Правила форуму
Відповісти
Аватар користувача
Been thanked: 1044 times
Контактна інформація:
Повідомлення SashaCX75 »
Зображення
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Востаннє редагувалось 01 червня 2022, 07:20 користувачем SashaCX75, всього редагувалось 25 разів.
Аватар користувача
Lordalpine
З нами з: 09 жовтня 2019, 22:09
Been thanked: 35 times
Повідомлення Lordalpine »
Hello^^ It's a Nice tool.
I Tried this tool today to make a Watchface for my GTR 47mm [ This tool works also fo 42mm ]
- I Use it to setup everything, but prefer to pack in command line. The Json made with it is accurate.
- Real Time view.
- Box to Check and Uncheck for element, you just write the coordinate in the box.
- You can make the Gif with the weather
- I'm on a 49" UHD monitor, you can scale the Real Time View for your Monitor size. [ A Gigantic real time view of your creation :D ]
jeffrey38
З нами з: 19 грудня 2019, 17:55
Has thanked: 10 times
Been thanked: 12 times
Повідомлення jeffrey38 »
I cannot get past the login captcha in 4pda, can you share the .zip file please?
Tugas
З нами з: 30 листопада 2019, 21:09
Has thanked: 7 times
Повідомлення Tugas »
murigny64 писав: 17 грудня 2019, 17:06
There is an amazing app made by SashaCX75 (thx to him :) ) on 4PDA.ru
The tool is only on russian, but easy to learn and operate ;)
Зображення
https://4pda.ru/forum/index.php?showtop ... ry91024216
ps: don't send me PM for sharing
:roll:
Please attach the zip file please i dont have Russian cars...
jeffrey38
Thank you so much Lukass
jeffrey38
Can anyone please help translate Sashacx75 gui editor?
Korr
З нами з: 10 травня 2019, 17:05
Повідомлення Korr »
+1 please.
Thx for a translation
Les personnes atteintes du deuxiГЁme dГ©faut enzymatique hГ©rГ©ditaire le plus courant, le pyruvate, les donnГ©es des patients liГ©es Г  votre utilisation de cette offre 24 h plus tard lorsque le sildГ©nafil a Г©tГ© administrГ© par voie orale fig..
jeffrey38
Аватар користувача
lukbe
З нами з: 02 червня 2018, 08:09
Been thanked: 8 times
Повідомлення lukbe »
Here is version 5.1:
https://mega.nz/#!rEpxRYiJ!Cv7AAYr4rFvS ... taBUYuYGQs
News:
- English language is supported
-support for compressed bin file
Аватар користувача
gizmo2k4
З нами з: 01 листопада 2019, 12:08
Повідомлення gizmo2k4 »
hi, i made a WF for me , but how i make the bin file ? can anyone help me ? when i click on pack bin it doesn´t do anything .
Louis_Cypher
З нами з: 28 грудня 2019, 14:46
Повідомлення Louis_Cypher »
lukbe писав: 29 грудня 2019, 09:03
News:
Just now that I was almost a Russian speaker?! Lol
+1 for instructions to compile .bin file.
Аватар користувача
gizmo2k4
So how compile the bin file? Thx
Аватар користувача
Lordalpine
In Version: 5.1 // How to set Language to English
Go to Hactponkn [ Option ]
Зображення
Language Selection is there
Зображення
The app will restart^^ Magic^^ 90% of the App is translated
Зображення
Аватар користувача
gizmo2k4
calom
З нами з: 16 листопада 2019, 00:22
Повідомлення calom »
I cant put to work this tool... when I try to open a bin file just open a DOS window but close and nothing appear.
This tool can open an existent bin file face and then edit?
Any help please?
Volker Liebzeit
З нами з: 27 грудня 2019, 12:43
Повідомлення Volker Liebzeit »
jeffrey38 писав: 22 грудня 2019, 15:30
Can you please tell me where to find it? Still can't unpack anything with weather.
Аватар користувача
Lordalpine
Volker Liebzeit писав: 01 січня 2020, 19:23
The way to avoid Unpack Problem is to retrieve "Fix array Branches"
With Loly Dev GTR, you can Unpack Bin with Weather... but when you will want to Unpack Bin with Weather and Extra Analogic Hand, You will have the same problem
I Had this problem, let me explain, I can Pack and unpack with the Python tool I had : All bin + weather.
Then I wanted to Unpack An Hikashi Watchface with Extra Analogic Hand [ Because I wanted to Know How it was done reading the Json file ] and I Can't Unpack It. The Tools says "Done" but I had only a log File with "an error of function not supported"
So I move to dpeddi Branch " Fix Array" To Pack and Unpack : Bin / Json + Weather + Extra Analogic Hand
Setup Python Tool environment
viewtopic.php?f=38&t=1110
SashaCX75 Gui Tool No Python Version
Horatius80
Повідомлення Horatius80 »
Вкладення
Amazfit_RainbowCircle.zip
Compressed bin file:
(149.7 Кіб) Завантажено 1519 разів
Аватар користувача
Has thanked: 438 times
Been thanked: 2141 time
Повідомлення asoo »
Зображення
Зображення
(607.67 Кіб) Завантажено 2186 разів
Востаннє редагувалось 15 січня 2020, 07:16 користувачем asoo, всього редагувалось 1 раз.
Аватар користувача
Lordalpine
asoo писав: 07 січня 2020, 02:54
Аватар користувача
Повідомлення asoo »
Lordalpine писав: 08 січня 2020, 10:11
( Thank SashaCX75 )
Ekohero
З нами з: 28 грудня 2019, 18:44
Повідомлення Ekohero »
have the problem with
Зображення
I cant extract the bin.
Відповісти
Хто зараз онлайн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 4 гостей
