• Administrador
Reglas del Foro
Avatar de Usuario
Contactar:
Mensaje por SashaCX75 »
Imagen
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Última edición por SashaCX75 el 01 Jun 2022, 07:20, editado 25 veces en total.
Avatar de Usuario
Lordalpine
Been thanked: 35 times
Contactar:
Mensaje por Lordalpine »
Hello^^ It's a Nice tool.
I Tried this tool today to make a Watchface for my GTR 47mm [ This tool works also fo 42mm ]
- I Use it to setup everything, but prefer to pack in command line. The Json made with it is accurate.
- Real Time view.
- Box to Check and Uncheck for element, you just write the coordinate in the box.
- You can make the Gif with the weather
- I'm on a 49" UHD monitor, you can scale the Real Time View for your Monitor size. [ A Gigantic real time view of your creation :D ]
jeffrey38
Has thanked: 10 times
Been thanked: 12 times
Contactar:
Mensaje por jeffrey38 »
I cannot get past the login captcha in 4pda, can you share the .zip file please?
Tugas
Has thanked: 7 times
Contactar:
Mensaje por Tugas »
murigny64 escribió: 17 Dic 2019, 17:06
There is an amazing app made by SashaCX75 (thx to him :) ) on 4PDA.ru
The tool is only on russian, but easy to learn and operate ;)
Imagen
https://4pda.ru/forum/index.php?showtop ... ry91024216
ps: don't send me PM for sharing
:roll:
Please attach the zip file please i dont have Russian cars...
jeffrey38
Contactar:
Thank you so much Lukass
jeffrey38
Contactar:
Can anyone please help translate Sashacx75 gui editor?
Korr
Mensaje por Korr »
+1 please.
Thx for a translation
Les personnes atteintes du deuxiГЁme dГ©faut enzymatique hГ©rГ©ditaire le plus courant, le pyruvate, les donnГ©es des patients liГ©es Г  votre utilisation de cette offre 24 h plus tard lorsque le sildГ©nafil a Г©tГ© administrГ© par voie orale fig..
jeffrey38
Contactar:
Imagen
jeffrey38
Contactar:
Imagen
jeffrey38
Contactar:
Avatar de Usuario
lukbe
Been thanked: 8 times
Contactar:
Mensaje por lukbe »
Here is version 5.1:
https://mega.nz/#!rEpxRYiJ!Cv7AAYr4rFvS ... taBUYuYGQs
News:
- English language is supported
-support for compressed bin file
Avatar de Usuario
gizmo2k4
Contactar:
Mensaje por gizmo2k4 »
hi, i made a WF for me , but how i make the bin file ? can anyone help me ? when i click on pack bin it doesn´t do anything .
Louis_Cypher
Contactar:
Mensaje por Louis_Cypher »
lukbe escribió: 29 Dic 2019, 09:03
News:
Just now that I was almost a Russian speaker?! Lol
+1 for instructions to compile .bin file.
Avatar de Usuario
gizmo2k4
Contactar:
So how compile the bin file? Thx
Avatar de Usuario
Lordalpine
Contactar:
In Version: 5.1 // How to set Language to English
Go to Hactponkn [ Option ]
Imagen
Language Selection is there
Imagen
The app will restart^^ Magic^^ 90% of the App is translated
Imagen
Avatar de Usuario
gizmo2k4
Contactar:
calom
Contactar:
Mensaje por calom »
I cant put to work this tool... when I try to open a bin file just open a DOS window but close and nothing appear.
This tool can open an existent bin file face and then edit?
Any help please?
Volker Liebzeit
Contactar:
Mensaje por Volker Liebzeit »
jeffrey38 escribió: 22 Dic 2019, 15:30
Can you please tell me where to find it? Still can't unpack anything with weather.
Avatar de Usuario
Lordalpine
Contactar:
Volker Liebzeit escribió: 01 Ene 2020, 19:23
The way to avoid Unpack Problem is to retrieve "Fix array Branches"
With Loly Dev GTR, you can Unpack Bin with Weather... but when you will want to Unpack Bin with Weather and Extra Analogic Hand, You will have the same problem
I Had this problem, let me explain, I can Pack and unpack with the Python tool I had : All bin + weather.
Then I wanted to Unpack An Hikashi Watchface with Extra Analogic Hand [ Because I wanted to Know How it was done reading the Json file ] and I Can't Unpack It. The Tools says "Done" but I had only a log File with "an error of function not supported"
So I move to dpeddi Branch " Fix Array" To Pack and Unpack : Bin / Json + Weather + Extra Analogic Hand
Setup Python Tool environment
viewtopic.php?f=38&t=1110
SashaCX75 Gui Tool No Python Version
Horatius80
Mensaje por Horatius80 »
Adjuntos
Amazfit_RainbowCircle.zip
Compressed bin file:
(149.7 KiB) Descargado 1490 veces
Avatar de Usuario
Has thanked: 419 times
Been thanked: 2109 times
Mensaje por asoo »
Imagen
Imagen
(607.67 KiB) Descargado 2156 veces
Última edición por asoo el 15 Ene 2020, 07:16, editado 1 vez en total.
Avatar de Usuario
Lordalpine
Contactar:
asoo escribió: 07 Ene 2020, 02:54
Avatar de Usuario
Mensaje por asoo »
Lordalpine escribió: 08 Ene 2020, 10:11
( Thank SashaCX75 )
Ekohero
Contactar:
Mensaje por Ekohero »
have the problem with
Imagen
I cant extract the bin.
Responder
Volver a “Watchfaces tools”
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 4 invitados
