• Administrador
MiBandWFTool
Regras do fórum
lvpokka
Registrado em: 07 Jul 2019, 20:22
Has thanked: 19 times
Been thanked: 152 times
Contato:
MiBandWFTool
Mensagem por lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Editado pela última vez por lvpokka em 02 Ago 2020, 19:41, em um total de 24 vezes.
thankkien
Mensagem por thankkien »
Hello GIK-Team, thank you for continuing this project. Yesterday after receiving news that bandbbs did not pursue it, I was very sad. Fortunately, they have publicized it and you are continuing this work.
But maybe this version has a more serious error. The image quality after packaging is too bad, the preview still has many errors. Even if I install it into miband, some components are gone.
Anyway, thank you, wish you have better products for the community
Max88
Registrado em: 30 Mai 2019, 17:54
Contato:
Mensagem por Max88 »
weather doesn't show on band. my bin gets compiled without errors, but on band 4 i don't see info about weather.
just the icon with "?"
lvpokka
Contato:
Max88 escreveu: 08 Jul 2019, 15:32
Could you please provide your bin file?
Max88
Contato:
lvpokka escreveu: 08 Jul 2019, 16:41
here it is
it could be my mistake obviously. at least that's what i hope so it could be fixed XD
thankkien
I think in the next version(1.3), it should be re-added transparency effect. That makes image quality smoother. And there seems to be a lot of errors for the self-made watch face (no wallpaper, battery icon at no time, am / pm has disappeared)
lvpokka
Contato:
* I assume transparent effect is not possible, if you look closer on stock firmware to make smooth image they using part of background image to make "transparency" effect
* Self made - Did you extract some other watch face and use it as template? Did you resize images or just changed colors? Did you add ownwrited json items?
p.s. There is problem with BottomRight* item, if you are changing image size
thankkien
lvpokka escreveu: 09 Jul 2019, 13:32
I'm not sure you developed it from any version of amazfitbiptool. But I used to use bandbbs's mod that @osmat posted on the forum. And the transparent effect can absolutely exist.
I created a completely new watch face. I have referenced some code in .json files. And as I said, It perfectly valid in the version of bandbbs.
Avatar do usuário
lukbe
Registrado em: 02 Jun 2018, 08:09
Been thanked: 8 times
Contato:
Mensagem por lukbe »
i tested this version (MiBandWFTool_1.2.zip) on my WF and it does not work.
After loading in to mi band is on the screen only graphic information about steps and nothin more.
It is this bin file: 00_v2_czech_09072019_nok-3080-38f2abd88c-3080-3ff76a872a.bin
here: https://amazfitwatchfaces.com/mi-band-4/view/83
here is really any prblem with transparency, because with AmazfitBipTools_Mi4_1.0.3 my WF wotk fine!
lvpokka
Contato:
UPDATE*
v1.3.3
https://yadi.sk/d/To9OZUcxNp_qGg
- bug fixes
P.S.(if v1.3.* is unpacking images with black background, it's mean that previously transparency was cutoff, please use new images or from previous build to fix watchface files)
Editado pela última vez por lvpokka em 10 Jul 2019, 17:29, em um total de 5 vezes.
gavan82
Mensagem por gavan82 »
hi there,
can anyone please tell precisely, what I need to carefully do to edit the 0000.png
does it need to have same color palette or else?
mutlab
Registrado em: 09 Jul 2019, 13:26
Contato:
Mensagem por mutlab »
Ciao,
I used the version 1.3.2 : the package is compiled with my .json but while the .gif show what I (think) is right, the .bin on the Mi Band 4 is wrong!
If you want to debug:
*ThisSite*/mi-band-4/view/770
v1.2
I used the RAW compiler.
Thanks in advance
L
Avatar do usuário
lukbe
Contato:
I used version of this tool 1.3.2 and here is problem with part of json named like: Status. Please can you share example of this part. Thank you
As you can see bellow, here is few commands named unknown. This is unpacked json from original WF.
Código: Selecionar todos
  "Status": {
    "DoNotDisturb": {
      "Coordinates": {
        "X": 6,
        "Y": 10,
        "Unknown3": 17,
        "Unknown4": 2,
        "Unknown5": 1
      "ImageIndexOn": 43
    "Lock": {
      "Coordinates": {
        "X": 23,
        "Y": 10,
        "Unknown3": 17,
        "Unknown4": 2,
        "Unknown5": 1
      "ImageIndexOn": 44
    "Bluetooth": {
      "Coordinates": {
        "X": 40,
        "Y": 10,
        "Unknown3": 12,
        "Unknown4": 2,
        "Unknown5": 1
      "ImageIndexOff": 42
    "Battery": {
      "Unknown1": 0,
      "Icon": {
        "X": 93,
        "Y": 10,
        "ImageIndex": 45,
        "ImagesCount": 9
lvpokka
Contato:
Please check fixed one https://yadi.sk/d/To9OZUcxNp_qGg v1.3.3
Updated*
Added circular/linear step progress on preview
Editado pela última vez por lvpokka em 10 Jul 2019, 19:56, em um total de 2 vezes.
