Bip 6 custom watchface question
Moderatori: asoo, Watchmens
Alphay2k
Messaggio da Alphay2k »
So I recently bought a bip 6 watch. I LOVE the battery life but I am having some issues with making my own watch face. What I want is very simplistic, I want a background, time in 12 hr format ie: 9:00 and not 09:00, date, month, and year, and battery percent.
I spent a big part of the day yesterday trying to get things working like I want them but running into snags.
I am a simpleton at heart so the simpler the better, and point and click is good for me.
So with the zepp edit site I noticed it needs some sort of files uploaded or to choose from, and I'm not sure where to get those. Yes I realize I can make my own but as stated I can't figure out how to even make my own to use without doing a lot of fanegling a lot of stuff.
So that given (and I hope I haven't missed anything) I just want a simple easy way to make a simple watchface and wondered if anyone had any solutions or other solutions without having to go thru a bunch of hoops or file manipulation or even uploading.
Drag and drop like time or date or even selecting it without having to upload like fonts would be awesome, or maybe someone could give me a link to the file(s) I need to use to download and to pick from to upload
I want to keep this watch so so badly but if I have to do a bunch of work just for a warchface it's not worth it to me
As a side note I created a watch face and it works very nice, with amazfit watchface editor for android, problem is it only has the leading 0 so I get 09:00 instead of 9:00 even if the watch is set to 12 hr format, other than that the watchface works perfect just can't get the hrs as 12 hr instead of 24 hr format.
So all this given if anyone has any ideas I would greatly appreciate the help
Has thanked: 419 times
Been thanked: 2109 times
Messaggio da asoo »
Alphay2k ha scritto: 17 ago 2026, 18:00
1. You should attach the watch face file you created, as you mentioned, so that those who need help can get an overview of the problem you're asking about.
2. Basically, as I understand it, you want to display the time in H:MM format and are looking for resources to create the watch face (if I understand correctly).
-- 2.1 To create a DigitalHour display where hour digit is shown in H:MM format:
There are actually several ways to do this, but the easiest way is to set it to display without leading zeros in the time widget. However, I'm not sure your editor has a this function or not . If not, you'll have to edit the script yourself. I'm also unsure what format your index.js is in, whether it's encrypted or not. An encrypted index.js file after packaging might be difficult to modify. Or, the easiest way is to try searching... An editor capable of performing this function for example, "Watch face editor for Amazfit watch on ZeppOS" by SashaCX75 for Windows.
Example
-- 2.2 How can find resources to create watch faces. You can do this in several ways:
---- 2.2.1 Find from watch faces you are interested in by unpacking and bring the images or other resource to use create your watchface.
---- 2.2.2 Generate by creating the desired text or characters as a PNG image.
Tools available include:
or
Hopefully, this information will be somewhat useful to you.
MarioLie
Has thanked: 50 times
Been thanked: 32 times
Messaggio da MarioLie »
And if you need to create any images, just use a program to create them. Images must be saved in PNG-24.
https://www.photopea.com/
