Mi Create - for Mi Band 7 Pro/8/9/10, Mi Watches & Redmi Watches
tostr
Been thanked: 14 times
Post by tostr »
Mi Create
Open source watchface editor for Xiaomi wearables made ~2021 and above
Modern watchface creator for new Mi Bands, Xiaomi Watches and Redmi Watches. Spiritual successor to EasyFace, with compatibility for EasyFace .fprj projects.
  • Simple & good looking
  • Easy to learn (especially for EasyFace users)
  • Support for .fprj projects
  • Experimental support for Chinese GMF (wfDef.json) projects
  • Quick AOD creation
  • Live watchface preview
  • Multilingual
Runs on Windows (and Linux if you run from source code)
Requires 64-bit versions of Windows 10 (1809 and later) or Windows 11
Guides at https://ooflet.github.io/docs
Download from Github https://github.com/ooflet/Mi-Create/releases/latest
Mi Create is unofficial and is not involved with Xiaomi.
Xaobaco
Post by Xaobaco »
I have designed a dynamic face for mi banfd 9 on mi create, but mi create only allows importing fprj files and exporting json files but not exporting bin files. So how can I export bin files to upload to amazfitwatchfaces?
tostr
Post by tostr »
@Xaobaco The build button is used to export as a bin file https://ooflet.github.io/docs/quickstar ... atchface_1
Xaobaco
Post by Xaobaco »
I already have the .bin file. Now how do I put it on the Mi Band 9 watch face?
tostr
Post by tostr »
@Xaobaco The easiest way is to use Notify for Mi Band or Gadgetbridge, but if you want to share it with others other than using AmazfitWatchFaces you can follow the steps on https://ooflet.github.io/docs/quickstart/publishing/ to publish them onto m0tral's servers.
xpdev
Post by xpdev »
Hi
great software.... there is a way to edit an existing watch face as happens with other software for xiaomi watch ?
thank you
tostr
Post by tostr »
@xpdev You can use the unpacker program to decompile watchface binaries https://github.com/ooflet/Mi-Create/dis ... t-11529953. From here, you can open and edit as you would a normal fprj project.
Mario7643
Post by Mario7643 »
Hi. In the latest version, is there no option for 'distance in kilometers'? Or I just can't find it. I'm using the smart band 10. By the way, how many digits should there be in the Appearance settings - digits? regarding distance?
tostr
Post by tostr »
@Mario7643 The source simply hasn't been added to Mi Create's data files yet, you should be able to manually add it in by replacing Mi Create's source file (%LocalAppData%\Mi Create\data\sources.json) with this one https://github.com/user-attachments/fil ... urces.json which has the Current Steo (kilometer) data source.
The digits need to be set manually to multiples of 10 depending on how many decimals you want, 20 for 1 decimal point, 40 for two. The digit count has a hard limit of 20 digits, so refer to this comment https://github.com/ooflet/Mi-Create/iss ... 3097570014 to change the limit (the file should be in Mi Create's data folder as well in data\fprj)
Witamamy
Post by Witamamy »
Any compatibility for Redmi watch 6?
Users browsing this forum: Baidu [Spider] and 2 guests
