Been thanked: 1029 times
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
ionut02
Post by ionut02 »
Horatius80 wrote: 30 Jan 2020, 10:00
@ionut02 the size of .bin is dependent on the dimensions of the png images (X*Y size, not on the size in bytes) You have to scale some of used elements in Your Watchface, that is the trick ... Based on my own experience, I also faced this problem and all that helped was to minimize the X*Y size of png images
Yeah, I figured this out on my latest watch face - https://amazfitwatchfaces.com/gts/view/855 - size decreased by about 400kb, just under 1.5MB after I used a narrower font, my initial design had a nicer font but a bit wider then the one in the final release. I've tried without transparency with solid background, removing aliasing, using 8 bits (this doesn't work at all) 16 bits etc. The only thing that made a difference in final bin size was the dimensions of the PNG ind if I used or not an image for preview. Because the GTS has 2 standard faces and one custom, if you want to switch between them you need an image for preview, I refereed to background image instead of an additional PNG file.
ionut02 wrote: 30 Jan 2020, 13:47
Looked at your watch face. In some pictures with the name of the day of the week on the right there is a lot of empty space that can be cropped. Some weather icons on the right and bottom also have an empty space that can be cut off.
Try it, this should help reduce the size of the watch face.
156156h
Post by 156156h »
Who can tell me how to save after modify the dial with GTR_WatchFace editor5.2 software file into bin file? How to operate and modify ok, don't save, thank you!
ionut02
Post by ionut02 »
SashaCX75 wrote: 30 Jan 2020, 18:31
Thank you SashaCX75, really appreciate what you are doing and the effort that you put in your tool. I knew that the blank spaces are increasing my bin size, but my design is mostly centered, and since week days have various length and I can only specify the coordinates for the upper left corner this was the only way to have them centered. This wouldn't be in issue if I had used shorten day name and another type of alignment. I will try different designs and see how this can be improved. Right now I'm working on watch face with very large weather icons but I'm still over the max size, since my weather icons are 125x125
Ekohero
Post by Ekohero »
Hi, i have the problem that some bins cant be unpacked ionut02 do you have the same issues?
999Nocturne
Post by 999Nocturne »
hi guys, how can i add more second hands?
i can't put more than one..
chb
Has thanked: 10 times
Post by chb »
you can paste & copy the russian text out of the readme.chm-file (Windows-help-manual)...
but i'm not able to import an existing bin-file and edit it.
Don't worry, eat Curry!
It is advisable to unpack the program to the root of the disk.
If the bin file is not unpacked, then a folder with the file name should appear in the Watch_face folder. In it, you can look at the log file with errors.
kampanita
Has thanked: 8 times
Been thanked: 7 times
Post by kampanita »
Ekohero wrote: 31 Jan 2020, 06:48
You must uncompress them before unpacking. ( you must use ResUNPACKER.exe for doing that ) , or use Sasha's tool for uncompressing a packed bin )
ionut02
Post by ionut02 »
Day and night temperature not working for GTS, only current temperature and weather icons are OK. Is there a workaround to have all values show on the same watch faces?
As far as I know, either the current temperature or the temperature during the day or night can be displayed. They cannot be displayed at the same time.
Who cares GTR_Watch_face_(without_Puthon)_5_2
https://drive.google.com/open?id=1T8u_f ... vW6vtZc-c8
New version of GTR/GTS WatchFace editor v6.0
List of changes (google translation)
https://drive.google.com/open?id=1Sn5oh ... elbtYCx4CS
yinas
Post by yinas »
hey hello.
i already read in this thread regarding, exceeding 1.5MB file size of BIN file.
but i do not want to accept that it depends on visual PNG x*y size...
feels like the packing of the editor is off in some place.
i know how to design the layout, and handle PNGs in a way that file size is minimal with desired visuals.
but this should not be the duty of the designer to be limited to something way smaller than the available screenspace.
currently my actual PNG file sizes are smaller than in some other watchfaces using smaller actual screen estate, and definitely smaller than the largest used fonts for custom watchfaces that still seem to work (but dont have complications).
this does not work:
maybe someone has an idea how to optimize, while still retaining the desired layout and function?
i added a new 1.1 version with smaller main clock font, since the larger one breaks the watchface and even caused bootloop... but i left the original file still within the watchface post.
this works:
this is my watchface post:
https://amazfitwatchfaces.com/gts/view/949
any chance the packing of the bin will be optimized in future versions, to properly allow for all possible combinations of PNGs, aka allowing to use the full screen whichever way imaginable?
thanks for input!
br ;)
Zaslon
Post by Zaslon »
Does anyone know how to resolve the "ValueError: bad transparent mask" error during compilation?
I uses GTR/GTS WatchFace editor v6.0 for GTR 42mm.
yinas
Post by yinas »
Zaslon wrote: 08 Feb 2020, 08:53
Had the same issue when I tried to force compress my PNGs with eg. "PngOptimizer".
Check the images you use in your watchface, and ideally save them properly as PNG via something like Photoshop or GIMP.
shirumitsu
Post by shirumitsu »
anyone post any tutorial vídeo how create a watch face with this program?
maikeandre
Post by maikeandre »
shirumitsu wrote: 08 Feb 2020, 14:37
The software is so much easy to do. Try use it. I suggest you to get one whatch from site (a simple) and open it in editor. This is the best way to be a master! :)
999Nocturne
maikeandre wrote: 08 Feb 2020, 14:46
Sorry but the program does not manage the animation?
maikeandre
999Nocturne wrote: 08 Feb 2020, 14:58
Not yet.
This usually happens when there are 8-bit pictures.
Zaslon
Post by Zaslon »
SashaCX75 wrote: 08 Feb 2020, 18:50
Now I try changing images to PNG-8/PNG-16 but both cause the error.
I use the Affinity Designer but this might be not gfood.
I'll try something else. Thank you!
Zaslon wrote: 09 Feb 2020, 02:55
PNG-8 - definitely not working
PNG-16/24 - it doesn't work for me, but some people write what works
PNG-32 - works fine
You can lay out the source, try to see why it does not work.
Zaslon
Post by Zaslon »
SashaCX75 wrote: 09 Feb 2020, 08:50
PNG-32 - works fine
I checked Affinity forum and finally I got the core of this problem.
My background image's background 8-) filled with black colour so there's no transparent area.
It causes 32bit PNG changed into 24bit PNG as no alpha channel automatically.
I changed some images into 32bit PNG, It works!
shirumitsu
this program work on windows 10? here i cant use, any bug
Horatius80
Post by Horatius80 »
shirumitsu wrote: 11 Feb 2020, 10:32
The editor must be in the root C:\GTR_watchface_editor .... or D:\GTR_ .... and better run it on 64bit OS ... I have Windows 10 64bit in root of "D" disk and it works perfectly without any problems ...
Users browsing this forum: MF2zy18wRdWiZrOk and 1 guest
