- Administrador
TSWF04 Garmin on T-Rex 3
Regras do fórum
Ricardo.cz
- Registrado em: 31 Out 2024, 17:24
- Has thanked: 10 times
- Been thanked: 9 times
- Contato:
- Registrado em: 03 Jan 2019, 01:48
- Has thanked: 419 times
- Been thanked: 2115 times
This watchface has some widget that are different from the original.
Top image progress is Humidity. Top image progress is sunrise , sunset
QR Code :
viewtopic.php?p=21699#p21699
MarioLie
- Registrado em: 12 Mai 2025, 19:37
- Has thanked: 50 times
- Been thanked: 32 times
- Contato:
Here is your dream look.
- Anexos
cz_T_Rex_2.zip- (244.3 KiB) Baixado 107 vezes
cz_Trex_3_PRO_48mm.zip- (180.24 KiB) Baixado 140 vezes
cz_T_REX_3.zip- (180.4 KiB) Baixado 120 vezes
Editado pela última vez por MarioLie em 02 Dez 2025, 18:56, em um total de 1 vez.
Ricardo.cz
- Contato:
danielmartis
- Registrado em: 27 Fev 2025, 16:57
- Has thanked: 3 times
- Been thanked: 2 times
- Contato:
danielmartis
- Contato:
You simply download the file you need,
then upload it to this website using your ID, and you can install it via the QR code that the website generates for you.
https://amazfitwatchfaces.com/upload
Or try this QR code. The file in this QR code is located at https://catbox.moe/. In some countries, it may not be accessible, or the website may be unavailable at certain times. Therefore, if you cannot install it, you will need to upload it yourself as previously instructed.
Quem está online
