HOW TO ADD day & night temperature in this watchface?
liucb05
Post by liucb05 »
AS the title, CAN anybody help me add the day & night temperature in this watchface?
the watchface bin file in closure。
就差日夜温差了.bin
(321.13 KiB) Downloaded 122 times
Has thanked: 436 times
Been thanked: 2137 times
temp_packed_zip.bin
(321.04 KiB) Downloaded 111 times
PS. If you would like the Day and night temperatures to be displayed, you must turn off the current temperature display.
liucb05
Post by liucb05 »
Dear Sir:can you help me REpack this watchface bin file, I have turn off the current temperature display,but the Day and night temperatures still not be displayed. I want it like this
测试_packed_zip.bin
(324.09 KiB) Downloaded 106 times
TXK
Has thanked: 150 times
Been thanked: 99 times
Post by TXK »
liucb05 wrote: 26 Dec 2020, 14:04
你解包一下他帮你制作的、可以正常显示的表盘,查看代码写法,不就可以自己修改了。
或者,你[解包、重新打包]或者修改一下他帮你制作的表盘,对比一下原作,看看哪里出现问题而导致显示故障。
???? I don't understand why your handwatch can not show Day / Night temperatures , Because I test your file it's work normal
PS. Use Zepp + GTR
Atia
Post by Atia »
Set the time format on your phone (not on your watch)
