GTR_Watch_face_ (without_Python) does not work, please help
Rafi87
Post by Rafi87 »
Hi
GTR_Watch_face_ (without_Python) software does not always work correctly
after editing the dial, I can pack and create a BIN file once, and not a second time
why is he doing this to me? i have windows 10
I adjusted one dial that I would very much like, but I can't wrap it, would anyone help me?
Has thanked: 419 times
Been thanked: 2109 times
Rafi87 wrote: 28 Jul 2020, 06:14
Hi
- What the dial , " You pack and create a BIN file once, and not a second time" ,
please show me ?
- .log file show what error
Rafi87
Post by Rafi87 »
I downloaded the dial I like, I adjust it to myself, and I wanted to wrap it in BIN but it doesn't work
the command line appears for 1 second but does nothing,
Rafi87 wrote: 28 Jul 2020, 09:07
if you say only " you download and modified and can not pack .................................. " I think , I can not help you to find your issue too
I think at the very least, report this
1. I would like to know what name of dial you Download to modified and you can not pack it.
2. Please see in your Dial folder, it have "yourDial.log" inside this file you can view for check your error.
Rafi87
Post by Rafi87 »
I downloaded this dial https://amazfitwatchfaces.com/gtr/view/6537
the log file will not be created for me
Rafi87
Post by Rafi87 »
I found
Debug|Reading config...
Fatal|Newtonsoft.Json.JsonSerializationException: Could not find member 'Info' on object of type 'WatchFace'. Path 'Info', line 2, position 9.
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at WatchFace.Program.ReadWatchFaceConfig(String jsonFileName)
Rafi87
Post by Rafi87 »
ws-smart_energy_v3_red-logo_packed_zip-34950-e23f972463.log
(98.2 KiB) Downloaded 87 times
ws-smart_energy_v3_red-logo_packed_zip-34950-e23f972463_packed.log
(1.09 KiB) Downloaded 88 times
Rafi87 wrote: 28 Jul 2020, 10:34
- I test modified and unpack / pack [ https://amazfitwatchfaces.com/gtr/view/6537 GTR_Watch_face_ (without_Python) 8.3 ] with it's ok.
- Now I would like to know what you modified ? I think the issue is caused by what you added or modified.
If possible please zip all you modified and send to me .
Rafi87
Post by Rafi87 »
I took my heart rate
I deleted the battery indicator on the graphic and changed it instead of the heart rate to show in numbers
the date remained and I added the months and the name of the days
that is all
I am attaching a zip file
please create it for me
I have a 42mm version
ws-smart_energy_v3_red-logo_packed_zip-34950-e23f972463.zip
(1.89 MiB) Downloaded 104 times
Rafi87 wrote: 28 Jul 2020, 11:40
that is all
I think you issue is you set " Path " of the program not correct.
I recommend put the program in root of Drive.
Version 8.3 " viewtopic.php?p=3789#p3789 "
I test your file , Your file can pack and unpack normal.
Download :
red_packed_zip.bin
(611.05 KiB) Downloaded 84 times
Rafi87
Post by Rafi87 »
I put the program in the root directory of C:
I put the folder with the dial into C: \ GTR_Watch_face_ (without_Python) \ Watch_face
and it works, it created a BIN file for me
I'm going to try it and record it in my watch
Thank you very much for your advice
Rafi87
Post by Rafi87 »
I found one error, the battery shows only one number, I have a 45% battery and it only shows the number 4
I already fixed it and redesigned the design a bit more
thanks again for the help
Users browsing this forum: No registered users and 19 guests
