Alexa watchface for balance 2
Moderatori: asoo, Watchmens
SleepyHollow
Has thanked: 23 times
Messaggio da SleepyHollow »
Hello to all. Can someone from the creators help me to make this watchface for balance 2 because i try with editor to convert myself but a error message appear when unpack the watchface. I want it as it is with only change the date and make it ddmmyy and replace alexa logo with start an exercise button-icon. Thank you for support. This is a zepp watchface.
https://ze.mmk.pw/view/7864576/106187/null
Has thanked: 418 times
Been thanked: 2099 times
Messaggio da asoo »
SleepyHollow ha scritto: 05 ago 2026, 06:35
Fixed issue weather index not correct from watchface original :
ZeppHealth1001539_480x480_Fixed_WeahterIndex.zip
(191.74 KiB) Scaricato 6 volte
Note : Temp. pointer use custom script so widget not show on preview but it will show on real device
SleepyHollow
Awesome! Exactly what I need. Thank you, asoo.
SleepyHollow
Can you check the weather icons because here now is sunny day and watchface shows cloudy night. Thank you.
Messaggio da asoo »
SleepyHollow ha scritto: 05 ago 2026, 11:28
The original watchface the weather icons are not arranged correctly, and I bring it to use without check , because I thought the official watch face wouldn't have this kind of misalignment problem. causing this problem. I will fix it if I finish my work. Or, if you know how to use an editor, you can unpack, rename the icons to meet the standard, and then repack them, and they should work.
Weather icon index
issue fixed :
viewtopic.php?p=22583#p22583
SleepyHollow
Thank you for the fix!
