Hello, guys!
Recently I switched from Garmin Instinct 2 to Amazfit Balance and while I'm very happy with the device itself, I miss my old watchface called doZen.
I tried recreating it using @SashaCX75 amazing tool, but turns out that there is no option to display two-digit numbers, eg. "58" , as a unique image. It always results in a combination of "5" and "8" mixed together.
Sadly, this is a crucial aspect of the design.
Is there any way to fight this or do I have to abandon all hope?
Displaying two-digit numbers as a unique image - is that possible?
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1036 times
This is possible only if you write the watch face code yourself, and not make it from ready-made elements in the editor. You can't do it in the editor.
I managed to pull it off, yay.
Here is the finished result for those who want to take a peep.
- SashaCX75
Are you sure the battery display is working correctly? I don't think IMG_LEVEL widget has bateriaSzyk parameter.
Truth be told, I haven't tested the battery display, yet, since my Balance lasts ages without the charge.
Nevertheless, thanks for reviewing the code.
I'll take another thorough look at it!
