Help with recreating Epix watchface [Trex 3 pro 44mm]
Nit0
Post by Nit0 »
Hi!
Found a few Garmin-inspired watchfaces on this website, but the one that has really caught my eye is one of the stock offerings for the Garmin Epix pro 2.
Has anyone come across a watchface similar to this or can it be made?
I have no idea how hard it is to replicate. Tried to look up how to use the Amazfit watchface editor, but im at a loss...
Does not need to be exactly the same datafileds and logo, but I like the way the watchface accentuates the side buttons. I also like the amber red colorway.
My Trex 3 pro 44mm has 466x466 resolution.
Thankful for any and all replies/help!
Has thanked: 441 times
Been thanked: 2142 times
Nit0 wrote: 08 May 2026, 20:08
Hi!
Preview and download
Epix_pro2_T_Rex_3_Pro_44mm.zip
(132.26 KiB) Downloaded 75 times
Nit0
Post by Nit0 »
asoo wrote: 09 May 2026, 12:16
Hi!
Wow, Thanks! I have only installed faces with qr-code before. How to I install this with the downloaded files?
Nit0 wrote: 09 May 2026, 12:27
You can read How to install watchface to your device in this link :
QR Code for install
Alternatively, you can install it via this QR code.
The file is hosted on catbox, which may sometimes experience high user traffic, preventing installation. Please wait a while and try again.
Nit0
Post by Nit0 »
asoo wrote: 09 May 2026, 12:41
QR Code for install
I uploaded it so that more users can get it. Seems to work just as intended. Huge thanks again!
Nit0
Post by Nit0 »
QR Code for install
Hesitant to ask since you had a disclaimer on further adjustments, but I really like this watchface and want to use it permanently. Kind of regret not asking for weather or anything other useful than HR and biocharge since I have tattoos and the hrm does not work on me. I use a Helio strap instead for that but it does not sync with the watch.
How much hassle would it be to switch hr to weather temp and biocharge with calories for a cleaner look?
Cheers!
Nit0 wrote: 09 May 2026, 15:16
Cheers!
Based on your request, I will do it. I believe this new version will be more useful to you than the previous one. However, I will not be making any further changes to the completed work.
Epix_pro2_T_Rex_3_Pro_44mm_Nit0.zip
(168.01 KiB) Downloaded 58 times
Nit0
Post by Nit0 »
asoo wrote: 09 May 2026, 16:20
Cheers!
You, good sir, are awesome!
If I want to change the primary color of the face in the future, is it something a novice like me can tweak relatively easily using the content in the zip file or do I have to replace/redo all the bars in the corners? Im guessing the bottom graph is static background picture?
Cheers from Sweden.
Nit0 wrote: 09 May 2026, 16:36
Cheers!
Cheers from Sweden.
Yes, graph is a background, you can unpack the watchface and edit images
you can use sasha's editor to unpack .
link editor : viewtopic.php?p=11643#p11643
Nit0
Post by Nit0 »
Newbie question: I tried messing with the tool you linked. I can open the project fine and move around the different data points. I gave up on trying to change the color of the background graphics in the app. I guess I can try to change the hue with a photo editor but I can not open the png file bg1 in the folder with any software on win11. Says the bitmap file is not valid. Is it possible the file is corrupt/locked or am I missing something obvious? Usually I can open PNG and JPEG etc. without any issues.
I would also like to crop the Garmin logo and ring around the image to make the image bigger and more legible. I should be able to do that also with a photo editor?
Can you perhaps share the original background image used so I can change it and import it into the project instead?
Sorry for all the questions!
Nit0 wrote: 10 May 2026, 07:28
you must unpack watchface before , because png in watchface is not normal png can not edit by normal graphic editor , after you unpack watchface by use sasha's editor, you will have "assets" folder and png i that folder is normal png ,
if you unzip watchface by use normal zip , the file png in folder "assets" is a encode "png" , so you can not edit it.
So you mush unpack by sasha's editor and edit image in folder "assets" that you want and pack to watchface by use sasha's editor
PS. The PNG files obtained from unpacking with Sasha's Editor will be standard PNG files that can be edited. However, after editing, if you want to use them in a watchface, please use Sasha's Editor to pack them, as the packing process requires encoding the PNG to match the device's specific standard
Nit0
Post by Nit0 »
asoo wrote: 10 May 2026, 12:18
This took far more time than I care to admit but I've tried to adjust the watchface to my liking but some parameters I just can't wrap my head around. The inverted big grey bar-thing that you made to cover the horisontal bars for progress is hard for me to replicate and I can't figure it out. I tried to change it to fat burning time but it does not seem to work. I want to change it to PAI-progress instead but the bar gets messed up everytime I try to add it. Added it in color to see the problem easier but want it in transparent black like before.
Also added sunrise and sunset but can't get the numbers to wrap around the watch like the other ones you added... Can you perhaps take a look at the upload and see if you understand what i'm trying to do and how to fix it?
https://amazfitwatchfaces.com/t-rex/view/18618
Cheers!
Nit0 wrote: 13 May 2026, 20:17
Cheers!
I not found you watchface, maybe your watch face may not pass the verification process because it may not meet the requirements.
I recommend that you attach the file in the post.
I will review it once I receive it.
Nit0
Post by Nit0 »
asoo wrote: 13 May 2026, 23:46
Cheers!
epix_2_pro_trex_3_pro_44mm-877937-5e44f6d8f0.zip
(254.66 KiB) Downloaded 57 times
Nit0
Post by Nit0 »
The moon icon was just me trying to find a fitting symbol for sunrise/sunset with the stuff you have added. If you have a more fitting symbol I would gladely take it.
Cheers!
1. Change line progress Fat Burning to PAI week
2. Fixed some calories line progress
3. Fixed some layout
4. Change Sun rise/set to use display text in a circle
If the layout is incorrect on the clock, you'll need to make further modifications yourself, as I cannot test it because I don't have the device you're using.
Epix-2-pro-Trex-3-pro-44mm.zip
(245.09 KiB) Downloaded 54 times
Nit0
Post by Nit0 »
asoo wrote: 14 May 2026, 02:56
Cheers!
Thank you! Finally I can wear it and just enjoy it without thinking about improvements. ;)
