner669 »
Hi!
Thank you for the great WF-tool!
I have a question about the "Status" indicators
I select a png for the BT ON and a png for the BT OFF
Compile the .bin and install the watchface on my MB5
When the BT is connected, the BT-OFF png appears
When the BT is disconnected, the BT-ON png appears
What am I doing wrong???
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
Wagner669 写了: 21 4月 2021, 13:21
Hi!
Hello, BT-off append when bluetooth not connected
yaoun
来自: France
Has thanked: 3 time
联系:
帖子 yaoun »
Thanks a lot
头像
Wagner669
来自: Athens
Has thanked: 2 time
联系:
帖子 Wagner669 »
I think I found a bug
The weekday shown in preview is wrong, showing the next weekday
I set the date to current day (Monday April 26th) and the preview shows the next week day, Tuesday
The weekday settings in .json appear to be correct
I haven't tried to compile the watchface to .bin in order to see if the bug appears only in preview or if it is also transfered to final watchface
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
Wagner669 写了: 26 4月 2021, 12:28
Thanks, I fix in 1.0.1.4 update
buraklarca
来自: istanbul
Has thanked: 2 time
联系:
帖子 buraklarca »
Hello there. I just started using the program. I made editing for 1 theme with Turkish language support, but when saving, it does not save the .bin file. The .bin file does not appear. Mi Band 6
代码: 全选
Debug|Reading config...
Debug|Reading referenced images from 'C:\Users\burak\Desktop\Yeni klasör'
Trace|Loading resources for 2 'Background'
Trace|Loading resources for 2.1 'ImageBasic'
Trace|Loading image 0...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0000.png
Trace|Loading resources for 3 'Time'
Trace|Loading resources for 3.1 'TwoDigits'
Trace|Loading resources for 3.1.1 'ImageSet'
Trace|Loading image 1...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0001.png
Trace|Loading image 2...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0002.png
Trace|Loading image 3...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0003.png
Trace|Loading image 4...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0004.png
Trace|Loading image 5...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0005.png
Trace|Loading image 6...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0006.png
Trace|Loading image 7...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0007.png
Trace|Loading image 8...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0008.png
Trace|Loading image 9...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0009.png
Trace|Loading image 10...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0010.png
Trace|Loading resources for 3.1.2 'ImageSet'
Trace|Loading resources for 3.2 'TwoDigits'
Trace|Loading resources for 3.2.1 'ImageSet'
Trace|Loading resources for 3.2.2 'ImageSet'
Trace|Loading resources for 4 'Activity'
Trace|Loading resources for 4.1 'Steps'
Trace|Loading resources for 4.1.1 'Number'
Trace|Loading resources for 4.1.1.5 'TextAlignment'
Trace|Loading image 21...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0021.png
Trace|Loading image 22...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0022.png
Trace|Loading image 23...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0023.png
Trace|Loading image 24...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0024.png
Trace|Loading image 25...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0025.png
Trace|Loading image 26...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0026.png
Trace|Loading image 27...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0027.png
Trace|Loading image 28...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0028.png
Trace|Loading image 29...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0029.png
Trace|Loading image 30...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0030.png
Trace|Loading resources for 4.4 'PulseWrapper'
Trace|Loading resources for 4.4.1 'Number'
Trace|Loading resources for 4.4.1.5 'TextAlignment'
Trace|Loading image 11...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0011.png
Trace|Loading image 12...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0012.png
Trace|Loading image 13...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0013.png
Trace|Loading image 14...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0014.png
Trace|Loading image 15...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0015.png
Trace|Loading image 16...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0016.png
Trace|Loading image 17...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0017.png
Trace|Loading image 18...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0018.png
Trace|Loading image 19...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0019.png
Trace|Loading image 20...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0020.png
Trace|Loading image 32...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0032.png
Trace|Loading resources for 5 'Date'
Trace|Loading resources for 5.1 'MonthAndDayAndYear'
Trace|Loading resources for 5.1.1 'SeparateMonthAndDay'
Trace|Loading resources for 5.1.1.4 'Number'
Trace|Loading resources for 5.1.1.4.5 'TextAlignment'
Trace|Loading resources for 5.1.4 'Boolean'
Trace|Loading resources for 5.1.5 'Boolean'
Trace|Loading resources for 5.4 'ImageSet'
Trace|Loading image 73...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0073.png
Trace|Loading image 74...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0074.png
Trace|Loading image 75...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0075.png
Trace|Loading image 76...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0076.png
Trace|Loading image 77...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0077.png
Trace|Loading image 78...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0078.png
Trace|Loading image 79...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0079.png
Trace|Loading resources for 6 'Weather'
Trace|Loading resources for 6.1 'WeatherIcon'
Trace|Loading resources for 6.1.2 'CustomWeatherIcon'
Trace|Loading image 80...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0080.png
Trace|Loading image 81...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0081.png
Trace|Loading image 82...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0082.png
Trace|Loading image 83...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0083.png
Trace|Loading image 84...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0084.png
Trace|Loading image 85...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0085.png
Trace|Loading image 86...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0086.png
Trace|Loading image 87...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0087.png
Trace|Loading image 88...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0088.png
Trace|Loading image 89...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0089.png
