lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
mysiak wrote: 26 Sep 2019, 16:38
Did I miss something? :)
There IS exe in the archive. Your antivirus must have eaten it. :mrgreen:
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Has thanked: 11 times
Post by mysiak »
lumenvindex wrote: 26 Sep 2019, 18:28
Oh great, you're right. "WF_Builder0.9.7.exe. The Trojan named Artemis!C163E601FD27 was detected and deleted." Interestingly 0.9.5 did not get deleted. Unfortunately I have no control over stupid McAffee on my work PC :\
mysiak
Post by mysiak »
Any chance that you could share the au3 file so we, with stupid forced antivirus software can run it directly from source? :)
lumenvindex
mysiak wrote: 27 Sep 2019, 07:08
share the au3 file
Only if you promise me not to share it with anyone else. :D Mail me about it (see help message in any version of a program).
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Post by mysiak »
lumenvindex wrote: 27 Sep 2019, 08:17
share the au3 file
:D I ended up with a basic Windows XP VM and managed to run WF_Builder in there. As long as it's running in XP I'll be fine. But thanks a lot anyway, I might contact you with this request in the future. :)
lumenvindex
First message updated: added link to WF_Builder 0.9.8.
UPD: added link to WF_Builder 1.0.0.
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Post by mysiak »
I'm having quite interesting problem. Due to a "virus" I must use virtual PC (Windows XP) and here I face difficulty with sorting order of numbers and weekdays.
This is how it works on my XP machine, whenever I load images with "Files" button:
- numbers MUST be "1,2..9,0", otherwise they're shifted by 1 (1 displayed instead of 2 etc.).
- weekdays MUST be "TUE, WED,...MON", otherwise they're shifted by one day (Monday displayed when it's Tuesday etc.).
Once I select them in this "wrong" order and save them, they are saved to the WF folder correctly (0-9, MON-SUN). If I replace WF images directly and reload the JSON file, WF displays and builds correctly. The issue is present only if I load images with "Files" button.
It's pain in the *** to work this way so I would appreciate if anyone has any idea why it's behaving this way. I checked all my localization settings (language, region, ..) and everything seems to be the same with my host Windows 7 where I do not face these issues.
Thanks in advance :)
lumenvindex
Well, the FileOpenDialog function returns a string with a list of filenames. On Windows XP this function places last filename at the begining. On other versions of Windows this behaviour has changed - filenames list is sorted alphabetically.
Will make some workaround for this situation in 1.0.1 (For now you can try redownloading 1.0.0 and using WF_Builder1.0.0_upx.exe - it has little less score on Virustotal).
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Post by mysiak »
Oh wow, never realized this strange behavior of XP. If I select the files in reverse order in the FileOpenDialog (click on the last file first and then shift click on the first file), funnily enough, they are opened in an ascending order.. So you probably don't need to do anything, maybe just raise a warning for unaware XP users like me (if there are any still using XP)..? :)
Thank you for the upx file, but it still gets deleted by McAfee.
lumenvindex
mysiak wrote: 02 Oct 2019, 05:05
I'll better sort the filenames array for WinXP. You can now try WF_Builder 1.0.1 (first message updated).
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Post by mysiak »
Thanks! New method works fine. Just not sure that I understand the difference between "Copy Data & Hdr/Row" and "Copy Data Only" buttons, both seem to load pictures correctly. Also "Exit script" closes the whole WF_builder app, one can easily lose work by clicking this button instead of the red "X" :)
Just wondering - is this new FileOpenDialog going to show on all Windows versions or is it exclusive to XP?
lumenvindex
mysiak wrote: 02 Oct 2019, 08:23
Oops, this window is for debugging purposes only, I just forgot to remove it. It won't show on other systems than XP.
UPD: Recompiled the binary without it. Redownload, please. Sorry.
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Post by mysiak »
Thanks a lot, now the magic's done in the background. :)
Avone
Post by Avone »
Hey OP, so Windows 10 detected a trojan in the program. Please look into this
Screenshot (25).png (34.81 KiB) Viewed 41496 times
lumenvindex
Avone wrote: 02 Oct 2019, 16:30
Please look into the original post (Virus spoiler). :?
You should use version 1.0.1 - I "removed trojan" from it. :D
MESS WITH THE BEST
DIE LIKE THE REST
Freddious
Post by Freddious »
lumenvindex wrote: 02 Oct 2019, 18:07
Hello lumenvindex!
Im sure im missing something basic, but I try to make an analog clock with custom clock hands. When I click on 'ON' under the analog tab, there appears a basic white hand which dinamically changes when I change the time but when I click on 'FILE' right to the text 'IMAGE' to open my custom hand png, it shows up, but only as a static object and wont change when I change the time. What am I missing?
Cheers,
Ferdinand
lumenvindex
Freddious wrote: 03 Oct 2019, 13:44
Sadly, this image is static on Mi Band 4. You can't choose image file to use as analog hand.
MESS WITH THE BEST
DIE LIKE THE REST
Freddious
Post by Freddious »
lumenvindex wrote: 03 Oct 2019, 13:58
Noooo, that's really bad news. :c
I was trying to make this idea of a watchface:
But thanks for your answer anyway!
phamaral
Post by phamaral »
Hey! This tool is amazing. It makes it so much easier to put the watchfaces together.
But there is something I want to know if it's possible, i can't find it anywhere.
Do you know if there is a way to change the drawing order of the elements? I want the battery icon to be behind the date, but it renders on the front, covering it up.
lumenvindex
phamaral wrote: 04 Oct 2019, 16:39
The order is unchangeable. You can only use transparency of the image to show what's under the battery icon.
MESS WITH THE BEST
DIE LIKE THE REST
awrun
Post by awrun »
Hello, I try to download the file (WF_Builder1.0.1.zip), but I can not.
Error message is: "Download limit reached. You can still save this file to your Yandex.Disk".
Can I get this editor somehow?
lumenvindex
awrun wrote: 10 Oct 2019, 14:44
Didn't know they have it. Will upload the editor somewhere else ASAP.
UPD: Reuploaded the program, it should solve the problem. At least for a while.
MESS WITH THE BEST
DIE LIKE THE REST
awrun
Post by awrun »
Thank you very much. I have it now, and try to use it. :)
lumenvindex
awrun wrote: 11 Oct 2019, 13:46
I have it now
Hurry up to get new WF_Builder 1.0.2 before the Download limit reached. :D (First post updated.)
MESS WITH THE BEST
DIE LIKE THE REST
Notarino
Post by Notarino »
Hi , I´ve tried to create a watchface with this gif, but i dont achieve that plays correctly. Could anyone make the watchface ??? i´m so hopeless... Thanks for your attention.
PD: I´ve split the gif in images and I´ve modified the size of images ,but its didnt plays correctly
