MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
dzsergio
Post by dzsergio »
lumenvindex wrote: 08 Apr 2020, 19:03
dzsergio wrote: 07 Apr 2020, 10:14
why should it be 96dpi?
can u make it higher?
Mi Band ignores dpi anyway. You need it to be 96 to get nice preview, that's all.
even if the preview was messed up the band will display it correctly? :o
lumenvindex
Been thanked: 49 times
Post by lumenvindex »
dzsergio wrote: 09 Apr 2020, 15:14
Well, yeah. But how do you know that you've placed everything well without normal preview? :lol:
MESS WITH THE BEST
DIE LIKE THE REST
wes.newman
Post by wes.newman »
I'm looking at creating a custom watch face for the Mi Band. I've downloaded several different faces looking at the different options.
The weather doesn't work on any of the faces I've downloaded. The icon stays the same and the temperature never shows. Is this currently broken in firmware version 1.0.9.48? Any other suggestions? The distance traveled also only shows in km. Can this be switched to miles yet?
lumenvindex
wes.newman wrote: 18 May 2020, 13:24
Search the topic.
MESS WITH THE BEST
DIE LIKE THE REST
LluisQuilez
Post by LluisQuilez »
Buenas tardes,
Últimamente cuando voy a crear el bin, la pantalla del fondo 0000.png no se ajusta correctamente al formato 120x240 y se hace más pequeña.
Por qué?
lumenvindex
LluisQuilez wrote: 22 May 2020, 17:08
Por qué?
Compruebe el DPI de la imagen. Debe ser igual a 96 para que la vista previa se genere normalmente.
Check the DPI of the picture. It should be equal to 96 for the preview to be generated normally.
MESS WITH THE BEST
DIE LIKE THE REST
Stylus
Post by Stylus »
Hola,
Tengo un problema, modifique algunas imágenes de una esfera que descargue de la pagina. La esfera es la F1 V3. Y me tira este error.
Fatal|[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:368kb.
Como puedo solucionarlo?
zebymanga
Post by zebymanga »
I am presented this error when I try to replace distance with weather
Fatal|[ERROR]Could not find member 'Step' on object of type 'Steps'. Path 'Activity.Steps.Step', line 41, position 1
can someone help me?
lumenvindex
zebymanga wrote: 16 Jun 2020, 17:45
It says that there is a mistake in your json. Need to see the code to say what is wrong with it.
By the way, Mi Band 4 doesn't show the weather.
MESS WITH THE BEST
DIE LIKE THE REST
lvpokka
Post by lvpokka »
New Mi band 5 support will be released soon. :!: :D
Animation preview for new watchfaces!
Image ImageImageImage
mediatouch
Post by mediatouch »
Just got my new MI Band 5. It is great!
Can't wait for the new Tools and start making something awesome for Band5!
Who knows, when, where, why!? )))
lvpokka
Post by lvpokka »
Currently i have beta version, but its not deeply tested for public release... but its already working with all mi band 5 components)
Beta version can be used with full understanding that what it can brick your Mi Band, use it at your own risk.
mediatouch
lvpokka wrote: 03 Jul 2020, 16:18
This is great news! So.., waiting for tested and stable release.
Anyway, here (on this website) are no Mi Band 5 category for upload yet. I guess it is upcoming soon... 8-)
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
Amazing! Incredible that mi band 5 add new elements as temperature min and max, humidity, index UV, and time to dawn and sunset.
I did apple faces and this elements will be great to add them. But i would like that the GEEK Team add other tools, as alignement to digital clock, or variation in time to complete one lap on pointers for analog clock (to do for example cronograph for 10, 20 or 30 seconds). Also the order of layers will be nice that i can change. For example, to do a circle with points in circuference that represents the 60 seconds, will be nice that the ones layer be below than the ten layer, to cover that i doesn't need to see. Also i like see a tool for asign 24 elements to hours in clock digital. There are many creators that will apreciate this, because you can change the color, alignament or position hour by hour.
I hope the GEEK Team develope this tools soon. Excelent your job by the way. Best regards!
franluciani
And the layer of heartrate will be nice if it be below the pointers of analog clock
franluciani
Stylus wrote: 06 Jun 2020, 18:36
Hola,
Probá con pallete mode. Si no funciona es porque hay muchos elementos en pantalla. Tenes que reducir el BIN a 321 kb
glassphone
Post by glassphone »
Miband5 BETA test user.
mediatouch
Well.., my first Band 5 WF complete and works well! ;)
Here is the all bundle:
Waiting for an upload category...
antinuvens
Post by antinuvens »
Hello everyone!
I'm customizing my first watchface, but I'm having trouble editing the commands in jason. Here would have any guide explaining each jason module and how to get the X and Y coordinates?
Thank you!
Yife Playte
Post by Yife Playte »
So how can I get the beta one ?
lvpokka
Post by lvpokka »
antinuvens wrote: 17 Jul 2020, 00:17
Hello everyone!
Thank you!
Check any tutorial ofr mi band 4 wf creation. X and 6 you can get, simple openned paint and find needed pixel position.
Yife Playte wrote: 17 Jul 2020, 12:12
Pm me
franluciani
Hi, anyone knows how much does the maximum .bin file weigh that can run the Mi Band 5? i'm creating my first WF for MB5 and the .bin file has 926kb. It's ok to install?
lvpokka
Post by lvpokka »
610kb max, you can try upload 900+ in result you will get an error from miband
btw. last beta build - 2.1.3, do you have last version?
franluciani
no, i have 2.1.2. Can you send me the last version?
franluciani
do you have any version of tool, same pallet mode in Mi band 4, that reduces the .bin file?
