Unpack Bip 6 Watchfaces
- frankh93
- Has thanked: 23 times
- Been thanked: 3 times
I got to know about mmk site where I can download the zip file of a certain watchface I wanna mod (https://mmk.pw/en/zepp_explorer/explorer/watch) but when I tried to unpack it using Sasha's tool it says I wasn't able to cause it is encrypted, so I wanna ask... There is another way to do this? Thank you
you should be doing something productive instead of reading this caption
- Has thanked: 414 times
- Been thanked: 2071 times
If the script file is encrypted, the editor will not be able to unpack it. However, when you unpack it, you will get the entire image of the watchface.frankh93 wrote: 25 Jul 2025, 20:59I got to know about mmk site where I can download the zip file of a certain watchface I wanna mod (https://mmk.pw/en/zepp_explorer/explorer/watch) but when I tried to unpack it using Sasha's tool it says I wasn't able to cause it is encrypted, so I wanna ask... There is another way to do this? Thank you
Then you must to use that image to create a new watchface . As far as I know, this is the only way to create a watchface where the script is encrypted.
- frankh93
tysm @asoo, i thought as it was saying the script was encrypted the resources wouldn't be unpacked neither, but I just tried again and it worked.