Trace|Loading image 90...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0090.png
Trace|Loading image 91...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0091.png
Trace|Loading image 92...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0092.png
Trace|Loading image 93...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0093.png
Trace|Loading image 94...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0094.png
Trace|Loading image 95...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0095.png
Trace|Loading image 96...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0096.png
Trace|Loading image 97...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0097.png
Trace|Loading image 98...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0098.png
Trace|Loading image 99...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0099.png
Trace|Loading image 100...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0100.png
Trace|Loading image 101...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0101.png
Trace|Loading image 102...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0102.png
Trace|Loading image 103...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0103.png
Trace|Loading image 104...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0104.png
Trace|Loading image 105...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0105.png
Trace|Loading resources for 6.1.3 'XY'
Trace|Loading resources for 6.1.4 'XY'
Trace|Loading resources for 6.2 'Temperature'
Trace|Loading resources for 6.2.1 'TemperatureNumber'
Trace|Loading resources for 6.2.1.1 'Number'
Trace|Loading resources for 6.2.1.1.5 'TextAlignment'
Trace|Loading image 106...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0106.png
Trace|Loading image 31...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0031.png
Trace|Loading resources for 7 'StepsProgress'
Trace|Loading resources for 7.2 'LineScale'
Trace|Loading image 33...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0033.png
Trace|Loading image 34...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0034.png
Trace|Loading image 35...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0035.png
Trace|Loading image 36...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0036.png
Trace|Loading image 37...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0037.png
Trace|Loading image 38...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0038.png
Trace|Loading image 39...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0039.png
Trace|Loading image 40...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0040.png
Trace|Loading image 41...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0041.png
Trace|Loading image 42...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0042.png
Trace|Loading image 43...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0043.png
Trace|Loading image 44...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0044.png
Trace|Loading image 45...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0045.png
Trace|Loading image 46...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0046.png
Trace|Loading image 47...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0047.png
Trace|Loading image 48...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0048.png
Trace|Loading image 49...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0049.png
Trace|Loading image 50...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0050.png
Trace|Loading image 51...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0051.png
Trace|Loading image 52...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0052.png
Trace|Loading image 53...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0053.png
Trace|Loading image 54...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0054.png
Trace|Loading image 55...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0055.png
Trace|Loading image 56...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0056.png
Trace|Loading image 57...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0057.png
Trace|Loading image 58...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0058.png
Trace|Loading image 59...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0059.png
Trace|Loading image 60...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0060.png
Trace|Loading image 61...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0061.png
Trace|Loading image 62...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0062.png
Trace|Loading image 63...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0063.png
Trace|Loading image 64...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0064.png
Trace|Loading image 65...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0065.png
Trace|Loading image 66...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0066.png
Trace|Loading image 67...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0067.png
Trace|Loading image 68...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0068.png
Trace|Loading image 69...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0069.png
Trace|Loading image 70...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0070.png
Trace|Loading image 71...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0071.png
Trace|Loading image 72...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0072.png
Trace|Loading resources for 8 'Status'
Trace|Loading resources for 8.1 'Switch'
Trace|Loading resources for 8.1.1 'XY'
Trace|Loading image 109...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0109.png
Trace|Loading image 108...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0108.png
Trace|Loading resources for 8.3 'Switch'
Trace|Loading resources for 8.3.1 'XY'
Trace|Loading image 107...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0107.png
Trace|Loading resources for 9 'Battery'
Trace|Loading resources for 9.2 'ImageSet'
Trace|Loading image 110...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0110.png
Trace|Loading image 111...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0111.png
Trace|Loading image 112...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0112.png
Trace|Loading image 113...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0113.png
Trace|Loading image 114...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0114.png
Trace|Loading image 115...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0115.png
Trace|Loading image 116...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0116.png
Trace|Loading image 117...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0117.png
Trace|Loading image 118...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0118.png
Trace|Loading image 119...
Trace|Image was loaded from file C:\Users\burak\Desktop\Yeni klasör\0119.png
Trace|Verifiying Resources...
Trace|Building parameters for watch face...