Avatar do usuário
lukbe
Contato:
Perfect, now it is ok...
Do you have idea why weather does not work ? Is it problem with FW?
lvpokka
Contato:
Not exposed still, looks like its part of "fantastic" upgrade with new watchfaces :D
gavan82
what is the difference pallete image mode and raw image mode?
lvpokka
Contato:
Palette mode store only unique pixels for image (like zip file) but if hq image is used then it's more efficient to use raw mode, it will store image pixel by pixel)
Therefore if image is simple and use 5-20 unique pixels, it's good to use palette mode.
Solution: Just check .bin size and use smaller one.
mutlab
Contato:
Ciao
with V1.3.3 the code
  "Date": {
    "MonthAndDay": {
      "OneLine": {
        "Number": {
          "TopLeftX": 5,
          "TopLeftY": 119,
          "BottomRightX": 70,
          "BottomRightY": 132,
          "Alignment": "TopLeft",
          "Spacing": 1,
          "ImageIndex": 21,
          "ImagesCount": 10
        "DelimiterImageIndex": 31
      "TwoDigitsMonth": true,
      "TwoDigitsDay": true
    "WeekDay": {
      "X": 85,
      "Y": 123,
      "ImageIndex": 32,
      "ImagesCount": 7
  "StepsProgress": {
    "Linear": {
is compiled, while
  "Date": {
    "MonthAndDay": {
      "Separate": {
        "Month": {
          "TopLeftX": 45,
          "TopLeftY": 119,
          "BottomRightX": 70,
          "Spacing": 0,
          "ImageIndex": 21,
          "ImagesCount": 10
        "Day": {
          "TopLeftX": 5,
          "TopLeftY": 119,
          "BottomRightX": 30,
          "Spacing": 0,
          "ImageIndex": 21,
          "ImagesCount": 10
  "StepsProgress": {
    "Linear": {
return the following error:
Newtonsoft.Json.JsonSerializationException: Could not find member 'StepsProgress' on object of type 'Date'. Path 'Date.StepsProgress', line 108, position 17.
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at WatchFace.Program.ReadWatchFaceConfig(String jsonFileName)
But the member StepsProgress is defined!
user_test
Mensagem por user_test »
lvpokka escreveu: 10 Jul 2019, 19:55
I am having a problem with the Palette Version which is the one which I need to make a WF with animation because of the size.
The bin is well compiled, and the gif animation appears to be ok, but when I install it into the Mi Band, the screen is all black and can not see anything expect one number of the battery.
Could you please tell me if I am doing something wrong or if there is a bug which will be fixed in your next version?
Really appreciate your work, thank you so much!
Anexos
Pokeball_packed.zip
(307.93 KiB) Baixado 1010 vezes
mutlab
Contato:
mutlab escreveu: 11 Jul 2019, 08:24
Ciao
  "Date": {
    "MonthAndDay": {
      "OneLine": {
        "Number": {
          "TopLeftX": 5,
          "TopLeftY": 119,
          "BottomRightX": 70,
          "Spacing": 1,
          "ImageIndex": 21,
          "ImagesCount": 10
    "WeekDay": {
      "X": 85,
      "Y": 123,
      "ImageIndex": 32,
      "ImagesCount": 7
  "StepsProgress": {
    "Linear": {
is compiled, while
sorry..It was myfault. forget about it
thankkien
* Does anyone know how to add calories?
It is not supported yet?
** My proposal for the new version
/ Why don't we allow it to be named freely. I think adding new languages ​​to the watch face will be simpler.
/ Now if I remove the day of the week in Chinese, it will fail. I have to add 14 image files for Chinese weekdays and 2 image files for morning and afternoon. Memory waste is too great
lvpokka
Contato:
user_test escreveu: 11 Jul 2019, 08:30
Images are ok, you have problems with json
"TopLeftX": 30,
"TopLeftY": 213,
"BottomRightX": 76,
"BottomRightY": 158,
please check TopLeft BottomRight?
Editado pela última vez por lvpokka em 11 Jul 2019, 11:35, em um total de 3 vezes.
lvpokka
Contato:
thankkien escreveu: 11 Jul 2019, 10:38
-named freely, there is just 1,2,3,4,5.. text is just for linking with data and sequence ) btw English is universal language
WeekDay
DayAmPm
Battery>Icon
Is required, but you can use ultra small memory)) please x=0 y=0 and make image of 1 black pixel!
btw. you can use only 7 images for WeekDay or 14 or 21 but remember all files should go from 0000 -> X without missing if you remove image you should rename all images after
user_test
lvpokka escreveu: 11 Jul 2019, 11:26
"TopLeftX": 30,
"TopLeftY": 213,
"BottomRightX": 76,
Sorry buy I can't understand you. So the problem in my json is that some BottomRightX and BottomRightY are not correct, and for that reason the Watchface is not showing the elements right?
It means that if I adjust the BottomRights positions to match exactly the size of elements, all the elements will be shown?
Thank you in advice.
Responder
Quem está online
