Resources to create Watchfaces?
Tomynsdk
Post by Tomynsdk »
Hi! I bought an Amazfit Band 7 a couple days ago and I want to costumize it but when i use the watchface maker i don't have the resources (like the style of digital time, weather, calories, etc) and i would like to know if there's any resource package to create the Watchfaces easily! Thanks in advance!
Been thanked: 2120 times
Tomynsdk wrote: 03 Aug 2024, 18:11
All resources are images, you have to create them from scratch
Or the easiest way is you can select resources from the existing watchface in this web and then unpack and bring resource image to make your watchface
And you can create images of numbers, days, months, years from TTF fonts, you can create them through the web at the link below
Tomynsdk
Post by Tomynsdk »
Thanks for the answer! It's actually quite difficult.
I wanted to install a Pipboy watchface that i loved a lot, but i can't download the AmazFaces app because is not available on my Moto g60s and i don't know how to install that watchface any other way :(
I read about some qr codes, but i think that's only for self-created watchfaces.
Anyway, i'll keep trying! Thanks! :)
Moto g60s it use android OS, why you can not Download and install App AmazFaces ??????
I think you should be able to install App AmazFast via Google Play.
https://play.google.com/store/search?q= ... apps&hl=en
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
Another option is the Facemaker application. It has a library that can get you started with different hands, backgrounds, etc. It also has a vector drawing tool. The author has several tutorials on YouTube:
https://www.youtube.com/@FacemakerNunoBessa/videos
Tomynsdk
Post by Tomynsdk »
I don't know why it sais that my phone is not compatible. I downloaded it on my tablet but it's really curious that for using it you need Zepp aplications and Zepp is not compatible with my tablet jajajajajaja
(Everything that could go wrong, went wrong xD)
betebs96
Post by betebs96 »
taw_bip wrote: 03 Aug 2024, 20:06
Thank you for the suggestion! I'll give Facemaker a try. It sounds like it has all the resources I need to get started, plus the tutorials on YouTube will definitely help! Hopefully, this app works better for me than the AmazFaces one. By the way, I came across a handy qr code
recently that might be useful for customizing some watchfaces. I'll check out Facemaker right away! 😊
u6gljnuj4l
Post by u6gljnuj4l »
I’ve had similar problems with customizing watchfaces. You can use tools like Photoshop or free editors to design icons for time and weather. If AmazFaces doesn’t work, Facemaker is a good option with helpful tutorials. You can also try extracting resources from existing watchfaces using mmk.pw/font_extract. Hope this helps,
Return to “Zepp OS”
