• Administrador
Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Contato:
Mensagem por SashaCX75 »
Imagem
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Editado pela última vez por SashaCX75 em 01 Jun 2022, 07:20, em um total de 25 vezes.
Avatar do usuário
Lordalpine
Registrado em: 09 Out 2019, 22:09
Been thanked: 35 times
Contato:
Mensagem por Lordalpine »
rubiales41 escreveu: 29 Fev 2020, 19:48
hello, how is it done, or where can I find the time points and minutes to make analog clocks ?, thank you very much
- Picking up some element : viewtopic.php?f=41&t=980
- Searching for faces on google by Key Word : Faces, Watch faces, Clean Dial
- Cutting out elements on site that sell Watch or repair watch or Aliexpress [ for Bezel, No I'm not kinding ]
- Unpack faces for android wear, GTR, [ All system :D ]
- Do the Hour Ring // Tachys // Minute ring [ everything you need ] on Watchmaker app for android on your smatphone or Android Emulator, screenshot, retrieve and edit in Photoshop [ Again I'm serious ]
- The Best solution :
do it yourself on Photoshop, Gimp, Illustrator, Autocad [ The best solution IMO ]
Imagem
Avatar do usuário
albertowd
Registrado em: 26 Set 2019, 01:01
Contato:
Mensagem por albertowd »
A quick tip for Photoshop users when saving PNG-24 preset:
When saving a solid PNG (with no transparent pixel, ex.: a full background picture), the exporter does not includes the alpha channel on the final file, leaving it with a true 24-bit PNG file.
The tool will use the same mask for all image files, so if the background image is solid but all other images are transparent, it will save as a 32-bit PNG file and it will crash the bin packer.
Solution: when using transparent and solid images, save solid ones with the normal "Save As ..." option so it will not be optimized into a different bit mask.
[email protected]
Registrado em: 10 Jan 2020, 14:12
Contato:
Mensagem por [email protected] »
我说一句,哥们们,我作为一个中国人,看英文都困难,你们让我去一个俄罗斯网站下载东西,还要求注册一个账户……我下下来一个一看,俄文,你们说郁闷不?谁能给我这个中国朋友提供一个中文版本的下载地址,而且能直接下载的,谢谢大家了……
Let me say, man, as a Chinese, it's difficult to read English. You asked me to go to a Russian website to download things and register an account I'll take a look next time. Russian, do you think it's depressing? Who can provide a Chinese version download address for my Chinese friend, and can download it directly? Thank you
Avatar do usuário
Contato:
[email protected] escreveu: 10 Mar 2020, 00:05
Download v6.2 here.
Or v7.0 beta with Chinese.
[email protected]
Contato:
感谢兄弟,这个我需要翻墙……中国对翻墙软件管理很严,有咱们论坛直接下载的就好了……
Thank you brother, I need to climb over the wall China is very strict in the management of wall climbing software. It's good to have those downloaded directly from our forum
[email protected]
Contato:
我已经翻墙下下来了,但是在表盘制作好以后不知道如何保存成手表能用的文件,谁能告诉我保存文件的步骤呢?麻烦了
I've come down the wall, but I don't know how to save the watch file after the dial is made. Who can tell me the steps to save the file? Sorry for the inconvenience
Avatar do usuário
Maikeldevil
Registrado em: 17 Ago 2019, 12:05
Been thanked: 44 times
Contato:
Mensagem por Maikeldevil »
Hi people, im a bit struggeling with a thing.. So i made this watch face to copy it like the original one:
https://amazfitwatchfaces.com/gtr/view/1160
But my problem is that the hand for step progress is going underneat the digital time. Is there any way to make sure this yellow hand is going over the digital times and status icons instead of under them? Is there any way to difine a dominant order? If there is we could do way more great things, just by changing orders..
Hope someone could reply to me!
(I use the sasha tool together with python)
Avatar do usuário
Pucci14
Registrado em: 08 Mar 2020, 16:42
Contato:
Mensagem por Pucci14 »
Is there any Manual (in any language) wich I could then translate with Google?
Registrado em: 12 Abr 2018, 16:29
Has thanked: 130 times
Been thanked: 19 times
Contato:
Mensagem por taw_bip »
SashaCX75 escreveu: 10 Mar 2020, 17:04
Download v6.2 here.
