• Administrador
MiBandWFTool
Reglas del Foro
lvpokka
Has thanked: 19 times
Been thanked: 152 times
Contactar:
MiBandWFTool
Mensaje por lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Última edición por lvpokka el 02 Ago 2020, 19:41, editado 24 veces en total.
mamen
Contactar:
Mensaje por mamen »
Can someone give me some explanation on how this MiBandWFTool works ?
The thing is, I think I am doing the procedure correctly i think, but my .bin file gets >400kb's of size and fails installing on the mi band!
I download any theme on the website, drag it to the .exe, and next (without doing any changes) drag the generated json to the .exe. Only on this procedure, the size goes from 20 / 30 kbs to 400kbs.. I just dont get it.
Can someone help please ? I tried several version i get always the same result..
lvpokka
Contactar:
Read README and use palette mode
hammad497
Mensaje por hammad497 »
lumenvindex escribió: 09 Sep 2019, 17:47
hammad497 escribió: 09 Sep 2019, 12:33
Is there a way to create a watchface that displays time in words instead of numbers?
Yes, there is. But it will take a lot of space.
Example
Can you provide a bin for this? I want to try it. Thanks
Avatar de Usuario
lumenvindex
Been thanked: 49 times
Contactar:
Mensaje por lumenvindex »
hammad497 escribió: 09 Sep 2019, 19:46
Sure.
Words.bin
(193.95 KiB) Descargado 239 veces
MESS WITH THE BEST
DIE LIKE THE REST
hammad497
Is there a way to position an element in front of the other? Like z-index? I am trying to create a WF where the tens images come on top of ones images.
Avatar de Usuario
lumenvindex
Contactar:
hammad497 escribió: 10 Sep 2019, 19:04
In some other devices there were DrawingOrder parameter in Time section. But Mi Band 4 ignored it. And the latest firmware changed ignorance to intolerance - watchfaces with this parameter don't show time at all.
MESS WITH THE BEST
DIE LIKE THE REST
fprietog
Has thanked: 10 times
Contactar:
Mensaje por fprietog »
lvpokka escribió: 08 Sep 2019, 09:05
v1.4.0
https://yadi.sk/d/hZnqJhUsUK6zow
- Added image quantization converter algorithm, it will compress image if it will have too much palette colors.
-- Will not affect RAW images. Added flag (ForceImageCompressor) to config
- If animation RepeatCount is 1, it will repeat only once
- Gif animation frames will be the same as animation image count
-- Added flag (PrettyAnimationPreview) to config
- Added new animation generator, now gif will look clean
- Fixed 8bit image usage, now it will work fine in palette mode
- bugfixes
v1.4.0 doesn't works well under linux using wine-mono 4.9.2: the .png preview files are not generated. There are the errors shown by process:
.bin to folder:
Código: Seleccionar todo
Could not load signature of ImageMagick.MagickImage:ToBitmapSource due to: Could not load file or assembly 'PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Could not load signature of ImageMagick.IMagickImage:ToBitmapSource due to: Could not load file or assembly 'PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
System.TypeLoadException: Could not resolve the signature of a virtual method
  at WatchFace.Program.UnpackWatchFace (System.String inputFileName) [0x00152] in <e2b42eaa96114c83aaf5d13095e1566d>:0
.json to bin:
  at WatchFace.Program.WriteWatchFace (System.String outputDirectory, System.String outputFileName, System.String imagesDirectory, WatchFace.Parser.WatchFace watchFace) [0x0015b] in <e2b42eaa96114c83aaf5d13095e1566d>:0
I know that using mono instead of .NET will not generate .gif preview but several .png preview files instead. It works perfectly well in v 1.3.9.
Thanks and best regards.
lvpokka
Contactar:
yeah, probably new library is not truly support mono. I will check it, thx
jmtomi
Mensaje por jmtomi »
Hi guys,
In the latest version of Mi fit app beside the usual watchfaces a new feature added where you can set the background image from your gallery for 3 predefined watchfaces and apply to your watch. The bin file created this way cannot be extracted by the tool, displays an error like parameter not found. Tried with version 1.4.0. Could you check? Shall I send the exact error or the bin file?