Trace|2.1.1 'X': 0
Trace|2.1.2 'Y': -2
Trace|2.1.3 'ImageIndex': 0
Trace|2.1 'Image'
Trace|2 'Background'
Trace|3.1.1.1 'X': 26
Trace|3.1.1.2 'Y': 162
Trace|3.1.1.3 'ImageIndex': 1
Trace|3.1.1.4 'ImagesCount': 10
Trace|3.1.1 'Tens'
Trace|3.1.2.1 'X': 76
Trace|3.1.2.2 'Y': 162
Trace|3.1.2.3 'ImageIndex': 1
Trace|3.1.2.4 'ImagesCount': 10
Trace|3.1.2 'Ones'
Trace|3.1 'Hours'
Trace|3.2.1.1 'X': 26
Trace|3.2.1.2 'Y': 247
Trace|3.2.1.3 'ImageIndex': 1
Trace|3.2.1.4 'ImagesCount': 10
Trace|3.2.1 'Tens'
Trace|3.2.2.1 'X': 76
Trace|3.2.2.2 'Y': 247
Trace|3.2.2.3 'ImageIndex': 1
Trace|3.2.2.4 'ImagesCount': 10
Trace|3.2.2 'Ones'
Trace|3.2 'Minutes'
Trace|3.11 'UnknownV11': 0
Trace|3 'Time'
Trace|4.1.1.1 'TopLeftX': 51
Trace|4.1.1.2 'TopLeftY': 56
Trace|4.1.1.3 'BottomRightX': 101
Trace|4.1.1.4 'BottomRightY': 70
Trace|4.1.1.5 'Alignment': 72
Trace|4.1.1.6 'SpacingX': 0
Trace|4.1.1.7 'SpacingY': 0
Trace|4.1.1.8 'ImageIndex': 21
Trace|4.1.1.9 'ImagesCount': 10
Trace|4.1.1 'Number'
Trace|4.1 'Steps'
Trace|4.4.1.1 'TopLeftX': 36
Trace|4.4.1.2 'TopLeftY': 102
Trace|4.4.1.3 'BottomRightX': 116
Trace|4.4.1.4 'BottomRightY': 127
Trace|4.4.1.5 'Alignment': 72
Trace|4.4.1.6 'SpacingX': 0
Trace|4.4.1.7 'SpacingY': 0
Trace|4.4.1.8 'ImageIndex': 11
Trace|4.4.1.9 'ImagesCount': 10
Trace|4.4.1 'Number'
Trace|4.4.2 'PrefixImageIndex': 32
Trace|4.4 'Pulse'
Trace|4.7 'UnknownV7': 0
Trace|4 'Activity'
Trace|5.1.1.4.1 'TopLeftX': 33
Trace|5.1.1.4.2 'TopLeftY': 334
Trace|5.1.1.4.3 'BottomRightX': 65
Trace|5.1.1.4.4 'BottomRightY': 357
Trace|5.1.1.4.5 'Alignment': 72
Trace|5.1.1.4.6 'SpacingX': 0
Trace|5.1.1.4.7 'SpacingY': 0
Trace|5.1.1.4.8 'ImageIndex': 11
Trace|5.1.1.4.9 'ImagesCount': 10
Trace|5.1.1.4 'Day'
Trace|5.1.1 'Separate'
Trace|5.1.4 'TwoDigitsMonth': 1
Trace|5.1.5 'TwoDigitsDay': 1
Trace|5.1 'MonthAndDayAndYear'
Trace|5.4.1 'X': 75
Trace|5.4.2 'Y': 334
Trace|5.4.3 'ImageIndex': 73
Trace|5.4.4 'ImagesCount': 7
Trace|5.4 'ENWeekDays'
Trace|5 'Date'
Trace|6.1.2.1 'X': 31
Trace|6.1.2.2 'Y': 390
Trace|6.1.2.3 'ImageIndex': 80
Trace|6.1.2.4 'ImagesCount': 26
Trace|6.1.2 'CustomIcon'
Trace|6.1.3.1 'X': 31
Trace|6.1.3.2 'Y': 390
Trace|6.1.3 'Unknown3'
Trace|6.1.4.1 'X': 31
Trace|6.1.4.2 'Y': 390
Trace|6.1.4 'Unknown4'
Trace|6.1 'Icon'
Trace|6.2.1.1.1 'TopLeftX': 65
Trace|6.2.1.1.2 'TopLeftY': 399
Trace|6.2.1.1.3 'BottomRightX': 135
Trace|6.2.1.1.4 'BottomRightY': 422
Trace|6.2.1.1.5 'Alignment': 72
Trace|6.2.1.1.6 'SpacingX': 0
Trace|6.2.1.1.7 'SpacingY': 0
Trace|6.2.1.1.8 'ImageIndex': 11
Trace|6.2.1.1.9 'ImagesCount': 10
Trace|6.2.1.1 'Number'
Trace|6.2.1.2 'MinusImageIndex': 106
Trace|6.2.1.3 'DegreesImageIndex': 31
Trace|6.2.1 'Current'
Trace|6.2 'Temperature'
Trace|6 'Weather'
Trace|7.2.1 'X': 5
Trace|7.2.2 'Y': 34
Trace|7.2.3 'ImageIndex': 33
Trace|7.2.4 'ImagesCount': 40
Trace|7.2 'LineScale'
Trace|7 'StepsProgress'
Trace|8.1.1.1 'X': 48
Trace|8.1.1.2 'Y': 6
Trace|8.1.1 'Coordinates'
Trace|8.1.2 'ImageIndexOn': 109
Trace|8.1.3 'ImageIndexOff': 108
Trace|8.1 'DoNotDisturb'
Trace|8.3.1.1 'X': 88
Trace|8.3.1.2 'Y': 6
Trace|8.3.1 'Coordinates'
Trace|8.3.2 'ImageIndexOn': 108
Trace|8.3.3 'ImageIndexOff': 107
Trace|8.3 'Bluetooth'
Trace|8 'Status'
Trace|9.2.1 'X': 68
Trace|9.2.2 'Y': 6
Trace|9.2.3 'ImageIndex': 110
Trace|9.2.4 'ImagesCount': 10
Trace|9.2 'BatteryIcon'
Trace|9 'Battery'
Debug|Generating previews...
