Правила форуму
Аватар користувача
Been thanked: 1044 times
Контактна інформація:
Повідомлення SashaCX75 »
v18.1
Version 18.1
Востаннє редагувалось 10 вересня 2026, 17:16 користувачем SashaCX75, всього редагувалось 54 разів.
Аватар користувача
You do not need to repack the watch face. You just need to insert the files into the watch face with replacement of the existing ones. Then the compression type of the archive will not change and everything will work.
In the editor there are explanations in which part of the code different js files are inserted. If it is not clear, you can just insert a comment with the name of the file in place of the code and then in the watch face to see where this fragment appeared.
Imozeb
З нами з: 27 червня 2025, 14:15
Повідомлення Imozeb »
Thanks for all your help. I've manage to get static text to display on the screen; however, the text will not update. Is there a specific location that I should put my event listeners or function calls?
This is how I currently have it:
user_functions.js:
Код: Виділити все
   // 1 User Functions (Include All User Functions Here)
   const updateCalories = () => {
      	caloriesText.setProperty(hmUI.prop.MORE, {
        	text: "test"
user_script_beforeShortcuts.js:
Код: Виділити все
    // Create the activity sensor
    const activitySensor = hmSensor.createSensor(hmSensor.id.ACTIVITY);
    // Create a text widget to display calories / 2.5
    const caloriesText = hmUI.createWidget(hmUI.widget.TEXT, {
      x: 219,
      y: 227,
      w: 78,
      h: 30,
      color: 0xFF00FF00,
      text_size: 25,
      align_h: hmUI.align.CENTER_H,
	  align_v: hmUI.align.CENTER_V,
	  text: "...",
	  marquee: false,
    // Listen for changes and update automatically
    activitySensor.addEventListener(hmSensor.event.CHANGE, () => {
	     updateCalories();
I expect the displayed text to be "test" not "..." after a short amount of time, but it stays as "..."
If I simply call updateCalories(); without the event listener, the rest of the code never runs and the rest of the watchface (e.g. time) does not display.
Аватар користувача
Make the caloriesText variable global. Like other widgets.
In the caloriesText widget it is desirable to specify on which screen it works, main or AOD. This doesn't affect its operation but may help to avoid some problems. Also I don't remember that this widget has a ‘marquee’ parameter.
The code in the watch face only works if the screen is on. So the event.CHANGE event will happen only if the AOD is enabled. If AOD is not used, it is easier to update data only when the screen is switched on. If AOD is used, it is necessary to add screen type check and update only widgets displayed on this screen.
It seems to me that steps are updated more often than calories. So I would use the steps sensor for testing. And then when the code is debugged and working change the sensor type to the required one.
Imozeb
Thanks.
So now I have gotten it to display "5" on the screen from "resume_call.js" below.
I would like to display the actual calories divided by 2, but I am not sure to do that. From what I read, I cannot get the actual calories value when the watch display resumes. Is this true?
I tried pulling calories from the "distanceSensor.addEventListener(hmSensor.event.CHANGE, function()" in "user_script_beforeShortcuts.js", but that never seems to execute. See my test script below where it should display "10" instead of "5" when the watch face resumes.
I have also tried pulling calorie.current from a different sensor and that did not work either.
Thanks again!
Other Calorie Sensor Generated From Your Editor
Код: Виділити все
            const calorie = hmSensor.createSensor(hmSensor.id.CALORIE);
            calorie.addEventListener(hmSensor.event.CHANGE, function() {
              scale_call();
user_function.js
Код: Виділити все
// 1 (user_functions.js)
			// MY GLOBAL VARIALBES
			let caloriesText = ''
Код: Виділити все
// 4 (user_script_beforeShortcuts.js) (Include all display text, event listeners here)
      x: 219,
      y: 190,
      w: 78,
      h: 25,
      color: 0xFF00FF00,
      text_size: 25,
	  text: "...",
    const distanceSensor = hmSensor.createSensor(hmSensor.id.DISTANCE);
    distanceSensor.addEventListener(hmSensor.event.CHANGE, function() {
        // Update display here
        //updateCalories(data.calories);
        updateCalories(10)
user_script_end.js
Код: Виділити все
// 5 (user_script_end.js) (Include all function definitions here)
// MY FUNCTIONS
	function updateCalories(calories) {
                console.log('updateCalories()');
                    //let valueCalories = calorie.current
                    //let adjustedCalories = Math.floor(valueCalories / 2.5);
                    // Update Calories Text
                        //text: String(adjustedCalories)
                        text: calories
resume_call.js
Код: Виділити все
// 6 (resume_call.js) (Calls once when watchface turns on)
                updateCalories(5);
Imozeb
Also, is there any way that I can edit the code generated from your program directly and rezip it with the proper compression for uploading? It looks like if I add my code to your "function scale_call()", it would work.
