Verified authors ✅
Questions about the main site. Authorship questions.
Moderator: Internal error
Has thanked: 1136 times
Been thanked: 275 times
Verified authors ✅
  1. Advertising is not displayed for this group of authors.
  2. An author may specify a link to PayPal or other ways to collect donations when uploading the work on the website.
  1. You need to have a minimum of 10 completely different works uploaded on our website.*
  2. Your works have to be popular on the site (based on “Last month TOP” or/and “Last year TOP”).
  3. All posted works should have a completed description and correct tags.
  4. The author should respond to comments under his/her work.
*Watch faces that are ported from other watches or copies of watch faces from famous brands of watches or smartwatches will be not considered.
Applications are processed within 5-10 days and the author receives a response in any case (either positive or negative).
Want to protect your original work?
  • Submit your application here.
minixperia
Post by minixperia »
GIK-Team wrote: 10 May 2023, 08:47
minixperia wrote: 10 May 2023, 05:50
Hello! I want to become part of the group of verified authors. Thank you!
Now i can be a part of the verified authors?
all my work have too be popular?
minixperia wrote: 25 May 2023, 17:23
supershallow
Post by supershallow »
i would like to apply for a verified user. Thanks.
supershallow wrote: 28 Nov 2023, 17:34
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Hey, can I join to elite? ;)
TRK88PL wrote: 16 Feb 2024, 19:13
Omaradsl
Has thanked: 16 times
Been thanked: 8 times
Post by Omaradsl »
I posted just a couple of watchfaces :)
I can join in group?
Omaradsl wrote: 16 Aug 2024, 14:04
Yep ✅
ktomcat
Post by ktomcat »
Hello! I'd like to join the club, if it's possible
Drongo
Watchmen
Has thanked: 34 times
Been thanked: 12 times
Post by Drongo »
ktomcat wrote: 15 Oct 2024, 17:10
To join the group, you need to meet all the rules described in the first post of this thread. So far, you have only partially passed. Keep working and you can apply again later. Thank you.
ktomcat
Post by ktomcat »
Drongo wrote: 15 Oct 2024, 18:49
Thank you for the reply, u mean the only thing im missing is i need to have 10 watchfaces uploaded, right?
Drongo
Watchmen
Post by Drongo »
ktomcat wrote: 16 Oct 2024, 08:36
Here is the rules:
  • You need to have a minimum of 10 completely different works uploaded on our website.*
  • Your works have to be popular on the site (based on “Last month TOP” or/and “Last year TOP”).
  • All posted works should have a completed description and correct tags.
  • The author should respond to comments under his/her work.
ktomcat
Post by ktomcat »
Thank you I've seen it thats why i was wondering which part im not passing. I guess the completely different watchface part goes for me now, cause im passing everything else
Rorov
Post by Rorov »
Hello, can I join the group Boss?
Rorov wrote: 22 Dec 2025, 09:31
frankh93
Has thanked: 23 times
Post by frankh93 »
Hi, may I join the selected group? Thank you :D
frankh93 wrote: 18 Mar 2026, 01:20
hakanerturk
Post by hakanerturk »
Merhaba, gruba katılabilir miyim? Saygılarımla.
Her şeyin bir kolay yöntemi vardır! [HE]
hakanerturk wrote: 18 Mar 2026, 09:47
Merhaba,
İlginiz için teşekkür ederiz :)
Şu anda gruba katılmak için bazı kriterlerimiz var:
  • Sitemizde en az 10 farklı watchface yayınlanmış olması
  • Çalışmaların popülerlik kazanmış olması (örneğin “Last month TOP” veya “Last year TOP” listelerinde yer alması)
Şu an için bu kriterler henüz tam karşılanmamış görünüyor, ancak bu bir ret değil ;)
Biraz daha paylaşım yapıp çalışmalarınız öne çıktıkça sizi memnuniyetle gruba ekleyebiliriz.
Çalışmalarınızı görmekten mutluluk duyuyoruz — devam edin!
Return to “amazfitwatchfaces.com site/catalog”
