SupportUkraine
Wow...I've been playing around with this for a bit now, and it's the closest I've found yet to an easy-to-use WatchFace editor for the Mi Band 5. I can't wait to see what else you do with it!
Only one person messaged me about Trojan.Msil for version 2.0 (but i don't know how to fix it )
Program don't contain any viruses and use without request admin permissions.
Trust or not only your choice!
I worked with the program a couple of times last week and everything was fine. But today I tried to open it a Windows Defender warned me about a trojan and it deleted the file :/
I would really test it. but everytime i try to open a ".bin" or ".json" files, a pop-up shows says "Opening failed" and then deletes the extracted PNGs
I'm using Windows 10 20H2 with non unicode language.
EDIT: I had to change my computer language to english to make this program work. it seems it doesn't support RTL languages.
I actually have a Amazfit Band 5 not the Mi Band 5. Will this program build the .bin's in that format? After I build the .bin file it's about 1/2 the size of the original and Notify for Amazfit says it's invalid when I try to upload.
It must be something that that particular watch face or one of the images. I was able to build another fine.
Yes, I've got a warning but after analyzing xml.zip in some online virus scanner like opentip.kaspersky and Eset online Scanner I choose to trust this app and added to the white list.
There was no problem with my system after extracting this file
Fatal|[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:645kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:645kb.
en WatchFace.Program.PackWatchFace(String inputFileName)
en WatchFace.Program.Main(String[] args)
Cookie Consent