Аватар користувача
I don't see where you defined the screenType variable.
I recommend changing the value in ‘packageInfo’ to “mode”: ‘development’ in the app.json file. This will allow you to view the logs. It will be easier to understand what the error is.
Imozeb
SashaCX75 писав: 05 липня 2025, 14:33
I managed to get it working. Now I am going to program the equations.
Thank you for all your help!
Imozeb
One question. Do you know if it is possible to temporarily store variables in Zepp OS 2.0 using: hmFS.SysProSetInt64(key, val)
https://docs.zepp.com/docs/watchface/ap ... oSetInt64/
It seems to not work. Does something need to be enabled in the app.json?
I tried:
Код: Виділити все
hmFS.SysProSetInt64("myCounter", 1234567890);
const value = hmFS.SysProGetInt64("myCounter");
Аватар користувача
SysProSetInt works fine.
I have never used SysProSetInt64.
Imozeb
Does your editor output Zepp OS 1.0 or Zepp OS 2.0 code? If it is 1.0, does that mean that I can only use functions from the Watchface 1.0 DOCS and not 2.0 or App DOCS?
Аватар користувача
The editor creates watch faces on API 1. Widgets that appeared only on API 2 will work in most cases in such watch faces. However, some functions (e.g. new sensors) will not work because they are in a different namespace and cannot be imported into watch faces.
Imozeb
How do I get the heartrate array for the day?
I tried to follow the docs here, but the array won't populate. https://docs.zepp.com/docs/watchface/ap ... rId/HEART/
My Code:
Код: Виділити все
heart.addEventListener(event, callback: Callback)
const hrTodayListener = function () {
  let myArray = heart.today;
heart.addEventListener(heart.event.today, hrTodayListener)
Finferlo
З нами з: 25 квітня 2020, 14:12
Повідомлення Finferlo »
Good morning, I downloaded version 14 of this software this morning, but it doesn't start on Windows 11. However, version 13.2 continues to work correctly. Is there something I need to do that I haven't done?
Аватар користувача
I can only advise you to download it again. Because I didn't add any new modules or libraries. If you get an error message, send it to me, it might help to understand the cause.
Аватар користувача
frankh93
З нами з: 20 червня 2025, 00:32
Has thanked: 26 times
Повідомлення frankh93 »
There is a way to make the watch vibrates when pressing a button?
I have been playing around with the code and managed to get working the background and a foreground changing depending on what button is pressed (it's an array of colors) but would like to make the watch vibrates when these buttons are pressed. Thank you beforehand
Finferlo
SashaCX75 писав: 13 липня 2025, 12:05
I downloaded the package again, launched it after unzipping it, it starts, asks me to grant permission to Win, and after granting it, the program doesn't load, no error message is displayed, it simply doesn't start.
I repeated the same operation with package 13.2, and it starts normally. All packages BEFORE 14 start.
Edit:
I put the 13.2 executable file in the version 14 package and it DOESN'T RUN. If I put the 14 executable file in the version 13.2 folder, it doesn't run.
Only version 13.2 (and earlier) runs within their package.
Lattenknaller
З нами з: 09 серпня 2022, 08:43
Has thanked: 62 times
Been thanked: 167 times
Повідомлення Lattenknaller »
under Windows the program does not ask for permission.
Could it be that you are emulating Windows on a Mac, for example? I have installed 14 on several Windows computers without any problems.
Аватар користувача
Version 14.1
Mirror
Fixed issues with the circular scale on some widgets.
Added support for Active 2 (Square).
Аватар користувача
frankh93
I managed to get a code to change bg depending on which button I press but wanna move some elements too. I got a weather temp and icon, a day of the week and date number, and the heart rate.... Tried with setProperty(hmUI.prop.MORE, {y:....}) but only week of the date and date number got moved... Gotta do it in other way for the other elements? Or I'm missing something?
Finferlo
Lattenknaller писав: 14 липня 2025, 12:16
I disabled the security check, now it works. Good afternoon.
Аватар користувача
@frankh93
Try prop.Y or prop.POS_X.
Also, if you use prop.MORE, for some widgets you need to change all parameters at once, not just the coordinates.
Аватар користувача
Version 14.1.1
Mirror
Critical update for the circular distance display widget. In version 14.1, it causes an error in watch faces.
