https://cdn1.savepice.ru/uploads/2019/8/5/6da5881f902a163d8262fb1b82a899b2-full.png
We have been working for a long time and continue to make our own Tool for watch faces.
Everything is built on these sources.
Support watch faces for devices
Amazfit Bip
Xiaomi Mi Band 4
Amazfit GTR ...
La ricerca ha trovato 10 risultati
- 08 lug 2019, 12:57
- Jump to forum
- Jump to topic
MiBandWFTool
Author
lvpokka
Tool Description
4. Mi band 5 supports 15,499,008 colors ...
lvpokka
Tool Description
- 12 lug 2019, 17:17
- Jump to forum
- Jump to topic
Re: MiBandWFTool
[mention]Anonymous86[/mention] calories not supported yet
[mention]lukbe[/mention] same problem, just added 21 weekdays 1-14 single pixel, last 7 normal
UPD>
v1.3.6
https://yadi.sk/d/7CFMjn5qSvmARA
-palette mode fix
UPD>
v1.3.6
-palette mode fix
- 15 lug 2019, 19:23
- Jump to forum
- Jump to topic
Re: MiBandWFTool
I found out a complete list of accepted parameters on a chinese forum called bandbbs. Attached, I hope it helps:
It contains 2x json files. One with Chinese explanations, another in plain format.
Also a picture showing how it looks like.
- 30 lug 2019, 22:26
- Jump to forum
- Jump to topic
Re: MiBandWFTool
I'm was trying to use a raw.cfg file but i get this error:
Found raw.cfg
[Error] Found raw.cfg but it contains unallowed characters, please use (ex. 0,1,3,4,5)
I'm using Ubuntu (Wine with Mono-gecko instead of .NET). The problem is that the editor i'm using (gedit) is always putting EOL ...
- 27 ago 2019, 16:18
- Jump to forum
- Jump to topic
Re: MiBandWFTool
Not possible...
b.t.w
v1.3.9
https://yadi.sk/d/t-gN9dmQN4myzA
- Calories rendering fixed
b.t.w
v1.3.9
- 08 set 2019, 09:05
- Jump to forum
- Jump to topic
Re: MiBandWFTool
v1.4.0
https://yadi.sk/d/hZnqJhUsUK6zow
- Added image quantization converter algorithm, it will compress image if it will have too much palette colors.
-- Will not affect RAW images. Added flag (ForceImageCompressor) to config
- If animation RepeatCount is 1, it will repeat only once
- Gif animation ...
- Gif animation ...
- 10 set 2019, 23:59
- Jump to forum
- Jump to topic
Re: MiBandWFTool
yeah, probably new library is not truly support mono. I will check it, thx
- 18 set 2019, 08:18
- Jump to forum
- Jump to topic
Re: MiBandWFTool
v1.4.1
https://yadi.sk/d/qcQN824qWeP2lw
- Linux will use old GIF builder
- Other bugfixes
- New WF support
- Other bugfixes
- New WF support
- 18 set 2019, 22:37
- Jump to forum
- Jump to topic
Re: MiBandWFTool
Nope 1.3.9 works same as now, i just start using new lib in 1.4.0 for gif creation... but i will check, thanks.
If someone can confirm that "GIF builder never worked for mono" then i will revert code for preview generator
hmm just check legacy code, there is png generators for mono(linux) so you ...