Thanks,
jmtomi
lvpokka
Contactar:
Check what? Did you attached bin file?
upd. discovered 3 new images. Delimiter for Time, Icon for Steps, SolidStepProgressBar.
1.4.1 is coming soon
jmtomi
I was not sure if you can create such a bin file, that's why I asked if you can check this error or shall I attach the bin file. Now I can copypaste the error:
c:\Temp\MiBandWFTool_1.4.0\PaletteImageMode>WatchFace.exe ..\..\fad3cc5b0dc07f24
e2b9c6c9d73e63e7.bin
Processing file '..\..\fad3cc5b0dc07f24e2b9c6c9d73e63e7.bin'
Opening watch face '..\..\fad3cc5b0dc07f24e2b9c6c9d73e63e7.bin'
Reading parameters...
Parsing parameters...
*************>>******[ERROR]Parameter does not exists
And I attached the bin file and the logfile too.
Thanks a lot,
jmtomi
Adjuntos
fad3cc5b0dc07f24e2b9c6c9d73e63e7.log
(330 Bytes) Descargado 179 veces
(141.84 KiB) Descargado 191 veces
Toan
Contactar:
Mensaje por Toan »
Tofuman89 escribió: 07 Sep 2019, 17:21
On the new firmware, there is a weird behaviour if there is "seconds" variable in the .json file of the WF. The seconds of the watch will be animated for the new firmware but everything else such as the steps, date, weekdays, calories, distance, heart rate will be hidden. For example is in this WF: https://amazfitwatchfaces.com/mi-band-4/view/1853 . My day to day custom WF is now somewhat broken because of this bug. Does anyone have a workaround? Thank you
No one answered you, but you're right. With MiFit app v4.0.8 seconds will now update and all the other data are not updated. As result after one second you can see only background image and time. For now I'm using MiFit app v4.0.7 and seconds are fixed like before but if someone can give us a solution, if there is one, will be very appreciated. Thank you.
lvpokka
Contactar:
solution, don`t use seconds)))
actually we don't know, please help up test
Avatar de Usuario
SinE_
Contactar:
Mensaje por SinE_ »
Hello team!
I'm not able to upload new watchfaces to my mi4, also, the watchfaces that I made before, are not visible in the "Personlanaized" tab.
Do you know if the procedure is the same?
Normally I paste the new Bin file with the presentations in a folder, in: \Phone\Android\data\com.xiaomi.hm.health\files\watch_skin_local
And they were available. Now, nothing appears. (the files are in, but MiFit App doesn't show them).
I was out about this matter for a month (Holidays time), and now, I'm lost...
Any help will be apreciated.
lvpokka
Contactar:
use https://play.google.com/store/apps/deta ... _watchface, and read manual carefully
own can be uploaded by Notify & Fitness.. please dont ask how(100% works), it's not a right place for that, just google it)
Faizan A
Mensaje por Faizan A »
hey there, I used this tool to edit a bin file for a watch face but after completing my work, I tried to compress it into a bin file again and did not succeed, I then tried to decompress the original bin file again and then recompress it without making any changes to it and it still gave me the same error.... "header.json or version file must be present in the folder with the images" how can I fix it.
Última edición por Faizan A el 18 Sep 2019, 03:10, editado 2 veces en total.
Faizan A
Adjuntos
1566890184636_packed.log
log
(414 Bytes) Descargado 175 veces
1566890184636.bin
original bin file
(301.89 KiB) Descargado 199 veces
lvpokka
Contactar:
v1.4.1
https://yadi.sk/d/qcQN824qWeP2lw
- Linux will use old GIF builder
- Other bugfixes
- New WF support
jmtomi
v1.4.1 is extracting new bin files correctly! Thanks a lot!
fprietog
Contactar:
v1.4.1 is still not generating .png preview files under linux...
