• 管理员
MiBandWFTool
版面规则
回复
lvpokka
来自: L1
Has thanked: 19 time
Been thanked: 152 time
联系:
MiBandWFTool
帖子 lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
上次由 lvpokka 在 02 8月 2020, 19:41,总共编辑 24 次。
thankkien
帖子 thankkien »
Hello GIK-Team, thank you for continuing this project. Yesterday after receiving news that bandbbs did not pursue it, I was very sad. Fortunately, they have publicized it and you are continuing this work.
But maybe this version has a more serious error. The image quality after packaging is too bad, the preview still has many errors. Even if I install it into miband, some components are gone.
Anyway, thank you, wish you have better products for the community
Max88
来自: Italia
Has thanked: 13 time
联系:
帖子 Max88 »
weather doesn't show on band. my bin gets compiled without errors, but on band 4 i don't see info about weather.
just the icon with "?"
lvpokka
来自: L1
联系:
帖子 lvpokka »
Max88 写了: 08 7月 2019, 15:32
Could you please provide your bin file?
Max88
来自: Italia
联系:
帖子 Max88 »
lvpokka 写了: 08 7月 2019, 16:41
here it is
it could be my mistake obviously. at least that's what i hope so it could be fixed XD
thankkien
帖子 thankkien »
I think in the next version(1.3), it should be re-added transparency effect. That makes image quality smoother. And there seems to be a lot of errors for the self-made watch face (no wallpaper, battery icon at no time, am / pm has disappeared)
lvpokka
来自: L1
联系:
帖子 lvpokka »
* I assume transparent effect is not possible, if you look closer on stock firmware to make smooth image they using part of background image to make "transparency" effect
* Self made - Did you extract some other watch face and use it as template? Did you resize images or just changed colors? Did you add ownwrited json items?
p.s. There is problem with BottomRight* item, if you are changing image size
thankkien
帖子 thankkien »
lvpokka 写了: 09 7月 2019, 13:32
I'm not sure you developed it from any version of amazfitbiptool. But I used to use bandbbs's mod that @osmat posted on the forum. And the transparent effect can absolutely exist.
I created a completely new watch face. I have referenced some code in .json files. And as I said, It perfectly valid in the version of bandbbs.
头像
lukbe
来自: Czech
Been thanked: 8 time
联系:
帖子 lukbe »
i tested this version (MiBandWFTool_1.2.zip) on my WF and it does not work.
After loading in to mi band is on the screen only graphic information about steps and nothin more.
It is this bin file: 00_v2_czech_09072019_nok-3080-38f2abd88c-3080-3ff76a872a.bin
here: https://amazfitwatchfaces.com/mi-band-4/view/83
here is really any prblem with transparency, because with AmazfitBipTools_Mi4_1.0.3 my WF wotk fine!
lvpokka
来自: L1
联系:
帖子 lvpokka »
UPDATE*
v1.3.3
https://yadi.sk/d/To9OZUcxNp_qGg
- bug fixes
P.S.(if v1.3.* is unpacking images with black background, it's mean that previously transparency was cutoff, please use new images or from previous build to fix watchface files)
上次由 lvpokka 在 10 7月 2019, 17:29,总共编辑 5 次。
gavan82
帖子 gavan82 »
hi there,
can anyone please tell precisely, what I need to carefully do to edit the 0000.png
does it need to have same color palette or else?
mutlab
联系:
帖子 mutlab »
Ciao,
I used the version 1.3.2 : the package is compiled with my .json but while the .gif show what I (think) is right, the .bin on the Mi Band 4 is wrong!
If you want to debug:
*ThisSite*/mi-band-4/view/770
v1.2
I used the RAW compiler.
Thanks in advance
L
头像
lukbe
来自: Czech
联系:
帖子 lukbe »
I used version of this tool 1.3.2 and here is problem with part of json named like: Status. Please can you share example of this part. Thank you
As you can see bellow, here is few commands named unknown. This is unpacked json from original WF.
代码: 全选
  "Status": {
    "DoNotDisturb": {
      "Coordinates": {
        "X": 6,
        "Y": 10,
        "Unknown3": 17,
        "Unknown4": 2,
        "Unknown5": 1
      "ImageIndexOn": 43
    "Lock": {
      "Coordinates": {
        "X": 23,
        "Y": 10,
        "Unknown3": 17,
        "Unknown4": 2,
        "Unknown5": 1
      "ImageIndexOn": 44
    "Bluetooth": {
      "Coordinates": {
        "X": 40,
        "Y": 10,
        "Unknown3": 12,
        "Unknown4": 2,
        "Unknown5": 1
      "ImageIndexOff": 42
    "Battery": {
      "Unknown1": 0,
      "Icon": {
        "X": 93,
        "Y": 10,
        "ImageIndex": 45,
        "ImagesCount": 9
lvpokka
来自: L1
联系:
帖子 lvpokka »
Please check fixed one https://yadi.sk/d/To9OZUcxNp_qGg v1.3.3
Updated*
Added circular/linear step progress on preview
上次由 lvpokka 在 10 7月 2019, 19:56,总共编辑 2 次。
头像
lukbe
来自: Czech
联系:
帖子 lukbe »
Perfect, now it is ok...
