- Amministratore
Alexa watchface for balance 2
SleepyHollow
- Has thanked: 23 times
- Been thanked: 2 times
- Contatta:
Hello to all. Can someone from the creators help me to make this watchface for balance 2 because i try with editor to convert myself but a error message appear when unpack the watchface. I want it as it is with only change the date and make it ddmmyy and replace alexa logo with start an exercise button-icon. Thank you for support. This is a zepp watchface.
https://ze.mmk.pw/view/7864576/106187/null
- Has thanked: 418 times
- Been thanked: 2099 times
Understand before downloadingSleepyHollow ha scritto: 05 ago 2026, 06:35Hello to all. Can someone from the creators help me to make this watchface for balance 2 because i try with editor to convert myself but a error message appear when unpack the watchface. I want it as it is with only change the date and make it ddmmyy and replace alexa logo with start an exercise button-icon. Thank you for support. This is a zepp watchface.
Fixed issue weather index not correct from watchface original :
Note : Temp. pointer use custom script so widget not show on preview but it will show on real device
SleepyHollow
- Contatta:
SleepyHollow
- Contatta:
Can you check the weather icons because here now is sunny day and watchface shows cloudy night. Thank you.
The original watchface the weather icons are not arranged correctly, and I bring it to use without check , because I thought the official watch face wouldn't have this kind of misalignment problem. causing this problem. I will fix it if I finish my work. Or, if you know how to use an editor, you can unpack, rename the icons to meet the standard, and then repack them, and they should work.SleepyHollow ha scritto: 05 ago 2026, 11:28Can you check the weather icons because here now is sunny day and watchface shows cloudy night. Thank you.
issue fixed :
viewtopic.php?p=22583#p22583
SleepyHollow
- Contatta:
