Convert request [GTR 4]
Hello fellas, wondering if someone could port this nice T-Rex 2 watchface (I tried myself but sucks at scripting) to GTR 4.
Sasha's editor works pretty good but some elements results on overlapping (ie: altitude/HRS/sunset/sunrise/etc)
IMPORTANT: Permission given from the original creator https://amazfitwatchfaces.com/ucp/786346
Just give proper credit if published (following site rules, of course).
Cbf Sporty
Cbf Sporty
- Has thanked: 429 times
- Been thanked: 2132 times
AWfan wrote: 12 Jun 2024, 21:31Spoiler
Cbf Sporty
Pack by use Editor Version Beta
Pack by use Editor Version 10.4 :
ENG:
Thank you very much!asoo wrote: 13 Jun 2024, 04:15Spoiler
AWfan wrote: 12 Jun 2024, 21:31Hello fellas, wondering if someone could port this nice T-Rex 2 watchface (I tried myself but sucks at scripting) to GTR 4.
Cbf SportyDownload
CBF_Sporty_v10_ALT_pol_full_aod_GTR_4.zip
CBF_Sporty_v10_ALT_pol_full_aod_GTR_4_104.zip
Cheers!
PS: Both versions working ok, props for both Sasha & You!
mrbutthead
- Has thanked: 60 times
- Been thanked: 5 times
mrbutthead
mrbutthead
@asoo I like this author's work. Perhaps there are instructions on how you ported it for GTR4? It’s just inconvenient for me to constantly ask on the forum to port
I'm not sure about your question.mrbutthead wrote: 01 Aug 2024, 21:44@asoo I like this author's work. Perhaps there are instructions on how you ported it for GTR4? It’s just inconvenient for me to constantly ask on the forum to port
If I understand correctly, you want to port this user's work because you like his work, right? If so, from what I've seen, his work generally uses custom scripts. If you want to port his work, you must be know about writing javascript.
Using an editor program to convert alone won't do.
Because the script he wrote is not in a format that the program editor can use immediately. You have to modify the variable values to use it with a device with a different screen size than the original.
The editor may only be able to resize the image and built basic scripts that the program can understand for you. And you may need some image editing knowledge to resize the image to fit your device.
However, this user writes good javascript that is easy to understand.
If you want to port his work. I would recommend that you study about writing javascript and, most importantly, don't forget to ask for permission from the owner of the work before modifying his work.
Editing work that uses custom scripts
You have to look in the index.js file to see what additional scripts the creator has written to create options that are not in the base editor. Then you can port it correctly. And of course, those scripts are in javascript format. So if you want to port, you will inevitably need to have some knowledge of javascript.
mrbutthead
@asoo Thanks for the detailed explanation. Unfortunately I don't know JavaScript. The author is not against his work being ported.
- Has thanked: 132 times
- Been thanked: 21 times
There are a lot of AI tools that can help interpret and write Javascript like Gemini, Copilot and Claude.mrbutthead wrote: 02 Aug 2024, 08:04@asoo Thanks for the detailed explanation. Unfortunately I don't know JavaScript. The author is not against his work being ported.
