Edit Background
marrud12
Edit Background
Post by marrud12 »
In Zepp WatchfaceMaker, when I delete a background of a selfcreated watchface and reload it with little changes, so it is in foreground and covers all digits, pointers and images created before.
How can I put the new background behind digits etc. to continue editing?
Has thanked: 414 times
Been thanked: 2073 times
marrud12 wrote: 04 Aug 2025, 09:30
If I guess correctly, your problem is likely caused by
when you delete the background and re-add it, you'll notice that it's placed at the top, meaning it wil show on the top of all elements. So, you need to move the background to the end of the line.
Preview issue
marrud12
Post by marrud12 »
Thanks, so simple, now it works!
