How to resize a watchface from GTR 47mm to 42mm
Hi all,
I've got the GTR 42mm, but I can see that there are just a few custom watchfaces available for this version, but for the 47mm there are lots around.
I wanted to know if there is a way to get a custom watchface for the 47mm and just resize it for the 42mm
Is that possible? if so, how to do it?
Thanks!!
Thanks!!
There must be a way since I've seen a couple of watchfaces resized from 47mm
Jpmaroco
kampanita
- Has thanked: 8 times
- Been thanked: 7 times
Put your 47.bin file into a zip file and upload to
https://wakeup.aliennation.lv/amazfit/
Then click the button for downloading 42.bin.zip file and decompress it.
There you have 42.bin and also all unpacked files.
kampanita
The bin file must be only packed....if you use a "compressed bin" this online tool does not work and gives "error" message
So if you begin with a compressed bin you should
* uncompress and unpack the bin file
* pack again ( but no compress!! )
* create a zip file with the bin
* upload to the site
* click on download for getting file_42.zip
* unzip that file and there you have all the contents also a repacked bin version for 42mm
I try unpack the bin file use IZArc but after unpack..in folder dont have any file...
kampanita
You need SaShaCX75's app for doing it ( Watchface_GTR )Wansunan wrote: 16 Jan 2020, 01:57I try unpack the bin file use IZArc but after unpack..in folder dont have any file...
ResPacker << used to compress the bin
ResUnpacker << used to uncompress the bin
These are two diferent things uncompress and unpack
* uncompress ( resunpacker ) decompresses the bin and gets another bin
* unpack extracts all the files at the bin ( .png, .json )
- Attachments
- App that helps to compress - uncompress - pack - unpack
- notitle2.png (104.61 KiB) Viewed 7346 times
- Respacker and resunpacker at SashaCX75's app
- notitle.png (98.23 KiB) Viewed 7346 times
- Has thanked: 420 times
- Been thanked: 2122 times
You can try this ( viewtopic.php?p=5109#p5109)
GTR_WatchFace editor for Windows by SashaCX75
Version 8.0
- Added the ability to convert dials between different watch models (GTR47,42/ T-Rex / Verge Lite).
Version 8.0
