Show digital minutes on analog minute Hand
Moderatori: asoo, Watchmens
ativirs
Has thanked: 9 times
Messaggio da ativirs »
I am trying to create a watchface where I have digital hours but an analog minute hand. I want to show digital minutes on the analog minute hand at the end . the minute should work similar to Asoo's Combat watchfaces seconds hand. Can anyone help me to achieve this?
I have created 60 images for the minues and have added those to a folder. I tried to reverse engineer the script in the Asoo's Combat watchface, but unable to get it to work.
Any help will be appreciated
Has thanked: 419 times
Been thanked: 2110 times
Messaggio da asoo »
ativirs ha scritto: 30 lug 2025, 13:49
From the message you sent, I believe it would be difficult to address the issue on your watchface.
Therefore, if you would like me to investigate any issues, I suggest you attach the project in which you encountered the issue so that those who wish to assist you can review it.