Debug|Writing watch face to 'C:\Users\burak\Desktop\Yeni klasör\Yeni klasör_packed.bin'
Trace|Encoding parameters...
Trace|Parameter: 2
Trace|1 (0A):
Trace|    1 (08): 0 (00)
Trace|    2 (10): -2 (FFFFFFFFFFFFFFFE)
Trace|    3 (18): 0 (00)
Trace|17 bytes
Trace|Parameter: 3
Trace|1 (0A):
Trace|    1 (0A):
Trace|        1 (08): 26 (1A)
Trace|        2 (10): 162 (A2)
Trace|        3 (18): 1 (01)
Trace|        4 (20): 10 (0A)
Trace|    11 bytes
Trace|    2 (12):
Trace|        1 (08): 76 (4C)
Trace|    11 bytes
Trace|24 bytes
Trace|2 (12):
Trace|    1 (0A):
Trace|        2 (10): 247 (F7)
Trace|    11 bytes
Trace|    2 (12):
Trace|    11 bytes
Trace|24 bytes
Trace|11 (58): 0 (00)
Trace|Parameter: 4
Trace|1 (0A):
Trace|    1 (0A):
Trace|        1 (08): 51 (33)
Trace|        2 (10): 56 (38)
Trace|        3 (18): 101 (65)
Trace|        4 (20): 70 (46)
Trace|        5 (28): 72 (48)
Trace|        6 (30): 0 (00)
Trace|        7 (38): 0 (00)
Trace|        8 (40): 21 (15)
Trace|        9 (48): 10 (0A)
Trace|    20 bytes
Trace|22 bytes
Trace|4 (22):
Trace|    1 (0A):
Trace|        1 (08): 36 (24)
Trace|        2 (10): 102 (66)
Trace|        3 (18): 116 (74)
Trace|        4 (20): 127 (7F)
Trace|        8 (40): 11 (0B)
Trace|    20 bytes
Trace|    2 (10): 32 (20)
Trace|24 bytes
Trace|7 (38): 0 (00)
Trace|Parameter: 5
Trace|1 (0A):
Trace|    1 (0A):
Trace|        4 (22):
Trace|            1 (08): 33 (21)
Trace|            2 (10): 334 (14E)
Trace|            3 (18): 65 (41)
Trace|            4 (20): 357 (165)
Trace|        22 bytes
Trace|    24 bytes
Trace|    4 (20): 1 (01)
Trace|    5 (28): 1 (01)
Trace|30 bytes
Trace|4 (22):
Trace|    1 (08): 75 (4B)
Trace|    3 (18): 73 (49)
Trace|    4 (20): 7 (07)
Trace|11 bytes
Trace|Parameter: 6
Trace|1 (0A):
Trace|    2 (12):
Trace|        1 (08): 31 (1F)
Trace|        2 (10): 390 (186)
Trace|        3 (18): 80 (50)
Trace|        4 (20): 26 (1A)
Trace|    11 bytes
Trace|    3 (1A):
Trace|    7 bytes
Trace|    4 (22):
Trace|    7 bytes
Trace|27 bytes
Trace|2 (12):
Trace|    1 (0A):
Trace|        1 (0A):
Trace|            1 (08): 65 (41)
Trace|            2 (10): 399 (18F)
Trace|            3 (18): 135 (87)
Trace|            4 (20): 422 (1A6)
Trace|        23 bytes
Trace|        2 (10): 106 (6A)
Trace|        3 (18): 31 (1F)
Trace|    29 bytes
Trace|31 bytes
Trace|Parameter: 7
Trace|2 (12):
Trace|    1 (08): 5 (05)
Trace|    2 (10): 34 (22)
Trace|    3 (18): 33 (21)
Trace|    4 (20): 40 (28)
Trace|10 bytes
Trace|Parameter: 8
Trace|1 (0A):
Trace|    1 (0A):
Trace|        1 (08): 48 (30)
Trace|        2 (10): 6 (06)
Trace|    6 bytes
Trace|    2 (10): 109 (6D)
Trace|    3 (18): 108 (6C)
Trace|12 bytes
Trace|3 (1A):
Trace|    1 (0A):
Trace|        1 (08): 88 (58)
Trace|    6 bytes
Trace|    2 (10): 108 (6C)
Trace|    3 (18): 107 (6B)
Trace|12 bytes
Trace|Parameter: 9
Trace|2 (12):
Trace|    1 (08): 68 (44)
Trace|    3 (18): 110 (6E)
Trace|10 bytes
Trace|Encoding offsets and lengths...
