BA POWER FORCE 200 ( Amazfit GTR3 Pro )
- Has thanked: 205 times
- Been thanked: 5 times
Hello guys, because i have no access to sasha editor 11.0 beta and this watchface can't convert at all with editor 10.4, can someone with knowledge convert this watchface for GTR3 Pro? A big thanks to asoo for his amazing work. Thank you.
https://amazfitwatchfaces.com/balance/view/999
- Has thanked: 420 times
- Been thanked: 2120 times
Thank you. Watchface rocks!
asoo, can you fix lcd white because it isn't like preview. I attach photo to show you. Black screen works fine. Only white has the problem. Thank you.
The problem lies in the ZeppOS1 part. It cannot read some commands of higher zeppOS scripts, so an error occurs.
I'm not sure if the fix will work properly.
Because I no longer use a device running ZeppOS 1.
You may need to test it on your own device.
If it still doesn't work properly I probably won't be able to make any changes.
Fix1 :
viewtopic.php?p=18293#p18293
Thank you, asoo. It's fixed now.
