Why can't I open Watch_Face_Editor_(ZeppOS).exe?
Wetodd1024
Post by Wetodd1024 »
I've been all over the forum looking for help so I'm sorry if this has already been addressed.
Not sure what I'm doing wrong but when I double click on Watch_Face_Editor_(ZeppOS).exe it does nothing. I put in in programs, c: on my desktop.
Any suggestions would be appreciated!
Been thanked: 2125 times
Wetodd1024 wrote: 21 Aug 2025, 01:37
I'm not sure what issue you're experiencing, but if you're using Windows 11, I recommend trying this thread.
viewtopic.php?p=20820#p20820
Wetodd1024
Working!!! Thank you so much!
Wetodd1024
Now that it's working...
When I go to select an image to use all I get is a line...
Thanks again for all the help!
Wetodd1024 wrote: 21 Aug 2025, 11:04
From the image you sent, it seems like you don't have any images in the "assets" folder. When you selected an image, the problem occurred as you described.
However, I'm curious as to why your preview displayed that way. Where did the numbers in the preview come from?
Next time, if you want to ask a new question that is not related to the original topic, I suggest you open a new topic.
Wetodd1024
Sorry about that. Will do. Thanks again for the help.
The numbers are 'Hours in Font'.
