buttons don't work
marrud12
buttons don't work
Post by marrud12 »
I have some questions about "hmApp.startApp" on my Active 2(NFC), all installed by V14.1.1 in the "Buttons"-menu from pulldown without changes.
What should do Respiration (url: 'RespirationControlScreen')? When I click the button, nothing happens.
The same problem with Breathing ({url: 'RespirationwidgetScreen', both in "Activities".
Also the App World Time (hmApp.startApp({url: 'WorldClockScreen') does nothing. In watch menu I can select worldclock and it works, but the button doesn't call it.
All this apps should work, but don't, because they are exactly like this in the firmware-files.
Other apps like Calendar, Alarm, BaroAltimeter, Compass, Sun etc. work fine.
Does somebody know how to call navigation-screen by "Button"?
PS: Also on Lattenknaller's "Illuminator Active 2" World Time (tap on analog watch) doesn't work...
Been thanked: 1029 times
In the new firmware, the World Time app is not part of the firmware but is installed as an external programme. Therefore, the path to launch it has changed. I think the same problem applies to Breathing.
I thought I had added new buttons in the latest version of the editor. But now I looked and it turns out they are missing somewhere.
hmApp.startApp({ appid: 1049670, url: “page/wclk_showLayer”}) - start world time
For breathing appid: 1053484
And url can take the following values
"page/gt/home/index.page",
"page/gt/help/help.page",
"page/gt/result/result.page",
"page/gt/start/start.page",
"page/gt/select/select.page",
"page/gt/measure/measure.page",
"page/gt/setting/setting.page",
"page/gt/edit/edit.page",
"page/gt/week/week.page",
"page/gt/repeat/repeat.page"
I haven't checked which of these actually works. You can check for yourself and write about it here.
marrud12
Post by marrud12 »
Thanks for this answer for World Time, but first, instead a watchface, only a black screen on the watch...
Your hmApp... is wrong with double quotes, only singe quotes allowed + a semicolon at the end:
hmApp.startApp({appid: 1049670, url: 'page/wclk_showLayer'});
like this it works.
World Time works fine, but your urls for breathing appid: 1053484 all do nothing...
Do you know a command for navigation-screen?
marrud12 wrote: 05 Sep 2025, 22:55
Actually, that's not entirely true. Semicolons are not required at the end. Double quotes can be used in the code. But if you add code via the editor, double quotes are converted to another character due to data storage features, and this causes an error. I will try to fix this in future versions.
It works. Just not quite the way I would like it to. The most suitable command is
hmApp.startApp({ appid: 1053484, url: “page/gt/home/index.page”})
This application was not installed on my watch by default, so I had to download it from the store. Please check that it is installed on your device. It has been tested on Balance 2 and Active 2 Premium.
Show a screenshot to understand what is meant.
marrud12
Post by marrud12 »
Now it works with the downloaded app. It would be fine if you write, e.g. in "Tips for use", what App from the store is needed for a function.
Active 2 premum has a navigation screen (map) and I am looking for a function for a button to call it.
Try the command
hmApp.startApp({url: 'OfflineMapScreen', native: true });
Return to “Zepp OS”
