Author
lvpokka
Tool Description
4. Mi band 5 supports 15,499,008 colors ...
搜索找到 11 个匹配
- 25 11月 2020, 14:26
- Jump to forum
- Jump to topic
Re: XMI Watch (WatchFace Editor - Mi Band)
cool~~~~~~~!
- 25 11月 2020, 14:35
- Jump to forum
- Jump to topic
WOW! Cool app with appealing intuitive design! Great functionality and high performance! Finally I don't need to waste a lot of time creating interfaces for my Mi Band 4
Love it! Looking forward to new products jefoce!
- 26 11月 2020, 04:14
- Jump to forum
- Jump to topic
- 26 11月 2020, 11:35
- Jump to forum
- Jump to topic
Looking forward to your dumb version of the software, I can’t figure this out at the moment, thank you for your jobjefoce 写了: 26 11月 2020, 11:25Thanks) I did hope too, however new technology need to install new updates..![]()
- 05 12月 2020, 06:41
- Jump to forum
- Jump to topic
Gah...I installed the x64 version, and it didn't work (running Windows 10 64 bit). Installed x86 version, and it loaded right up.jefoce 写了: 30 11月 2020, 23:04
Hi, arthurking521, maybe you will be able to run after installing .NET Core x86
It's simply![]()
- 06 12月 2020, 08:17
- Jump to forum
- Jump to topic
Re: XMI Watch - Mi Band 4 | 5 (WF Designer + Converter)
Wow...I've been playing around with this for a bit now, and it's the closest I've found yet to an easy-to-use WatchFace editor for the Mi Band 5. I can't wait to see what else you do with it!
- 09 12月 2020, 06:07
- Jump to forum
- Jump to topic
Re: [3.0] XMI Watch - Mi Band 4 | 5 (Designer + Converter)
开源的吗?需要帮忙翻译中文吗
- 08 1月 2021, 16:30
- Jump to forum
- Jump to topic
Re: [3.1] XMI Watch - Mi Band 4 | 5 (Designer + Converter)
I would really test it. but everytime i try to open a ".bin" or ".json" files, a pop-up shows says "Opening failed" and then deletes the extracted PNGs
I'm using Windows 10 20H2 with non unicode language.
https://i.postimg.cc/6Qz0192J/popup.png
https://i.postimg.cc/Jh7ghYj8/delete.png
EDIT ...
EDIT ...
- 20 9月 2021, 03:16
- Jump to forum
- Jump to topic
Re: [3.2.0.1] XMI Watch - Mi Band 4 | 5 (Designer + Converter)
Hey. Thank you. Happy to see the app development still working. Had a question, do you have a plan to add analog dial to work? Will be fantastic.
Your tool is much easier than other to use, honestly.
Thank you.
