[4.0] XMI Watch - Mi Band 4 | 5 | 6 (Editor + Converter)
jefoce
Has thanked: 11 times
Been thanked: 18 times
Post by jefoce »
lvpokka thanks a lot for *.bin support
My WatchFaces
XMI Watch
Version: 4.0 Release (auto-update)
Platform: Windows (.NET Core 3.1)
Developer: jefoce
Official site: xmi
Documentation: docs
✅ Updates Plan
🟡 4.x.0.0
New:
  • Saving format for app *.xmi (contains styles and all series)
🟢 4.0.0.0
New:
  • Mi Band 6 support (only json open for now)
  • Add background option in the left side
Update:
  • Converting engine
🟢 3.2.0.1
New:
  • Styled messages
🟢 3.2.0.0
New:
  • GIF support with speed
🟢 3.1.0.3
New:
  • Split creating and opening project
🟢 3.1.0.2
Fix:
  • Battery status (showing on Mi Band 4)
🟢 3.1.0.1
New:
  • Margin for project buttons
🟢 3.1.0.0
New:
  • Styling
  • Image DPI correction
Update:
  • Previewer adaptation
🟢 3.0.0.0 - Important
New:
  • Global core (changed more than 50% code)
  • Update preview images on import/paste
Update:
  • Date Inline → Date Separate
  • Image managing system
  • Smart converting system (save positions for elements and resize background by screen size)
Optimize:
  • Open
  • Convert
  • Build
  • Weeks saving
🟢 2.1.0.0
New:
  • Screen adaptation for 1366x768
  • Series converting (Mi Band 4/5)
Fix:
  • Images scrolling
  • Distance suffix for Mi Band 5
🟢 2.0.0.0
New:
  • Mi Band 5 support
  • Optimized speed open/build for Bin and Json formats
  • Preview image after build for Bin format
  • Tooltip with full name on project button mouse hover
Update:
  • Saving system
  • Image compressing
Fix:
  • Closing last project
  • Temp clearing
🟢 1.0.0.3
New:
  • Simplify weekdays edit
Fix:
  • Images preview changing, when select other project
🟢 1.0.0.2
New:
  • Optimizing saving system
  • Notify for closing projects, app
Fix:
  • Localization
🟢 1.0.0.1
Fix:
  • Opening file with spacing name. (example: "xmi watch.exe")
⚠️ Running Problem
If system notify about installation .NET Core - download x86 version
Microsoft wrote:
Full support for Windows 10 (1607, 1709+)
Additional dependencies are required if you're installing the .NET Core:
  • Windows Vista (SP2)
  • Windows 7 (SP1)
  • Windows 8.1
Install the following:
Description
Design program for Mi Band watchfaces
  • You can easily open, edit and build:
    • Json - folder must contains 0000.png → screen sized
    • Bin
  • On / off watch elements (even not include)
  • Copy or import images from opened projects or files
  • Watchfaces converting
  • Text styling
  • Dev: Presets
🖼️ Screenshots
Watch series
  • Mi Band 4
  • Mi Band 5
  • Mi Band 6
Elements support
  • Time
    • Hours
    • Minutes
  • Date
    • Inline / Separate
    • Week
    • Month
    • Day
  • Activity
    • Calories
    • Distance
    • Pulse
    • Steps
  • Widgets
    • Do Not Disturb
    • Bluetooth
    • Lock
    • Battery
  • Other
    • Animation
    • Background
Controls
  • Change value - ↑↓ keys
  • Move - WASD or ↑←↓→ keys and mouse
  • Unselect - Escape key
  • Unvisible - Delete key
  • Selecting in Previewer or Elements bar
Previewer - render on change
  • Previewer limits
    • H, Y (+-Screen height)
    • W, X (+-Screen width)
    • SX (+-20)
  • Render limits
    • Activity (99999)
    • Real time
    • Real date
    • Battery (100)
Languages
  • Russian
  • English (default)
* Right button click on opened app name
ixijimixi
Post by ixijimixi »
Wow...I've been playing around with this for a bit now, and it's the closest I've found yet to an easy-to-use WatchFace editor for the Mi Band 5. I can't wait to see what else you do with it!
