BA POWER FORCE 200 ( Amazfit GTR3 Pro )
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello guys, because i have no access to sasha editor 11.0 beta and this watchface can't convert at all with editor 10.4, can someone with knowledge convert this watchface for GTR3 Pro? A big thanks to asoo for his amazing work. Thank you.
https://amazfitwatchfaces.com/balance/view/999
Has thanked: 438 times
Been thanked: 2142 times
GTR3pro:
BA_POWER_FORCE_200_GTR_3_ProFix1.zip
(976.35 KiB) Downloaded 133 times
Amazfit Balance :
Thank you. Watchface rocks!
asoo, can you fix lcd white because it isn't like preview. I attach photo to show you. Black screen works fine. Only white has the problem. Thank you.
amazfitfacesafrica wrote: 30 May 2024, 06:24
The problem lies in the ZeppOS1 part. It cannot read some commands of higher zeppOS scripts, so an error occurs.
I'm not sure if the fix will work properly.
Because I no longer use a device running ZeppOS 1.
You may need to test it on your own device.
If it still doesn't work properly I probably won't be able to make any changes.
Fix1 :
viewtopic.php?p=18293#p18293
Thank you, asoo. It's fixed now.