Trace|1 (0A):
Trace|    1 (08): 258 (102)
Trace|    2 (10): 120 (78)
Trace|7 bytes
Trace|2 (12):
Trace|    2 (10): 17 (11)
Trace|6 bytes
Trace|3 (1A):
Trace|    1 (08): 17 (11)
Trace|    2 (10): 50 (32)
Trace|6 bytes
Trace|4 (22):
Trace|    1 (08): 67 (43)
Trace|    2 (10): 48 (30)
Trace|6 bytes
Trace|5 (2A):
Trace|    1 (08): 115 (73)
Trace|    2 (10): 41 (29)
Trace|6 bytes
Trace|6 (32):
Trace|    1 (08): 156 (9C)
Trace|    2 (10): 58 (3A)
Trace|7 bytes
Trace|7 (3A):
Trace|    1 (08): 214 (D6)
Trace|    2 (10): 10 (0A)
Trace|7 bytes
Trace|8 (42):
Trace|    1 (08): 224 (E0)
Trace|    2 (10): 24 (18)
Trace|7 bytes
Trace|9 (4A):
Trace|    1 (08): 248 (F8)
Trace|7 bytes
Trace|Writing header...
Trace|Writing parameters offsets and lengths...
Trace|Writing parameters...
Trace|Writing images...
Trace|Resource 0 offset is 0...
Debug|Encoding resource 0...
Trace|Writing image in Raw mode
Trace|No Transparency image...
Trace|Writing image header...
Trace|Width: 152, Height: 486, RowLength: 304
Trace|BPP: 16, PaletteColors: 0, Transaparency: 0
Trace|Writing image...
Trace|Resource 1 offset is 147760...
Debug|Encoding resource 1...
Trace|Transparency image...
Trace|Width: 50, Height: 67, RowLength: 150
Trace|BPP: 24, PaletteColors: 0, Transaparency: 0
Trace|Resource 2 offset is 157826...
Debug|Encoding resource 2...
Trace|Resource 3 offset is 167892...
Debug|Encoding resource 3...
Trace|Resource 4 offset is 177958...
Debug|Encoding resource 4...
Trace|Resource 5 offset is 188024...
Debug|Encoding resource 5...
Trace|Resource 6 offset is 198090...
Debug|Encoding resource 6...
Trace|Resource 7 offset is 208156...
Debug|Encoding resource 7...
Trace|Resource 8 offset is 218222...
Debug|Encoding resource 8...
Trace|Resource 9 offset is 228288...
Debug|Encoding resource 9...
Trace|Resource 10 offset is 238354...
Debug|Encoding resource 10...
Trace|Resource 11 offset is 248420...
Debug|Encoding resource 11...
Trace|Width: 16, Height: 23, RowLength: 48
Trace|Resource 12 offset is 249540...
Debug|Encoding resource 12...
Trace|Resource 13 offset is 250660...
Debug|Encoding resource 13...
Trace|Resource 14 offset is 251780...
Debug|Encoding resource 14...
Trace|Resource 15 offset is 252900...
Debug|Encoding resource 15...
Trace|Resource 16 offset is 254020...
Debug|Encoding resource 16...
Trace|Resource 17 offset is 255140...
Debug|Encoding resource 17...
Trace|Resource 18 offset is 256260...
Debug|Encoding resource 18...
Trace|Resource 19 offset is 257380...
Debug|Encoding resource 19...
Trace|Resource 20 offset is 258500...
Debug|Encoding resource 20...
Trace|Resource 21 offset is 259620...
Debug|Encoding resource 21...
Trace|Width: 10, Height: 14, RowLength: 30
Trace|Resource 22 offset is 260056...
Debug|Encoding resource 22...
Trace|Resource 23 offset is 260492...
Debug|Encoding resource 23...
Trace|Resource 24 offset is 260928...
Debug|Encoding resource 24...
