Has thanked: 14 times
Been thanked: 1043 times
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Matth78
Post by Matth78 »
Does compile work? I failed to do it with Windows without python. I don't understand what is wrong since it seems so simple! 😓
Edit :
For those who may have the same problem, mine was coming from no transparency on some image.
After adding transparency I have been able to pack. (But produced bin does not work on my watch T_T)
Ekohero
Post by Ekohero »
no compile:
bin to -> open file directory does not work
so I cant edit this watchfaces
I wanted to see how the circles for calories and temperatur are done
Has thanked: 429 times
Been thanked: 2132 times
GTR_WatchFace editor for Windows by SashaCX75
Version 5.2 full
The program is available for download now.
http://4pda.ru/forum/index.php?showtopi ... ry92847810
Обновил Графический редактор циферблатов
Добавлена поддержка набора иконок (иконки и набор координаты к ним) для прогресса шагов и батареи.
Добавлена возможность обрезки предпросмотра по форме экрана.
Исправлены ошибки в английской версии.
Google translate
Updated Graphical Dial Editor
Thank SashaCX75
kampanita
Has thanked: 8 times
Been thanked: 7 times
Post by kampanita »
asoo wrote: 13 Jan 2020, 18:22
Version 5.2 full
Google translate
Thank SashaCX75
I can not download from 4pda.ru , not registered at that site....I tried to but don't understand russian and google translate didn't help also.
Could you upload 5.2 version to somewhere else ( mega / drive ... ) ?
kampanita wrote: 14 Jan 2020, 08:17
I'm not sure if 4pda allows copying this file for distribution outside of the 4pda in public.
To conclude, I sent my link that I uploaded for you in PM.
Please SEE your Private message
Horatius80
Post by Horatius80 »
[mention]asoo[/mention] please, if it is possibble, share the link with me also ... many many thx
Horatius80 wrote: 14 Jan 2020, 10:44
@asoo please, if it is possibble, share the link with me also ... many many thx
Next time, who wants my link?
Please PM to me
Do not post request
Thank
If you want to improve the translation or add a translation into other languages, write in PM.
Kastelic
Post by Kastelic »
many many thx
Starlince
Post by Starlince »
hola a todos, perdón por mi petición, pero es que me he bajado el programa watchfaces tools en inglés pero no se como funciona, se que es mucho pedir, pero alguien me podría decir, indicar o remitir a unas instrucciones para un novato?? Muchas gracias de antemano y perdón por las molestias.
Ekohero
Post by Ekohero »
may i get a link pls?
ionut02
Post by ionut02 »
Hi, can I please have the link for the new version. 4PDA uses Russian captcha for creating an account, practically impossible to register with google translate.
ss30
Post by ss30 »
Hi can someone pm me the dl link for 5.2 please.
maikeandre
Post by maikeandre »
Guys, here you have a tutorial to bypass the captcha from 4DPA.
https://doorsgeek.blogspot.com/2015/08/ ... orial.html
Tugas
Has thanked: 7 times
Post by Tugas »
ionut02
Post by ionut02 »
maikeandre wrote: 24 Jan 2020, 00:17
Thanks maikeandre, that tutorial worked great.
Fuzzy
Post by Fuzzy »
can be used for verge lite?
Matierk
Post by Matierk »
Is there a GTR editor for mac
Fuzzy wrote: 28 Jan 2020, 21:45
The editor is not designed for the verge lite screen size. The preview image may not be correct (especially for analog clock). But theoretically, he should collect dials for verge lite. To do this, on the first tab, replace "--gtr 47 --file" with "--vergelite --file".
Matierk wrote: 29 Jan 2020, 02:06
No
StopkaPeter
Post by StopkaPeter »
Hi SashaCX75, I want ask you, which "main.exe" for decompile do you use in your program. Until today, I only know about two partially working sources. First is from github repo https://github.com/ghtalpo/py_amazfit_tools and second is from GizChina.it telegram group where is some new version 0.2. I ask because sometimes some bin files can't decompile, some has unknown strings, etc. I don't know now, which one is actually best for decompile bin files for GTS.
ionut02
Post by ionut02 »
Right now it's a complete mess regarding the tools for GTS, SashaCX75's tool is the most complete but it doesn't support yet shortcuts, I don't know if he plans to update. Right now I'm unpacking my watch face with the respacker/unpacker tool, then decompile the watchface with the py tool from this fork https://github.com/amazfitbip/py_amazfi ... /v0.2-beta this one is the one from GizChina.it, that error is because the face has shortcuts in it, then I edit my PNG's in photoshop, export in compatible format, I use Sasha's tool to place the elements and fix alignment, really hope better english support in the next version. Then I edit the modified json in Notepad++ to add shortcuts to pulse, steps and weather and after all of this you have to recompile and repack the watch face bin file. My main issue right now is that I can't seem to find the best way to have the face below 1.5MB with all the elements I want to add.
Horatius80
[mention]ionut02[/mention] the size of .bin is dependent on the dimensions of the png images (X*Y size, not on the size in bytes) You have to scale some of used elements in Your Watchface, that is the trick ... Based on my own experience, I also faced this problem and all that helped was to minimize the X*Y size of png images
kampanita
Post by kampanita »
Horatius80 wrote: 30 Jan 2020, 10:00
@ionut02 the size of .bin is dependent on the dimensions of the png images (X*Y size, not on the size in bytes) You have to scale some of used elements in Your Watchface, that is the trick ... Based on my own experience, I also faced this problem and all that helped was to minimize the X*Y size of png images
Agree with you. I usually use "crop image to content" in GIMP for that pourpouse.
StopkaPeter wrote: 29 Jan 2020, 22:49
In the current version, the program will be used https://github.com/lolyinseo/py_amazfit ... 094bd3b59d from 12.15.19 and "main.exe" made on its basis.
Future versions plan to upgrade to a newer version with the addition of new features.
Users browsing this forum: No registered users and 12 guests