AmazChris22
Post by AmazChris22 »
where i can download this Editor? The Link isn't working (i use IE and Firefox).
jefoce
Post by jefoce »
ixijimixi wrote: 06 Dec 2020, 08:17
Thanks ;)
Templates and styles will be the biggest update for app))
jefoce
Post by jefoce »
AmazChris22 wrote: 06 Dec 2020, 13:25
I download last version firefox and check link, it works fine
Belens
Post by Belens »
jefoce wrote: 01 Dec 2020, 19:48
Uncagedphoenix wrote: 01 Dec 2020, 19:14
Only one person messaged me about Trojan.Msil for version 2.0 (but i don't know how to fix it :( )
Program don't contain any viruses and use without request admin permissions.
Trust or not only your choice!
I worked with the program a couple of times last week and everything was fine. But today I tried to open it a Windows Defender warned me about a trojan and it deleted the file :/
jefoce
Post by jefoce »
Belens wrote: 08 Dec 2020, 19:38
I don't know why some defenders find a virus.. Try to download actual version🤷‍♂️
kyle
Post by kyle »
开源的吗?需要帮忙翻译中文吗
如有需要可联系!
Gads
Post by Gads »
arthurking521 wrote: 26 Nov 2020, 04:46
prolem:
when i open this tool,Pop up dialog box prompt:
“To run this application, you must install .NET Core. Would you like to download it now?”
then,I download and install it ,But problem also
I have the same problem, and i run on w10
jefoce
Post by jefoce »
Gads wrote: 16 Dec 2020, 01:20
You need to install x86 .Net Core, link in post → Running problem
kyle
Post by kyle »
Позвольте мне еще раз спросить, нужна ли мне помощь с переводом на китайский язык?
如有需要可联系!
jefoce
Post by jefoce »
kyle wrote: 20 Dec 2020, 16:51
Спасибо, до релиза не планирую переводить на другие языки. Возможно потом сделаю форму для создания пользовательских переводов
Maare
Post by Maare »
why it shows an opening failed error
jefoce
Post by jefoce »
Maare wrote: 02 Jan 2021, 06:29
Which's file format?
cygmon0
Post by cygmon0 »
I would really test it. but everytime i try to open a ".bin" or ".json" files, a pop-up shows says "Opening failed" and then deletes the extracted PNGs
I'm using Windows 10 20H2 with non unicode language.
EDIT: I had to change my computer language to english to make this program work. it seems it doesn't support RTL languages.
ffeingol
Post by ffeingol »
When I try to open a .json file I get a popup that says "Screen size not supported!" Any way I can fix that?
jefoce
Post by jefoce »
ffeingol wrote: 09 Jan 2021, 00:30
Folder must contains 0000.png with screen size resolution
Mi Band 4 - 120x240
Mi Band 5 - 126x294
ffeingol
Post by ffeingol »
jefoce Thanks, I was able to get it loaded now.
I actually have a Amazfit Band 5 not the Mi Band 5. Will this program build the .bin's in that format? After I build the .bin file it's about 1/2 the size of the original and Notify for Amazfit says it's invalid when I try to upload.
It must be something that that particular watch face or one of the images. I was able to build another fine.
jefoce
Post by jefoce »
ffeingol wrote: 09 Jan 2021, 17:26
Hi, support only for Mi Band watchfaces
hermedass
Post by hermedass »
Anyone else gets a virus/trojan warning on this?
Yes, I've got a warning but after analyzing xml.zip in some online virus scanner like opentip.kaspersky and Eset online Scanner I choose to trust this app and added to the white list.
There was no problem with my system after extracting this file
NikiWafa
Post by NikiWafa »
can this tool be used for amazfit band 5?
because I plan to buy AMAZFIT Band 5 ... :)
jefoce
Post by jefoce »
NikiWafa wrote: 15 Jan 2021, 22:16
Only Xiaomi :(
Sanshexx
Post by Sanshexx »
when I try to transform a .json to .bin this appear
jefoce
Post by jefoce »
Sanshexx wrote: 17 Jan 2021, 02:47
Hi, send zip to [email protected].
jefoce
Post by jefoce »
You have a size problem
Log Error
Fatal|[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:645kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:645kb.
   en WatchFace.Program.PackWatchFace(String inputFileName)
   en WatchFace.Program.Main(String[] args)
Sanshexx
Post by Sanshexx »
jefoce wrote: 19 Jan 2021, 11:39
Hi, send zip to
I already sent it to you