Trace|Resource 25 offset is 261364...
Debug|Encoding resource 25...
Trace|Resource 26 offset is 261800...
Debug|Encoding resource 26...
Trace|Resource 27 offset is 262236...
Debug|Encoding resource 27...
Trace|Resource 28 offset is 262672...
Debug|Encoding resource 28...
Trace|Resource 29 offset is 263108...
Debug|Encoding resource 29...
Trace|Resource 30 offset is 263544...
Debug|Encoding resource 30...
Trace|Resource 31 offset is 263980...
Debug|Encoding resource 31...
Trace|Width: 12, Height: 23, RowLength: 36
Trace|Resource 32 offset is 264824...
Debug|Encoding resource 32...
Trace|Width: 34, Height: 25, RowLength: 102
Trace|Resource 33 offset is 267390...
Debug|Encoding resource 33...
Trace|Width: 142, Height: 17, RowLength: 426
Trace|Resource 34 offset is 274648...
Debug|Encoding resource 34...
Trace|Width: 142, Height: 34, RowLength: 426
Trace|Resource 35 offset is 289148...
Debug|Encoding resource 35...
Trace|Width: 142, Height: 57, RowLength: 426
Trace|Resource 36 offset is 313446...
Debug|Encoding resource 36...
Trace|Width: 142, Height: 82, RowLength: 426
Trace|Resource 37 offset is 348394...
Debug|Encoding resource 37...
Trace|Width: 142, Height: 107, RowLength: 426
Trace|Resource 38 offset is 393992...
Debug|Encoding resource 38...
Trace|Width: 142, Height: 133, RowLength: 426
Trace|Resource 39 offset is 450666...
Debug|Encoding resource 39...
Trace|Width: 142, Height: 158, RowLength: 426
Trace|Resource 40 offset is 517990...
Debug|Encoding resource 40...
Trace|Width: 142, Height: 184, RowLength: 426
Trace|Resource 41 offset is 596390...
Debug|Encoding resource 41...
Trace|Width: 142, Height: 209, RowLength: 426
Trace|Resource 42 offset is 685440...
Debug|Encoding resource 42...
Trace|Width: 142, Height: 235, RowLength: 426
Trace|Resource 43 offset is 785566...
Debug|Encoding resource 43...
Trace|Width: 142, Height: 260, RowLength: 426
Trace|Resource 44 offset is 896342...
Debug|Encoding resource 44...
Trace|Width: 142, Height: 286, RowLength: 426
Trace|Resource 45 offset is 1018194...
Debug|Encoding resource 45...
Trace|Width: 142, Height: 311, RowLength: 426
Trace|Resource 46 offset is 1150696...
Debug|Encoding resource 46...
Trace|Width: 142, Height: 337, RowLength: 426
Trace|Resource 47 offset is 1294274...
Debug|Encoding resource 47...
Trace|Width: 142, Height: 362, RowLength: 426
Trace|Resource 48 offset is 1448502...
Debug|Encoding resource 48...
Trace|Width: 142, Height: 388, RowLength: 426
Trace|Resource 49 offset is 1613806...
Debug|Encoding resource 49...
Trace|Width: 142, Height: 412, RowLength: 426
Trace|Resource 50 offset is 1789334...
Debug|Encoding resource 50...
Trace|Width: 142, Height: 432, RowLength: 426
Trace|Resource 51 offset is 1973382...
Debug|Encoding resource 51...
Trace|Width: 142, Height: 445, RowLength: 426
Trace|Resource 52 offset is 2162968...
Debug|Encoding resource 52...
Trace|Width: 142, Height: 449, RowLength: 426
Trace|Resource 53 offset is 2354258...
Debug|Encoding resource 53...
Trace|Resource 54 offset is 2545548...
Debug|Encoding resource 54...
Trace|Resource 55 offset is 2736838...
Debug|Encoding resource 55...
Trace|Resource 56 offset is 2928128...
Debug|Encoding resource 56...
Trace|Resource 57 offset is 3119418...
Debug|Encoding resource 57...
Trace|Resource 58 offset is 3310708...
Debug|Encoding resource 58...
Trace|Resource 59 offset is 3501998...
Debug|Encoding resource 59...
Trace|Resource 60 offset is 3693288...
Debug|Encoding resource 60...
Trace|Resource 61 offset is 3884578...
Debug|Encoding resource 61...
Trace|Resource 62 offset is 4075868...
Debug|Encoding resource 62...
Trace|Resource 63 offset is 4267158...
Debug|Encoding resource 63...
Trace|Resource 64 offset is 4458448...
Debug|Encoding resource 64...
Trace|Resource 65 offset is 4649738...
Debug|Encoding resource 65...
Trace|Resource 66 offset is 4841028...
Debug|Encoding resource 66...
