Weather in a watchface [Verge Lite]
Hi. I have a doubt about a watchface that I have downloaded. It appears that it has the weather but when I have installed it it is not visible. Do we have to do something to make it look?
Saatmanyak
how can i change my watch firmwareT-Troll wrote: 26 Jun 2020, 06:09Wrong. weather WORKS at Verge Lite, but only with firmware 1.3.4.15 (it's old beta, so have some other issues).
Seems like it's marketing.
T-Troll
WARNING: First, you need patched amazefit app - original one always update firmware to "latest" version.
1. Download firmware - f.e. from 4PDA. You need 1.3.4.15 ONLY, others doesn't support weather!
2. Install Notify&Fitness app from google play (you can also use it instead of Amazefit app), it's free.
3. Unpack firmware files somewhere at you mobile.
4. Start Notify&Fitness, use it's "Update firmware" feature (you need to do it 3 times - file by file).
5. Enjoy!
5. Enjoy!
mateusleivas
mateusleivas
AmatoR DoznaN
Ok thanks, however, when Amazfit connects to Mi Fit again, it continues to update and brings it back to the higher version.
- Has thanked: 123 times
- Been thanked: 19 times
I haven't tried it but my understanding is you need to use a modified version of the Zepp app to prevent the "phone home" function:
https://www.freemyband.com/2019/08/amaz ... h-key.html
