- Адміністратор
Problem installing Watch Face on Amazfit Balance
Правила форуму
schwaitz
- З нами з: 22 лютого 2021, 21:14
- Контактна інформація:
I have an Amazfit Balance and I'm having trouble downloading watchfaces. When I click on the "show QR on watch" option, it appears that the file has been downloaded, but when I open the Zepp application, click on developer options, then scan and open the gallery, there is no file there, and all the Permissions have been given on Android to both the Amazfaces app and the Zepp app. Could you make a more detailed tutorial on how to install to find out the problem??
- GIK-Team
- root
- З нами з: 22 березня 2018, 10:00
- Has thanked: 1150 times
- Been thanked: 278 times
schwaitz писав: 30 червня 2024, 17:57Could you make a more detailed tutorial on how to install to find out the problem??
- GIK-Team
- root
1. https://docs.zepp.com/docs/guides/tools/zepp-app/schwaitz писав: 30 червня 2024, 20:40The problem is after the installation of QR list. It´s not clear, and even I putting the URL code nothing happens
2. Download QR List app
3. Copy and past URL ID into the QR List app
4. Press "Show QR on the watch" button
schwaitz
The explanation it´s not clear. When I choose the watch face in the app and click on " show QR on the watch ", I wait the advertisement, than nothing happens, there is no QR code appearing at the watch. The old way to sinchronize , as amazfit GTR 4 is much better
TONYRM
- З нами з: 05 листопада 2024, 17:57
- Has thanked: 4 times
Amazfit balance + Samsung s23 Plus
I can't see the QR code
I have given all permissions activated developer mode
If I send the file to qrcode on balance I don't see it and I don't even see the url to copy
Where am I wrong
Sorry my bad English
Where am I wrong
- GIK-Team
- root
Hai letto le istruzioni mostrate dall’app? Troverai tutti i passaggi spiegati passo dopo passo. Prova a seguire la guida e, se riscontri ancora problemi, faccelo sapere!TONYRM писав: 06 листопада 2024, 14:01Amazfit balance + Samsung s23 Plus
Where am I wrong
TONYRM
Grazie della rispostaGIK-Team писав: 06 листопада 2024, 20:12Hai letto le istruzioni mostrate dall’app? Troverai tutti i passaggi spiegati passo dopo passo. Prova a seguire la guida e, se riscontri ancora problemi, faccelo sapere!TONYRM писав: 06 листопада 2024, 14:01Amazfit balance + Samsung s23 Plus
Where am I wrong
Ho seguito la guida, il balance è connesso al telefono
-Attivato la modalità sviluppatore
-Messo visibile in zepp il balance
-dato i permessi
-Scaricato Qrcode
Nulla ...quando invio il qrcode al balance non lo vedo e non vedo neanche url da app AW
Come posso verificare se AW si connette a zeep o al Balance?
Grazie
- GIK-Team
- root
Ecco l’istruzione completa:TONYRM писав: 07 листопада 2024, 09:06Grazie della risposta
-dato i permessi
-Scaricato Qrcode
Grazie
- Abilita la modalità sviluppatore (dev mode) su Zepp: Link alla guida.
- Scarica l’app QR List dal Zepp App Store.
- Copia l’URL ID (passaggio 2 dell’istruzione mostrata nella nostra app durante il download del quadrante) e incollalo nell’app QR List.
- Apri QR List sull’orologio e scansiona il QR con l’app Zepp in modalità sviluppatore.
TONYRM
Ho letto le istruzioni..GIK-Team писав: 07 листопада 2024, 09:35Ecco l’istruzione completa:TONYRM писав: 07 листопада 2024, 09:06Grazie della risposta
-dato i permessi
-Scaricato Qrcode
GrazieFammi sapere se riscontri ancora problemi!
Ho seguito la guida passo per passo
Nella applicazione non vedo url e non riesco a copiare url
Non riesco ad inviare qrcode al Balance
Da pc funziona se leggo il qrcode
Da Telefono non funziona
- GIK-Team
- root
Come puoi vedere, nella zona evidenziata sullo screenshot, basta cliccare lì per copiare l’URL. Una volta copiato, puoi incollarlo nell’app QR List e procedere con l’installazione. Facci sapere se funziona!TONYRM писав: 07 листопада 2024, 13:50Ho letto le istruzioni..
TONYRM
Veramente Grazie...grazieGIK-Team писав: 07 листопада 2024, 18:49Come puoi vedere, nella zona evidenziata sullo screenshot, basta cliccare lì per copiare l’URL. Una volta copiato, puoi incollarlo nell’app QR List e procedere con l’installazione. Facci sapere se funziona!TONYRM писав: 07 листопада 2024, 13:50Ho letto le istruzioni..
Alla fine ci sono riuscito...
Per me era uno spoiler uguale per tutte le whatchface...credevo fossero solo le istruzioni d'uso...
Ti ringrazio ancora...
- GIK-Team
- root
Siamo lieti che alla fine tu ci sia riuscito!TONYRM писав: 07 листопада 2024, 22:02Veramente Grazie...grazie
Per me era uno spoiler uguale per tutte le whatchface...credevo fossero solo le istruzioni d'uso...![]()
Alfred2021
- З нами з: 01 січня 2021, 19:01
Ciao a Tutti. Non vedo qr list da Amazfit app store
- GIK-Team
- root
Per quale modello di orologio stai cercando l’app QR List?
Alfred2021
Ilducatone
- З нами з: 19 вересня 2024, 21:15
Buongiorno,
su QR list non riesco ad inserire nessun URL ID.
Ho seguito tutte le istruzioni ma niente
- GIK-Team
- root
Mi dispiace per i problemi che stai incontrando con l’inserimento degli URL ID su QR list. Per aiutarti al meglio, potresti specificare esattamente cosa succede quando provi ad inserire un URL? Ricevi qualche messaggio di errore? Queste informazioni ci aiuteranno a comprendere meglio il problema e a fornirti una soluzione più precisa.Ilducatone писав: 02 грудня 2024, 14:47Buongiorno,
- GIK-Team
- root
Para utilizar correctamente la funcionalidad QR Card en tu Amazfit Balance, necesitas actualizar nuestra aplicación a la última versión beta disponible. Asegúrate de instalar esta versión beta para acceder a todas las nuevas características, incluida la QR Card.seat600 писав: 02 грудня 2024, 20:41Tengo un Amazfit Balance y en la tienda de aplicaciones de la aplicación Zeep no aparece ninguna apk que se llame QR list, si que aparece una llama QR Card 3.
Хто зараз онлайн
