Weather in a watchface [Verge Lite]
Etiloman
Post by Etiloman »
Hi. I have a doubt about a watchface that I have downloaded. It appears that it has the weather but when I have installed it it is not visible. Do we have to do something to make it look?
Has thanked: 123 times
Been thanked: 19 times
Post by taw_bip »
Weather doesn't work in Verge Lite
T-Troll
Post by T-Troll »
Wrong. weather WORKS at Verge Lite, but only with firmware 1.3.4.15 (it's old beta, so have some other issues).
Seems like it's marketing.
Saatmanyak
Post by Saatmanyak »
T-Troll wrote: 26 Jun 2020, 06:09
how can i change my watch firmware
T-Troll
Post by T-Troll »
WARNING: First, you need patched amazefit app - original one always update firmware to "latest" version.
1. Download firmware - f.e. from 4PDA. You need 1.3.4.15 ONLY, others doesn't support weather!
2. Install Notify&Fitness app from google play (you can also use it instead of Amazefit app), it's free.
3. Unpack firmware files somewhere at you mobile.
4. Start Notify&Fitness, use it's "Update firmware" feature (you need to do it 3 times - file by file).
5. Enjoy!
mateusleivas
Post by mateusleivas »
can u upload this firmware 1.3.4.15 and share link ? 4PDA link is down.
Sharat
Post by Sharat »
I found a post on reddit with a mediafire link. Try it!
AmatoR DoznaN
Post by AmatoR DoznaN »
Ok thanks, however, when Amazfit connects to Mi Fit again, it continues to update and brings it back to the higher version.
Post by taw_bip »
I haven't tried it but my understanding is you need to use a modified version of the Zepp app to prevent the "phone home" function:
https://www.freemyband.com/2019/08/amaz ... h-key.html
Users browsing this forum: Amazon [Bot] and 2 guests