Аватар користувача
frankh93
SashaCX75 писав: 15 липня 2025, 16:35
@frankh93
Tried what you told me and only hmUI.prop.Y worked but only for the weathericon, it didn't work for current temperature and heart rate. This is my code:
code
user_functions.js
Код: Виділити все
const bgColorsSet = [
    "WHITE", "BLUE", "TURQUOISE", "GREEN", "ORANGE", "RED", "VIOLET"
let bgColorsIndex = 0;
let currColor = "";
let currBgColor = "";
let currCardColor = "";
let solidModulesStyle = false;
let currModulesStyle = "OUTLINE"
// positions for modules
let weathericon_ypos = 25;
let temp_ypos = 66;
let dow_ypos = 206;
let day_ypos = 228;
let hrm_ypos = 356;
user_script_end.js
Код: Виділити все
function prevColor(){
    bgColorsIndex = (bgColorsIndex - 1 + bgColorsSet.length) % bgColorsSet.length;
    updateWatchface();
function nextColor(){
    bgColorsIndex = (bgColorsIndex + 1) % bgColorsSet.length;
    updateWatchface();
function modulesStyle(){
    solidModulesStyle = !solidModulesStyle;
    if (solidModulesStyle){
        currModulesStyle = "SOLID";
        // positions
        weathericon_ypos = 48;
        temp_ypos = 84;
        dow_ypos = 214;
        day_ypos = 236;
        hrm_ypos = 372;
    else{
        currModulesStyle = "OUTLINE";
        // positions
        temp_ypos = 66;
        dow_ypos = 206;
        day_ypos = 228;
        hrm_ypos = 356;
    updateWatchface();
function updateWatchface(){
    currColor = bgColorsSet[bgColorsIndex];
    // positions
    normal_weather_image_progress_img_level.setProperty(hmUI.prop.Y, weathericon_ypos);
    normal_temperature_current_text_font.setProperty(hmUI.prop.MORE, {
        x: 231,
        y: temp_ypos,
        w: 100,
        h: 30
    // styles
    currBgColor = "MODULES_" + currModulesStyle + "_" + currColor + ".png";
    currCardColor = "FRONT_CARD_" + currColor + ".png";
    normal_background_bg_img.setProperty(hmUI.prop.SRC, currBgColor);
updateWatchface();
function hideSettings(){
    // normal buttons
    Button_1.setProperty(hmUI.prop.VISIBLE, true);
    Button_2.setProperty(hmUI.prop.VISIBLE, true);
    Button_3.setProperty(hmUI.prop.VISIBLE, true);
    Button_4.setProperty(hmUI.prop.VISIBLE, true);
    Button_5.setProperty(hmUI.prop.VISIBLE, true);
    // clock
    normal_time_hour_text_font.setProperty(hmUI.prop.VISIBLE, true);
    normal_time_minute_text_font.setProperty(hmUI.prop.VISIBLE, true);
    normal_analog_clock_pro_minute_pointer_img.setProperty(hmUI.prop.VISIBLE, true);
    // settings layout
    Button_6.setProperty(hmUI.prop.VISIBLE, false);
    Button_7.setProperty(hmUI.prop.VISIBLE, false);
    Button_8.setProperty(hmUI.prop.VISIBLE, false);
    Button_10.setProperty(hmUI.prop.VISIBLE, true);
    normal_image_img.setProperty(hmUI.prop.SRC, currCardColor);
hideSettings();
function showSettings(){
    // normal buttons
    Button_1.setProperty(hmUI.prop.VISIBLE, false);
    Button_2.setProperty(hmUI.prop.VISIBLE, false);
    Button_3.setProperty(hmUI.prop.VISIBLE, false);
    Button_4.setProperty(hmUI.prop.VISIBLE, false);
    Button_5.setProperty(hmUI.prop.VISIBLE, false);
    // clock
    normal_time_hour_text_font.setProperty(hmUI.prop.VISIBLE, false);
    normal_time_minute_text_font.setProperty(hmUI.prop.VISIBLE, false);
    normal_analog_clock_pro_minute_pointer_img.setProperty(hmUI.prop.VISIBLE, false);
    // settings layout
    Button_6.setProperty(hmUI.prop.VISIBLE, true);
    Button_7.setProperty(hmUI.prop.VISIBLE, true);
    Button_8.setProperty(hmUI.prop.VISIBLE, true);
    Button_10.setProperty(hmUI.prop.VISIBLE, false);
    normal_image_img.setProperty(hmUI.prop.SRC, "SETTINGS_OVERLAY.png");
Thank you beforehand for all the help, also sorry for the mess in the code... I'm just starting to learn this and trying my best haha :D
Аватар користувача
Finferlo писав: 15 липня 2025, 14:53
Some users encountered similar problems. They were able to resolve the issue by running the SplashScreen.exe file in the Libs folder. When launched, the system requested permission to run this file. After that, the editor started running normally.
Finferlo
SashaCX75 писав: 16 липня 2025, 17:27
Thanks, I disabled the security check on the executable file and it no longer blocks it.
Відповісти
Хто зараз онлайн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 7 гостей
