Search found 3 matches
Return
by paulonardi
12 Sep 2024, 12:01
Jump to forum
Jump to topic
Re: Mi Create - for Mi Band 7 Pro/8/9, Mi Watches & Redmi Watches
Now it works (just need to delete the digits and do it again to work)!
Thanks! And congrats for your work on that app.
by OneWatchface
18 Jun 2024, 12:10
Jump to forum
Jump to topic
Re: Need opinions for my new application
tostr Thank you for the quick reply and the example project. Your explanation was plenty and it worked like a charm.
I think your tool is a great add on for the custom watchface community. I didn't install EasyFace due to some concerns but I was really happy when I found yours. Unfortunately I ...
by NotOnlyEyes
03 Aug 2024, 15:32
Jump to forum
Jump to topic
<?xml version="1.0" ?>
<FaceProject DeviceType="12">
<Screen Title="moto_test" Bitmap="preview.png">
<Widget Shape="30" Name="background" X="0" Y="0" Width="240" Height="280" Alpha="255" Visible_Src="0" Bitmap="background.png" />
<Widget Shape="32" Name="38_num_hourHigh" X="20" Y="96" Width="45 ...