- using wine-mono 4.9.2 the tool doesn't works at all:
Unhandled Exception:
System.BadImageFormatException: Could not resolve field token 0x04000004, due to: Could not load type of field 'WatchFace.Program:Logger' (3) due to: Could not load file or assembly 'NLog, Version=4.0.0.0, Culture=neutral, PublicKeyToken=5120e14c03d0593c' or one of its dependencies. assembly:H:\Descargas\RawImageMode\WatchFace.exe type:Program member:(null)
File name: 'WatchFace'
[ERROR] FATAL UNHANDLED EXCEPTION: System.BadImageFormatException: Could not resolve field token 0x04000004, due to: Could not load type of field 'WatchFace.Program:Logger' (3) due to: Could not load file or assembly 'NLog, Version=4.0.0.0, Culture=neutral, PublicKeyToken=5120e14c03d0593c' or one of its dependencies. assembly:H:\Descargas\RawImageMode\WatchFace.exe type:Program member:(null)
There is a workaround: if you move all files from new lib folder to the same folder of Watchface.exe it works.
- using mono 5.18.0.240 (not wine) the tool works with the files under lib folder.
In both cases the preview .png files are not generated... You stated that "Linux will use old GIF builder" but I guess that GIF builder never worked for mono. In the source of Watchface/Program.cs from valeronm's amazfitbiptools when mono is detected it generated .png files instead of a .gif file. You probably changed that behavior after v1.3.9 (i.e. the message "Generating previews..." isn't logged anymore from that version):
        private static void GeneratePreviews(List<Parameter> parameters, Bitmap[] images, string outputDirectory, string baseName)
            Logger.Debug("Generating previews...");
            var states = GetPreviewStates();
            var staticPreview = PreviewGenerator.CreateImage(parameters, images, new WatchState());
            staticPreview.Save(Path.Combine(outputDirectory, $"{baseName}_static.png"), ImageFormat.Png);
            var previewImages = PreviewGenerator.CreateAnimation(parameters, images, states);
            if (IsRunningOnMono)
                var i = 0;
                foreach (var previewImage in previewImages)
                    previewImage.Save(Path.Combine(outputDirectory, $"{baseName}_animated_{i}.png"), ImageFormat.Png);
                    i++;
            else
                using (var gifOutput = File.OpenWrite(Path.Combine(outputDirectory, $"{baseName}_animated.gif")))
                using (var encoder = new GifEncoder(gifOutput))
                        encoder.AddFrame(previewImage, frameDelay: TimeSpan.FromSeconds(1));
lvpokka
Contactar:
Nope 1.3.9 works same as now, i just start using new lib in 1.4.0 for gif creation... but i will check, thanks.
If someone can confirm that "GIF builder never worked for mono" then i will revert code for preview generator
hmm just check legacy code, there is png generators for mono(linux) so you probably somehow trigger IsRunningOnMono to false and its using new lib...
new code is
   generating png
else{
   if (IsRunningOnMono){   <<-- mistype)) in 1.4.1
       generating gif old lib
   }else{
      generating gif new lib
fprietog
Contactar:
lvpokka escribió: 18 Sep 2019, 22:37
If you didn't change it the way to check if it is using mono was like that:
        private static readonly bool IsRunningOnMono = Type.GetType("Mono.Runtime") != null;
You may log a debug message telling if it's using mono (or not) in order to know it for sure.
¿Did you still have this line in newer code? (routine GeneratePreviews):
I ask because that message is not logged anymore in v.1.4.0 and v1.4.1 but is logged in v1.3.9. If you haven't changed it, it should means that new versions are not reaching that line so problem may occurs before generating previews.
mysiak
Has thanked: 11 times
Contactar:
Mensaje por mysiak »
I'm sorry if this has been asked before or I missed something, but I noticed that when I extract a watch face, modify JSON file and pack it back, quality of pictures degrade significantly. Also the file size differs a lot from the original WF (original bin 120kb, repacked palette 60kb, raw 380kb). Is there some special parameter to have higher quality palette mode or smaller raw file?
Thanks in advance.
lvpokka
Contactar:
nope) limit of colors is 255, do what you want with it...
To use palette mode you can use paint.net and save it with 8 bit, or use JUST one background raw image by using raw.cfg
if you have 3 results of file size then there is 100% using mixed raw images with palette mode
Avatar de Usuario
SinE_
Contactar:
Mensaje por SinE_ »
lvpokka escribió: 16 Sep 2019, 19:46
Thanks for the info.
I "googled" a lot, and may be a didn't ask the correct question to Google.
For this reason I ask to the comunity.
regards
Responder
Volver a “Watchfaces tools”
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 21 invitados