Trace|Resource 67 offset is 5032318...
Debug|Encoding resource 67...
Trace|Resource 68 offset is 5223608...
Debug|Encoding resource 68...
Trace|Resource 69 offset is 5414898...
Debug|Encoding resource 69...
Trace|Resource 70 offset is 5606188...
Debug|Encoding resource 70...
Trace|Resource 71 offset is 5797478...
Debug|Encoding resource 71...
Trace|Resource 72 offset is 5988768...
Debug|Encoding resource 72...
Trace|Resource 73 offset is 6180058...
Debug|Encoding resource 73...
Trace|Width: 50, Height: 23, RowLength: 150
Trace|Resource 74 offset is 6183524...
Debug|Encoding resource 74...
Trace|Resource 75 offset is 6186990...
Debug|Encoding resource 75...
Trace|Resource 76 offset is 6190456...
Debug|Encoding resource 76...
Trace|Resource 77 offset is 6193922...
Debug|Encoding resource 77...
Trace|Resource 78 offset is 6197388...
Debug|Encoding resource 78...
Trace|Resource 79 offset is 6200854...
Debug|Encoding resource 79...
Trace|Resource 80 offset is 6204320...
Debug|Encoding resource 80...
Trace|Width: 40, Height: 40, RowLength: 120
Trace|Resource 81 offset is 6209136...
Debug|Encoding resource 81...
Trace|Resource 82 offset is 6213952...
Debug|Encoding resource 82...
Trace|Resource 83 offset is 6218768...
Debug|Encoding resource 83...
Trace|Resource 84 offset is 6223584...
Debug|Encoding resource 84...
Trace|Resource 85 offset is 6228400...
Debug|Encoding resource 85...
Trace|Resource 86 offset is 6233216...
Debug|Encoding resource 86...
Trace|Resource 87 offset is 6238032...
Debug|Encoding resource 87...
Trace|Resource 88 offset is 6242848...
Debug|Encoding resource 88...
Trace|Resource 89 offset is 6247664...
Debug|Encoding resource 89...
Trace|Resource 90 offset is 6252480...
Debug|Encoding resource 90...
Trace|Resource 91 offset is 6257296...
Debug|Encoding resource 91...
Trace|Resource 92 offset is 6262112...
Debug|Encoding resource 92...
Trace|Resource 93 offset is 6266928...
Debug|Encoding resource 93...
Trace|Resource 94 offset is 6271744...
Debug|Encoding resource 94...
Trace|Resource 95 offset is 6276560...
Debug|Encoding resource 95...
Trace|Resource 96 offset is 6281376...
Debug|Encoding resource 96...
Trace|Resource 97 offset is 6286192...
Debug|Encoding resource 97...
Trace|Resource 98 offset is 6291008...
Debug|Encoding resource 98...
Trace|Resource 99 offset is 6295824...
Debug|Encoding resource 99...
Trace|Resource 100 offset is 6300640...
Debug|Encoding resource 100...
Trace|Resource 101 offset is 6305456...
Debug|Encoding resource 101...
Trace|Resource 102 offset is 6310272...
Debug|Encoding resource 102...
Trace|Resource 103 offset is 6315088...
Debug|Encoding resource 103...
Trace|Resource 104 offset is 6319904...
Debug|Encoding resource 104...
Trace|Resource 105 offset is 6324720...
Debug|Encoding resource 105...
Trace|Resource 106 offset is 6329536...
Debug|Encoding resource 106...
Trace|Width: 10, Height: 23, RowLength: 30
Trace|Resource 107 offset is 6330242...
Debug|Encoding resource 107...
Trace|Width: 16, Height: 16, RowLength: 48
Trace|Resource 108 offset is 6331026...
Debug|Encoding resource 108...
Trace|Resource 109 offset is 6331810...
Debug|Encoding resource 109...
Trace|Resource 110 offset is 6332594...
Debug|Encoding resource 110...
Trace|Resource 111 offset is 6333378...
Debug|Encoding resource 111...
Trace|Resource 112 offset is 6334162...
Debug|Encoding resource 112...
Trace|Resource 113 offset is 6334946...
Debug|Encoding resource 113...
Trace|Resource 114 offset is 6335730...
Debug|Encoding resource 114...
Trace|Resource 115 offset is 6336514...
Debug|Encoding resource 115...
Trace|Resource 116 offset is 6337298...
Debug|Encoding resource 116...
Trace|Resource 117 offset is 6338082...
Debug|Encoding resource 117...
Trace|Resource 118 offset is 6338866...
Debug|Encoding resource 118...
Trace|Resource 119 offset is 6339650...
Debug|Encoding resource 119...
