[download] GTS Watchface Bundle
chm
Been thanked: 12 times
Post by chm »
The tools are all over the place so I decided to put them in a single bundle.
Just read the readme to understand the workflow and go make those cool watchfaces :).
https://github.com/chm-dev/GTS-watchface-bundle
kotw
Been thanked: 9 times
Post by kotw »
Great job, I was waiting for someone to do something normal to do GTS Watchfaces :)
Thanks for sharing :)
LoraMoser
Post by LoraMoser »
Thanks for sharing this tools, works as intended! ;)
allurba
Post by allurba »
Good work, almost everything works, the circle of progress steps and battery progression does not work in the Gts.
Your code is:
"StepsProgress": {
"Circle": {
"CenterX": 88,
"CenterY": 88,
"RadiusX": 24,
"RadiusY": 24,
"StartAngle": 0,
"EndAngle": 360,
"Width": 3,
"Color": "0x00FF00"
If you add this line if it works on the gts:
"StepsProgress": {
"Circle": {
"CenterX": 87,
"CenterY": 367,
"RadiusX": 26,
"RadiusY": 26,
"StartAngle": 0,
"EndAngle": 360,
"Width": 7,
"Color": "0x00827410",
"Flatness": 0
"Battery": {
"Scale": {
"CenterX": 47,
"CenterY": 319,
"RadiusX": 18,
"RadiusY": 18,
"StartAngle": 0,
"EndAngle": 365,
"Width": 5,
"Flatness": 0
Would it be very difficult to modify to make it work?
Thank you very much for your work.
Enej
Post by Enej »
Hello, I have trouble with adding and moving weather, I click on the add weather button and it shows on the watch face, but in json there is nothing added so I could move x and y paths... Also when I move folder of the watchface into pack.cmd, nothing happens... Anyone know how to help with that?
Thank you and kind regards
rubiales41
Post by rubiales41 »
hello, does anyone know how it is done to change only the background of an already created sphere ?, I get to unpack the .bin file but how do I add the background that I want ?, so that when I package it I am not mistaken ?.
danbroken
Post by danbroken »
rubiales41 wrote: 30 Jan 2020, 21:55
Open the .json file and check "Background" section. "ImageIndex" is the number of png filename that matches with background file. To change, use other imagem with 338x442 pixel size. Copy and rename to "ImageIndex" number with png extension. For exemple if Background section is:
    "Background": {
        "Image": {
            "ImageIndex": 500,
            "X": 0,
            "Y": 0
Sorry my poor english. :)
danbroken
Post by danbroken »
Hello everybody! I made one watchface from scratch. It works perfectly. It has hour, minute, second, calories, month, day, week, steps, battery and pulse. But the problem came when I try to put more information like weather. The weather icon and info works, but battery icon and "°C" signal dissapear. Is there a limit to screen information and animation icons? Or is it a bug? :ugeek:
danbroken
Post by danbroken »
danbroken wrote: 13 Feb 2020, 01:19
Nevermind. I found the problem. Packed BIN file without compression was bigger than 1.5mb. I fix removing some resources images. :)
mvtnhan
Post by mvtnhan »
Brotrix
Post by Brotrix »
I have downloaded this and all of it does not extract. Wont let me add any backgrounds, Any Ideas im doing wrong?
jorgealmeida.rs
Post by jorgealmeida.rs »
Please ! Is there something like this to make the GTS 2, GTS 2 MINI Watchfaces? Thanks
amazneo
Has thanked: 12 times
Post by amazneo »
Anyone successfully try this tool in Dec 2021?
The unpack.cmd doesn't do anything?
I'm using Windows 10 Pro v.20H2