Thank you for adding Verge Lite to the app!
Avatar do usuário
Contato:
Maikeldevil escreveu: 12 Mar 2020, 07:31
Hand for step progress is going under digital time and over status icons.
The order cannot be changed.
The best way to check is to install on the watch and see.
Pucci14 escreveu: 12 Mar 2020, 12:58
Help is in the program (a question mark beside to the button to close the window or a link on the "About" tab). I have not seen a more detailed help anywhere. Maybe someone will do the best help.
taw_bip escreveu: 12 Mar 2020, 13:40
Verge Lite support in beta may not work properly.
After the release of the stable version, I recommend updating to it.
Avatar do usuário
Contato:
[email protected] escreveu: 12 Mar 2020, 04:44
0. Unpack the existing dial or create a new one.
Imagem
1. Edit the dial.
Imagem
2. Save the dial.
Imagem
3. We pack the dial.
Imagem
Avatar do usuário
Pucci14
Contato:
Thanks SashaCX75!
[email protected]
Contato:
兄弟,谢谢了,我已经自己研究出怎样保存了,还是感谢你的帮助,谢谢。
Brother, thank you. I have worked out how to save it. Thank you for your help. Thank you.
Avatar do usuário
Pucci14
Contato:
First of all I apologize if this question was alredy posted but I have just managed to create a file *packed_zip.bin.
This is a modification of an existing one.
I would also be ready to publish it but, to be sure of the result, I need to see it on my whatch,
Now the question: how can I load into my Watch?
Sorry again for a possible double posst.
It is enough the link to the correct post.
shirumitsu
Registrado em: 07 Jul 2019, 01:48
Contato:
Mensagem por shirumitsu »
Version 7.0 suport animation? if not, please make it!
Download v6.2 here.
Westy
Registrado em: 14 Mar 2020, 20:25
Contato:
Mensagem por Westy »
Pucci14 escreveu: 13 Mar 2020, 16:40
I forgot to mention but it is important that I have an iOS phone.
Avatar do usuário
Contato:
Westy escreveu: 15 Mar 2020, 10:16
How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Westy
Contato:
SashaCX75! Thanks! A lot of them.
WillyB.
Registrado em: 03 Set 2019, 19:59
Contato:
Mensagem por WillyB. »
"Open the folder with the downloaded watch face in the file manager with the path:
/iPhone/Amazfit/watchSkin/"
I cannot open the /iPhone/Amazfit/watchSkin/ folder. Is this only possible with a jailbreak? Or which file manager must I use?
SteMo
Registrado em: 16 Mar 2020, 19:30
Contato:
Mensagem por SteMo »
Pulse (Progress Bar) still not working in GTS devices?
In the spectacular software you made (SashaCX75) I see the correct preview. Then on the clock it doesn't appear in any way. Is it also up to you?
Thank you
Avatar do usuário
Contato:
[mention]SteMo[/mention]
I can not check on the GTS.
But here is the dial where there is Pulse (Progress Bar). To check, you can set the dial. If it works, then unpack and repack the dial and check it.
I can only say that everything works for me on GTR.
SteMo
Contato:
Starting from your quadrant, everything works ... now I can understand what I'm wrong. In any case, thanks, you have been very fast and are doing an exceptional job.
thank you ;)
Avatar do usuário
Maikeldevil
Contato:
Hi Sasha, i have made this watchface:
https://amazfitwatchfaces.com/gtr/view/4381
I used step segments to show the step progress but somehow it doesnt reset after a new day.. Any idea why? (So when i walk 4000 steps and the segments shows me its half way the next day the steps are at 0 but the segments are still stuck on 4000 steps..
Hope someone knows this.
Avatar do usuário
Maikeldevil
Contato:
Maikeldevil escreveu: 23 Mar 2020, 10:04
So it had reset.. On its own on 11:15.. Wierd time :roll:
Avatar do usuário
Contato:
[mention]Maikeldevil[/mention]
Everything looks normal and should work.
A little tip. According to my information, a maximum of 10 pictures is used for the battery and 11 pictures are used in your dial.
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 2 visitantes
