Requesting creation of watch face [Bip 6]
Hi gurus,
Bozy posted a sweet watchface inspired by the huawei fit 4, and it looks fantastic! My gripe with it is
( 1 ) there is no AOD,
( 2 ) if the green background could be replaced with black, and
( 3 ) the general colour could be switchable with other colours.
https://amazfitwatchfaces.com/bip/view/44837
Here is a version of it which i used Ai to modify.
If a kind capable soul could help achieve this, it would be mucho appreciated!
- Has thanked: 436 times
- Been thanked: 2137 times
This watch face is actually not difficult to create. However, this watch face uses a certain level of code obfuscation in the index.js file, which may suggest that the original creator does not intend for the work to be modified. Therefore, I would recommend obtaining permission from the original creator before submitting a request on the forum to modify it, or alternatively asking the creator to consider implementing the changes you would like.mojo25 wrote: 17 Apr 2026, 11:52Hi gurus,
Bozy posted a sweet watchfatch inspired by the huawei fit 4, and it looks fantastic! My gripe with it is
Thanks for trying Asoo! I've tried hinting at AOD on his page, so i'll keep my fingers crossed!
MarioLie
- Has thanked: 56 times
- Been thanked: 37 times
It will be a tough nut to crack, hopefully I'll manage to fulfill your dream. I just don't know how I'll do that AOD calendar display. I don't have time at the moment to do AOD display. If anyone wants to continue in this development, I will give you the needed files.mojo25 wrote: 17 Apr 2026, 11:52Hi gurus,
QR codes generated by the web system often have a time limit for use, so the QR code you are displaying may not be valid to use.
Therefore, if you are going to create a QR code for zpk installation, it is recommended to use https://catbox.moe/ to upload the .zpk file.
You can read more at
This is the QR code for installing Mojo 25 via Catbox.
Xphyle1971
- Has thanked: 4 times
- Been thanked: 7 times
Hello. I'm just jumping in on this conversation. This is a very nice watchface. I just downloaded it to my Bip Max. But the temperature reading looks to be off-center, and the number is too big and overlaps on top of the nighttime icon which looks sloppy/too busy. Is it possible to center the number better and fix the overlap? See pic for reference. Thank you so much!MarioLie wrote: 17 Jun 2026, 05:51
MarioLie
As you can see in the picture, the temperature indicator is centered in the middle of the picture and you have to count with the display of - a °Xphyle1971 wrote: 19 Jun 2026, 09:39Hello. I'm just jumping in on this conversation. This is a very nice watchface. I just downloaded it to my Bip Max. But the temperature reading looks to be off-center, and the number is too big and overlaps on top of the nighttime icon which looks sloppy/too busy. Is it possible to center the number better and fix the overlap? See pic for reference. Thank you so much!MarioLie wrote: 17 Jun 2026, 05:51
Try version 1.0
Xphyle1971
I understand that you are using the degree indicator as part of the centering process, but I don't believe you should. The number only should be centered on the center line. In the picture you have posted, the 18 should be directly under the 21, but it's shifted to the left because you are incorporating the degree symbol into the calculation. Just center the numbers. I think that most people would agree that this looks wrong even if the guy who requested the watch face specifically requested this. Great watch face, thought.