Trace|Writing resources offsets table
Debug|Writing resources
Fatal|[ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:6192kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 1300kb, it will not be accepted by Mi Band 6, please reduce size! Current size:6192kb.
   konum: IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.SjD0RiGg7(String  )
   konum: IvAgHVd4mYbL19b0oG.BhU54AsmePbEYl5b7h.WQxOdqmcX(String[]  )
lvpokka
来自: L1
Has thanked: 19 time
Been thanked: 152 time
联系:
帖子 lvpokka »
buraklarca read last line in your log file)
p.s use palette mode
lucsus
来自: Brasil
联系:
帖子 lucsus »
I'm having the same usue. The problem is: I had create a bin file in the previous version without problem. This time I only modified the space between pai values, nothing else, and started having this problem.
Can't even save the old version, unmodified, of the watchface.
lvpokka 写了: 03 5月 2021, 15:11
@buraklarca read last line in your log file)
buraklarca
来自: istanbul
Has thanked: 2 time
联系:
帖子 buraklarca »
hopefully this problem will be fixed soon.
lucsus 写了: 03 5月 2021, 15:30
lvpokka
来自: L1
联系:
帖子 lvpokka »
Its not a problem, there is watchface size limit, read logs...
use palette mode!
lucsus
来自: Brasil
联系:
帖子 lucsus »
lvpokka 写了: 04 5月 2021, 00:04
use palette mode!
What exactly palette mode does? I'm currently unable to turn it on. It gives me the following error:
代码: 全选
[i]************** Exception Text **************
  at MiBand5WatchFaces.Forms.SettingsForm.RosJE9BgaH (System.Object  , System.EventArgs  ) [0x000c8] in <d09a9990ec954c28bd3ef4674fa2f33b>:0
  at System.Windows.Forms.Control.OnClick (System.EventArgs e) [0x0001f] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Button.OnClick (System.EventArgs e) [0x00037] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Button.OnMouseUp (System.Windows.Forms.MouseEventArgs mevent) [0x0009a] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control.WmMouseUp (System.Windows.Forms.Message& m, System.Windows.Forms.MouseButtons button, System.Int32 clicks) [0x001c3] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x005a0] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.ButtonBase.WndProc (System.Windows.Forms.Message& m) [0x0011f] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Button.WndProc (System.Windows.Forms.Message& m) [0x00056] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control+ControlNativeWindow.OnMessage (System.Windows.Forms.Message& m) [0x00001] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x000b3] in <05da37b967c44bb2a28686c16b7d8316>:0
  at System.Windows.Forms.NativeWindow.Callback (System.Windows.Forms.Message& m) [0x00025] in <05da37b967c44bb2a28686c16b7d8316>:0
mscorlib
    Win32 Version: 4.6.57.0
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/4.5/mscorlib.dll
MiBandWatchFaces
    Assembly Version: 1.0.1.4
    Win32 Version: 1.0.1.4
    CodeBase: file:///C:/MiBand5WatchFaceEditor/MiBandWatchFaces.exe
Mono.Security
    Win32 Version: 4.0.0.0
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/Mono.Security/4.0.0.0__0738eb9f132ed756/Mono.Security.dll
System.Core
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Core/4.0.0.0__b77a5c561934e089/System.Core.dll
System
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System/4.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Configuration/4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Drawing/4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
    Win32 Version:
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/Accessibility/4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Xml/4.0.0.0__b77a5c561934e089/System.Xml.dll
Newtonsoft.Json
    CodeBase: file:///C:/MiBand5WatchFaceEditor/Newtonsoft.Json.dll
System.Numerics
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Numerics/4.0.0.0__b77a5c561934e089/System.Numerics.dll
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Runtime.Serialization/4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    CodeBase: file:///C:/windows/mono/mono-2.0/lib/mono/gac/System.Data/4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************[/i]
12DOTZE
来自: Barcelona
联系:
帖子 12DOTZE »
I can't save as bin file
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
12DOTZE 写了: 06 5月 2021, 12:00
Can you please send the dial in a zip file
Try use save as
头像
Johnson070
来自: Москва
Has thanked: 5 time
联系:
帖子 Johnson070 »
lucsus 写了: 04 5月 2021, 13:33
use palette mode!
代码: 全选
mscorlib
MiBandWatchFaces
Mono.Security
System.Core
System
System.Drawing
Accessibility
    Win32 Version:
System.Xml
Newtonsoft.Json
System.Numerics
System.Data
This can happen because the file is in the root directory and you need administrator rights to change it
pepe pepon
来自: Madrid
联系:
帖子 pepe pepon »
I am getting a "Trojan:Win32/Zpevdo.B" warning from Windows Security
Peoplehater
来自: Germany
联系:
帖子 Peoplehater »
pepe pepon 写了: 15 5月 2021, 12:50
Same here :roll:
回复
回到 “Watchfaces tools”
在线用户
正浏览此版面之用户: 没有注册用户 和 9 访客