Do you have idea why weather does not work ? Is it problem with FW?
lvpokka
来自: L1
联系:
帖子 lvpokka »
Not exposed still, looks like its part of "fantastic" upgrade with new watchfaces :D
gavan82
帖子 gavan82 »
what is the difference pallete image mode and raw image mode?
lvpokka
来自: L1
联系:
帖子 lvpokka »
Palette mode store only unique pixels for image (like zip file) but if hq image is used then it's more efficient to use raw mode, it will store image pixel by pixel)
Therefore if image is simple and use 5-20 unique pixels, it's good to use palette mode.
Solution: Just check .bin size and use smaller one.
mutlab
联系:
帖子 mutlab »
Ciao
with V1.3.3 the code
代码: 全选
  "Date": {
    "MonthAndDay": {
      "OneLine": {
        "Number": {
          "TopLeftX": 5,
          "TopLeftY": 119,
          "BottomRightX": 70,
          "BottomRightY": 132,
          "Alignment": "TopLeft",
          "Spacing": 1,
          "ImageIndex": 21,
          "ImagesCount": 10
        "DelimiterImageIndex": 31
      "TwoDigitsMonth": true,
      "TwoDigitsDay": true
    "WeekDay": {
      "X": 85,
      "Y": 123,
      "ImageIndex": 32,
      "ImagesCount": 7
  "StepsProgress": {
    "Linear": {
is compiled, while
代码: 全选
  "Date": {
    "MonthAndDay": {
      "Separate": {
        "Month": {
          "TopLeftX": 45,
          "TopLeftY": 119,
          "BottomRightX": 70,
          "Spacing": 0,
          "ImageIndex": 21,
          "ImagesCount": 10
        "Day": {
          "TopLeftX": 5,
          "TopLeftY": 119,
          "BottomRightX": 30,
          "Spacing": 0,
          "ImageIndex": 21,
          "ImagesCount": 10
  "StepsProgress": {
    "Linear": {
return the following error:
Newtonsoft.Json.JsonSerializationException: Could not find member 'StepsProgress' on object of type 'Date'. Path 'Date.StepsProgress', line 108, position 17.
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at WatchFace.Program.ReadWatchFaceConfig(String jsonFileName)
But the member StepsProgress is defined!
user_test
帖子 user_test »
lvpokka 写了: 10 7月 2019, 19:55
I am having a problem with the Palette Version which is the one which I need to make a WF with animation because of the size.
The bin is well compiled, and the gif animation appears to be ok, but when I install it into the Mi Band, the screen is all black and can not see anything expect one number of the battery.
Could you please tell me if I am doing something wrong or if there is a bug which will be fixed in your next version?
Really appreciate your work, thank you so much!
附件
Pokeball_packed.zip
(307.93 KiB) 已下载 1003 次
mutlab
联系:
帖子 mutlab »
mutlab 写了: 11 7月 2019, 08:24
Ciao
代码: 全选
  "Date": {
    "MonthAndDay": {
      "OneLine": {
        "Number": {
          "TopLeftX": 5,
          "TopLeftY": 119,
          "BottomRightX": 70,
          "Spacing": 1,
          "ImageIndex": 21,
          "ImagesCount": 10
    "WeekDay": {
      "X": 85,
      "Y": 123,
      "ImageIndex": 32,
      "ImagesCount": 7
  "StepsProgress": {
    "Linear": {
is compiled, while
sorry..It was myfault. forget about it
thankkien
帖子 thankkien »
* Does anyone know how to add calories?
It is not supported yet?
** My proposal for the new version
/ Why don't we allow it to be named freely. I think adding new languages ​​to the watch face will be simpler.
/ Now if I remove the day of the week in Chinese, it will fail. I have to add 14 image files for Chinese weekdays and 2 image files for morning and afternoon. Memory waste is too great
lvpokka
来自: L1
联系:
帖子 lvpokka »
user_test 写了: 11 7月 2019, 08:30
Images are ok, you have problems with json
"TopLeftX": 30,
"TopLeftY": 213,
"BottomRightX": 76,
"BottomRightY": 158,
please check TopLeft BottomRight?
上次由 lvpokka 在 11 7月 2019, 11:35,总共编辑 3 次。
lvpokka
来自: L1
联系:
帖子 lvpokka »
thankkien 写了: 11 7月 2019, 10:38
-named freely, there is just 1,2,3,4,5.. text is just for linking with data and sequence ) btw English is universal language
WeekDay
DayAmPm
Battery>Icon
Is required, but you can use ultra small memory)) please x=0 y=0 and make image of 1 black pixel!
btw. you can use only 7 images for WeekDay or 14 or 21 but remember all files should go from 0000 -> X without missing if you remove image you should rename all images after
user_test
帖子 user_test »
lvpokka 写了: 11 7月 2019, 11:26
"TopLeftX": 30,
"TopLeftY": 213,
"BottomRightX": 76,
Sorry buy I can't understand you. So the problem in my json is that some BottomRightX and BottomRightY are not correct, and for that reason the Watchface is not showing the elements right?
It means that if I adjust the BottomRights positions to match exactly the size of elements, all the elements will be shown?
Thank you in advice.
回复
回到 “Watchfaces tools”
在线用户
正浏览此版面之用户: 没有注册用户 和 1 访客
