Just read the readme to understand the workflow and go make those cool watchfaces
https://github.com/chm-dev/GTS-watchface-bundle
Open the .json file and check "Background" section. "ImageIndex" is the number of png filename that matches with background file. To change, use other imagem with 338x442 pixel size. Copy and rename to "ImageIndex" number with png extension. For exemple if Background section is:rubiales41 wrote: 30 Jan 2020, 21:55hello, does anyone know how it is done to change only the background of an already created sphere ?, I get to unpack the .bin file but how do I add the background that I want ?, so that when I package it I am not mistaken ?.
"Background": {
"Image": {
"ImageIndex": 500,
"X": 0,
"Y": 0
Nevermind. I found the problem. Packed BIN file without compression was bigger than 1.5mb. I fix removing some resources images.danbroken wrote: 13 Feb 2020, 01:19Hello everybody! I made one watchface from scratch. It works perfectly. It has hour, minute, second, calories, month, day, week, steps, battery and pulse. But the problem came when I try to put more information like weather. The weather icon and info works, but battery icon and "°C" signal dissapear. Is there a limit to screen information and animation icons? Or is it a bug?![]()
